Help needed with wifi
Discussion in 'Networking, Telephony & Internet' started by XXX-XXX, Feb 9, 2019.
  1. XXX-XXX
    XXX-XXX Member
    Jan 20, 2008
    282
    sydney
    I just bought a new router (netgear 7000p) I set it up and everything was fine.Then I decided to change the network name on the 2,4ghz band and since then one computer running windows 10 with a usb wifi adapter can no longer detect the network anymore. I have tried uninstalling it from device manager. Though not sure what else to do when it was working fine before.
    Any ideas?
  2. bcann
    bcann Member
    Feb 26, 2006
    5,462
    NSW
    Are you sure that the usb wifi is dual band?
    XXX-XXX
    XXX-XXX Member
    Jan 20, 2008
    282
    sydney
    nah the usb is only on the 2.4 band though it should still detect that network right? It detected it the first time, it was only when I changed the network name that it failed to detect it anymore. Though all my other devices see it fine.
  4. bcann
    bcann Member
    Feb 26, 2006
    5,462
    NSW
    It should see the new network but you'll need to reconfig to connect to it
    XXX-XXX
    XXX-XXX Member
    Jan 20, 2008
    282
    sydney
    Ok.Do you mean reconfig the router or the usb stick?
    I am not sure what is happening. I have tried taking the usb to another pc and it finds the network fine. Then move it back the the first pc and nothing?
    I have tried a network reset in windows and still nothing?
  6. caspian
    caspian Member
    Mar 11, 2002
    9,803
    XXX-XXX
    XXX-XXX Member
    Jan 20, 2008
    282
    sydney
    Hey. I tried that just now and still no luck. I set the SSID to what it was and it could not find that anymore? Anything else to try. It has to be a windows thing though right?
  8. dragonFLAME
    dragonFLAME Member
    Nov 18, 2002
    738
    Somewhere Cool
    check country code - could be setting it to a band that your 2.4ghz device can't see.
  9. voltare1
    voltare1 Member
    Jun 6, 2002
    399
    Set the WiFi channel from auto (cause it likes to pick 0) to 3-6 or 9
    caspian likes this.
    XXX-XXX
    XXX-XXX Member
    Jan 20, 2008
    282
    sydney
    Ahh. That seemed to have fixed it. Thanks mate.I thought it must have been a windows problem cause I got it to work when running ubuntu off a flash drive though as soon as it went back to windows it stopped. Though all working now.Cheers
