Help with memory
Discussion in 'Troubleshooting Help' started by bananabryan, Apr 21, 2017.
  1. bananabryan
    bananabryan Member
    Jun 5, 2015
    6
    Hi all, just had my first experience building a computer. Everything is connected correctly, although it seems that I have a possible motherboard or RAM issue. When i put in two RAM Sticks, the BIOS does not boot up. When i put in one RAM stick, the BIOS boots up. I've tried putting the RAM sticks in various slots. I have also tried taking out the battery as well as unplugging power. Updating the BIOS also has not worked. In the end i've booted up and installed Windows 10 (x64) with one RAM stick. Currently unsure of what I can do in terms of getting the other RAM stick working.
    PC Specs
    CPU: Intel core i5 7400
    RAM: Kingston Value RAM DDR4 2133 Desktop - 16GB (2x8GB)
    Hard Drive: Firecuda 2TB SSHD
    PSU: 650w Thermaltake RGB toughpower gold
    Graphics Card: GTX 1060 (MSI) Gaming X 6GB
    Motherboard: Asus Strix H270F
    Any help or comments would be appreciated, thanks.
  2. havabeer
    havabeer Member
    Dec 12, 2010
    3,155
    well there's your problem, cheap ass ram.
    email kingston and get them to send you a new stick
  3. Akh-Horus
    Akh-Horus Member
    Feb 8, 2008
    10,537
    Western Vic
    Did you swap the ram chips in the slots?
    bananabryan
    bananabryan Member
    Jun 5, 2015
    6
    Yes, I've tried that and still no success.
  5. i7Baby
    i7Baby Member
    Jul 3, 2012
    290
    Is the RAM on the motherboard memory QVL list?
    bananabryan
    bananabryan Member
    Jun 5, 2015
    6
    I don't believe so, no.
  7. nCrypt
    nCrypt Member
    Feb 12, 2010
    1,470
    QVL means fuck all tbh.
    Never had an issues with non qvl mems in any board that i have used.
    do both sticks work on their own:?
    Maybe one stick is dead.
    Also, which motherboard? and which slots were you installing the mems in?
  8. Bold Eagle
    Bold Eagle Member
    Jun 28, 2008
    6,728
    Agree with this - and which mobo as well?!?
    bananabryan
    bananabryan Member
    Jun 5, 2015
    6
    Asus Strix H270F, I've tried 1-3, 2-4, 1-2, 2-4, 2-3, 3-4
  10. VirtualNinja
    VirtualNinja Member
    Apr 27, 2003
    889
    North Parramatta
    To clarify have you tried both sticks in single channel mode and both worked?
  11. ae00711
    ae00711 Member
    Apr 9, 2013
    1,125
    fuck of. seriously. :thumbdn:
    this. +9999999999999
  12. Cape_Horn
    Cape_Horn Member
    Dec 23, 2001
    2,248
    Shooting Baker
    If it posts with one stick, then do an mem test on each stick, if you get errors on one, you have bad ram.
    if errors on the other, bad ram.
    (Maybe see if you can borrow someone elses ram, known working_) - test that and if that also has issues, new mobo time. (Or is all ram controlled by the cpu and not the NB anymore - it has been a while since I looked at these things)
  13. cvidler
    cvidler Member
    10,860
    until you want help from the motherboard manufacturer/RMA.
    "that RAM isn't supported, bugger off."
    this is certainly 99.999% of the case. It's more a problem with servers and apple, but still not a common thing for a RAM compatibility issue these days.
  14. im late
    im late Member
    Jan 5, 2012
    1,118
    Canning Vale WA 6155
    Not really a QVL issue as one stick of ram got your Windows installed....
    Likely bad stick..
    Process of elimination. :thumbup:
    And going off topic a bit here, but everyone experience with QVL is different.
    I once had a x99 SOC champion that did not post with a particular corsair quad kit (I don't remember the IC right now), and after bios updates and trying different ram in the SOC and the ram in different boards it ended up both parts not being faulty, they just did not work together. The ram kit was not on the QVL list as well.
    But as already stated above at least 99.9999% of the time QVL means dick squat.
    I was able to do these tight mem timings with a ram kit that is not on the R5E QVL list and not even an actual "quad channel" kit.
  15. im late
    im late Member
    Jan 5, 2012
    1,118
    Unfortunately this tends to be a free "get out of jail card" for vendors.
    If your ram is not on the QVL list, then they may turn you away.
  16. cvidler
    cvidler Member
    10,860
    People bag it (cause they don't understand it), but it's entirely fair. You can't expect any manufacturer to support absolutely every combination of every device that can plug into a motherboard.
    If you want it to absolutely work, buy from the QVL (or buy a HP/Dell/etc*). If you're willing to risk it, buy what you want - knowing you're on your own if it doesn't work.
    *and it why their prices are higher, because they have tested everything they sell will work together, and have drivers for it all.
    bananabryan
    bananabryan Member
    Jun 5, 2015
    6
    Thanks for responses everyone. In reference to this, I've tried both sticks in single channel BY THEMSELVES and they work. Once you try put in more than one stick in either single or dual channel the computer won't boot up at all. I just get a DRAM LED warning light.
  18. Xenon
    Xenon Shīrāzī
    315
    Perth, 6105
    Try re-seating your CPU, and check to ensure you haven't bent any pins.
  19. Bold Eagle
    Bold Eagle Member
    Jun 28, 2008
    6,728
    Install each RAM module and then boot into the OS using CPU-Z review the SPD and take note of the Part Number of each stick (take a screenshot and save to desktop to compare them both) - do they match?
    Review the timing tables - do they match?
    Being a budget kit you may find they have not been binned correctly.
    I suspect you are going to need to manually set the voltages and timings of one stick and save in the BIOS and then add the other.
  20. havabeer
    havabeer Member
    Dec 12, 2010
    3,155
    Only other thing to do is take the ram to a mates PC and install them, if it doesn't work you know the ram is stuffed, if it works fine you know your Mobo isn't great
