High hat stand repair.
Discussion in 'Musicians' started by anark1, Jun 20, 2018.
  1. anark1
    anark1 Member
    Aug 13, 2004
    1,702
    melbourne
    my wifes kits high hat stand is not sitting correct and i suspect the pull down rod is bent.
    worth trying to fix or get new rod?
    stand is Mapex, from the mapex prodigy kit.
  2. Perko
    Perko Member
    Aug 12, 2011
    4,046
    NW Tasmania
    I've juryrigged a few to work for drummers that have damaged them in transit to gigs, if you can disassemble the base of the stand easily it'd be worth a shot to straighten it out. Mapex/TAMA stuff usually works ok, my mate's DW did it when it got dropped out of the van once, and that shit is high tensile or something, because when we went to bend it it snapped.
    Be careful not to bend it next to the bend so that you don't end up with a little kink. She's cooked then.
    Most of the drummers still replaced the rod as soon as they could, a few didn't and never had another issue, it just depends on her use case, cost of replacement etc.
    anark1
    anark1 Member
    Aug 13, 2004
    1,702
    melbourne
    cheers, ill have a look over it again tonight and dissasemble to stand to see what i can do.
  4. Skitza
    Skitza Member
    3,747
    In your street
    Just get a new rod. Can’t say I’ve bent a rod before though so not sure what she did
