Help putting a loop in
Discussion in 'Extreme and Water Cooling' started by motas, Aug 29, 2010.
  1. OP
    motas
    motas Member
    Oct 14, 2009
    2,316
    Na my cpu is a bit on the hot side. Actually not a bit I got it to 90 degrees on stock settings with stock cooler with a exhaust right next to it. got it to 100 i reckon with a h50 on 4ghz but i stopped it before it got there. Im gonna aim fo 4.5ghz. Yer I have seen mst guides just say unplug everything and you cant ruin anything if theres a leak.
    Thanks.
  2. h2oxide
    h2oxide Member
    Dec 9, 2009
    3,748
    Dude i was clearly kidding about the 5GHz :lol:
    Anyway, yeah you could always just set it up in your case and jump the pump only, without powering on anything else
    motas
    motas Member
    Oct 14, 2009
    2,316
    Sorry I'm half asleep cant even remember what clock speeds normal. Yer I think Ill just do that.
  4. fang_laluna
    fang_laluna Member
    Sep 5, 2009
    1,183
    6Ghz :thumbup:
    motas
    motas Member
    Oct 14, 2009
    2,316
    1thz anyone?
  6. terroristone
    terroristone Member
    Apr 16, 2006
    2,144
    Melb 3030
    TBH i have never tested for leaks, i always use threebond 1110b on fittings and clamps on my hoses, so far over many years i havnt had a single drop of water where it shouldnt be...
    Andrew
    motas
    motas Member
    Oct 14, 2009
    2,316
    Got my resevoirs today. One to use one to mod. And then mod the other and use both lol. The guy at the local computer shop knows how to watercool so he's gonna help me. Should be done Friday.
    Thanks.
  8. retrobot
    retrobot Member
    Apr 12, 2009
    43
    Every WC build needs pics :)
  9. Wootwagon
    Wootwagon Member
    Jun 10, 2010
    462
    Melbourne (boronia)
    i didnt leak test either, cause im impatient, but i bet i would have leaked from :upset: too if the loop decided to leak :tongue: youll be right mate, just check, check then check again, and if your using clamps, dont go too berserk on them, if compression fittings, go tight =]
    motas
    motas Member
    Oct 14, 2009
    2,316
    Compressions all round except pump. I forgot to get a pump top but this is only a temporary loop anyway.
    motas
    motas Member
    Oct 14, 2009
    2,316
    Got it working today. Will post pics tonight. Keeps my stock 920 under 60c (by a bit) with a 360mm rad with 2 oem fans and a delta.
  12. broox
    broox Member
    Apr 27, 2006
    3,600
    Ad'laide SA
    PICS! c'mon maaaan.
    motas
    motas Member
    Oct 14, 2009
    2,316
    Sorry I couldn't find the memory card and had to go camping. I am free tonight so I will hopefuly remember. It's a challenge to get the side on because of the tubing. I still need to work out an overclock that is stable. What should I aim for and what temps and voltages would you stop at?
    Thanks
    motas
    motas Member
    Oct 14, 2009
    2,316
    Hey everyone. Just took some pics and found i had a kink iin my loop. Not good. Anyway I have put a hose clamp over the kink so hopefully will fix it. Are there any other ways to prevent kinks without taking the loop apart?
    Havent done any cable management and cant really be bothered.
    Thanks.
  15. PaulysVision
    PaulysVision Member
    Jan 19, 2010
    289
    Newcastle,Australia
    +1 nicely put.. lol
  16. mugga
    mugga Member
    Feb 15, 2002
    1,098
    Parramatta
    Use some angle adaptors (45 degree) to get out from tight bends. But you will need to drain the water of course.
  17. mr_mordred2095
    mr_mordred2095 Member
    Mar 9, 2004
    3,904
    LOL 60c. Should be nearly ambient.
  18. Copie
    Copie Member
    Jul 24, 2009
    13,741
    Newcastle
    This.
    Another method is to put paper towel around all the fittings to help detect leaks, will also stop anything going onto the equipment.
  19. WuzzA21
    WuzzA21 Member
    Sep 29, 2009
    1,371
    Sounds like you dont really give a shit if your computer fucks up because of a poorly researched watercooling loop. nice work champ.
    http://forums.overclockers.com.au/showthread.php?t=895731
    NEW THREAD
    OVERCLOCK MY COMPUTER FOR ME PLEASE
    "so do i increase the gigabytes for it to zoom zoom?"
  20. PaulysVision
    PaulysVision Member
    Jan 19, 2010
    289
    Newcastle,Australia
    :lol: ouch!!
    nice, i used to use tea towels ;)
