Help Needed! Pc boot issues.
Discussion in 'Troubleshooting Help' started by Angus M, Dec 16, 2018.
Tags:
  1. Angus M
    Angus M New Member
    Nov 20, 2018
    5
    Hi guys,
    My current PC, 1920x/Aorus Gaming 7 X399 build, crashed yesterday. This computer has had no issues in the past and this is my first major roadblock with it. Anyways, after it crashed, when I tried to boot it again the motherboard leds and the fans flicked on for a split second and then shut off but the leds on the ram and the gpu stayed on. When I tried again it did nothing and I had to switch off the power supply to try again. So far I have drained the loop and searched for any shorts or loose wires but haven't found anything. I've also tested the ram and gone through the manual with no success. The only other ideas I have are possible mobo, cpu or psu failure but i'm not sure which one has gone wrong. Any help would be much appreciated.
    Cheers
  2. Bold Eagle
    Bold Eagle Member
    Jun 28, 2008
    7,946
    Paperclip test the PSU to start with.
    The LEDs do they have codes (numbers)?
    Angus M
    Angus M New Member
    Nov 20, 2018
    5
    The Psu is good. I checked it on another system. Also, the mobo does have to led codes but the system shuts off before the codes start running through.
  4. shane41
    shane41 Member
    Nov 10, 2008
    5,990
    on the edge
    Cmos reset. Then see your ram sticker. Input the required volt for ram in bios or a tad more, boot.
