Help with screws
Discussion in 'Photography & Video' started by chilloutbuddy, Jun 5, 2008.
  1. chilloutbuddy
    chilloutbuddy Member
    Dec 7, 2007
    4,494
    These two screws came from my zenitar 16mm fisheye.
    They're tiny, I've put them next to a coin to give you an idea of the size. Problem is they're both broken and I cant find replacements anywhere. Since Monday I have looked at Jaycar, Bunnings, JB HiFi, all new & used camera stores I know, camera repair centres, 2 jewellers and 3 opticians.
    The accident happened as I was trying to calibrate the lens for infinity focus. No drama, as long as I can find some screws somewhere.
    Any ideas please?
  2. BRGMCS
    BRGMCS Member
    Oct 28, 2005
    2,665
    the issue will be getting pointy ones, but if you go into a decent screw place (fnarr!) they should have some grub screws that could be adapted.
    Other alternative is to get a machinist to turn some up for you, some old crusty dude who has been doing it for 100 years would be your best bet :)
  3. Deckham
    Deckham Member
    Jan 16, 2005
    6,963
    Essendon, Melbourne
    They are grub screws, right?
    Just in case you cant find any anywhere -
    Clamp them in a vice, using padding.
    Cut off the broken bit with a hacksaw.
    Turn the screw vertical, and cut in a screwdriver slot.
    Then just screw them in further then they were.
    Work?
  4. bugeyes
    bugeyes Member
    Oct 10, 2002
    2,472
    There pretty tiny, also consider a good model car/aircraft shop, if no go what about contacting the zenitar/place of purchase?
  5. Deckham
    Deckham Member
    Jan 16, 2005
    6,963
    Essendon, Melbourne
    Could sunglass screws work?
  6. phreeky82
    phreeky82 Member
    Dec 10, 2002
    9,494
    Townsville
    As BRGMCS said, old crusty dudes who've been doing strange stuff for their entire life are sure to be able to make something.
    Do you have vernier calipers to measure them?
    chilloutbuddy
    Dec 7, 2007
    4,494
    Thanks guys, I didnt think about cutting another screw to size, that would work.
    Bugeyes there is no dealer in Australia for these lenses, it came directly from the only factory that makes them in Belarus via an ebay seller in Canada who places the orders. It takes forever for anything to get posted from Belarus, provided you find someone who speaks English. Even the instructions manual was in Russian :)
  8. bugeyes
    bugeyes Member
    Oct 10, 2002
    2,472
    I would still shoot him off an email; you never know he may have spares? They seem like a part that would see a fare bit turnover? Failing that you need to identify the thread size and locate a replacement, cut it to length, grind a point at one end then cut a slot with a jewelers saw.
  9. kini_mini
    kini_mini Member
    Sep 28, 2004
    1,811
    If you know anyone in your area who does fencing (as in with foils), they will probably have some grub screws around.
    Grub screws are used to hold the tips of the foils together, they are a huge pain to work with though, keeping a large magnet around works wonders. They might not be the same size, but it's worth a shot :)
  10. bugeyes
    bugeyes Member
    Oct 10, 2002
    2,472
    last resort you can send me one and I'll see if I can find a match in my selection from my old RC car days?
  11. azz
    azz Member
    Nov 23, 2002
    3,862
    Heidelberg, Melbourne
  12. v81
    v81 Member
    Jan 31, 2005
    679
    SE Vic
    I used to work in the "fastener" industry, specialised in bolts, nuts and other threaded fasteners.
    Still have a few contacts, PM me if you like and we'll see what can be done.
  13. doigal
    doigal Member
    Apr 18, 2003
    2,847
    Linkoping, Sweden
    List of places i would try:
    Opticians - lots of them.
    RC hobby stores, although most of them look too big
    machining clubs
    Camera places - mabey even try canon/nikon/etc and see if they can help?
  14. Iscran
    Iscran Member
    Nov 17, 2006
    635
    World Traveller
    there are some store that specialise in (making) screws. You could try them?
    chilloutbuddy
    Dec 7, 2007
    4,494
    Wow thanks guys, I really appreciate it :)
    I'll have a look again tomorrow for a screw making store (never knew they existed) & hobby stores/opticians etc around my area and let you know how I went
  16. Iscran
    Iscran Member
    Nov 17, 2006
    635
    World Traveller
  17. dawesius
    dawesius Member
    Feb 3, 2007
    241
    Newcastle
    Well, someone at a forge/small engineering type place would more than likely know someone with a full set of taps and dies, or the appropriate lathe gear, and the skills to determine the size/pitch of ur broken ones and run you off some new ones.
    Get some spares made out of the same stock, no doubt you or another OCAU tog will need some eventually, you'd be like, the Aussie supplier for them, lol.
  18. Aziraphale
    Aziraphale Member
    Jan 5, 2002
    550
    Have you tried any fastener specialists like Coventry Fasteners? These guys specialise in all sort of nuts, bolts, screws etc, and there are other suppliers around as well (I just can't think of any others off the top of my head).
    They usually have a shop front you can buy one off orders from.
  19. DoCsIs
    DoCsIs Member
    Jan 30, 2002
    1,492
    You give me this info my dad can probably make them for you for a small price (mech. engineer, tool and die maker, with CNC lathes etc)
  20. Cererus
    Cererus Member
    Jan 14, 2002
    1,536
