High Performance ITX Platform Review-Intel Core i5-655K Air Cooling to 5GHz
Discussion in 'Intel x86 CPUs and chipsets' started by windwithme, Oct 8, 2010.
  1. windwithme
    windwithme Member
    May 11, 2007
    879
    The normal image of ITX platform for users is hard to find in the market, price is high and old generation chipset.
    Even it’s the NoteBook CPU socket or SO-DIMM design to make ITX platform price go even higher.
    Intel launched 32nm Core i3/i5 CPU early this year and also launched H55/H57 chipset at the same time.
    Also, many MB manufacturers launched LGA 1156 ITX MB. The price is lower than past ITX MB.
    New spec ITX MB uses PC spec CPU and DDR3 that makes ITX product be more easy to use and cheaper.
    This review is to introduce the high performance ITX platform with latest products.
    First of all, the CPU is Intel latest unlocked version, K series, Core i5 655K.
    Left side is product manual and right side is 655K CPU.
    The special thing is 655K and 875K don’t bundle original cooler.
    Intel suppose the unlocked version CPU users will choose better performance cooler.
    The clock is 3.2GHz supports Turbo Boost technology. The max speed is 3.46GHz.
    Physical 2 Cores with Hyper-Threading can achieve 4 threads, called 2C/4T.
    32nm manufacturing, L3 Cache is 4MB.
    CPU back design can see the version and different design.
    The built-in GPU clock is 733Mhz.
    MB uses GIGABYTE H55N-USB3
    2oz cooper PCB, USB 3.0, 3X USB Power, and On/Off Charge are advantage features.
    2 X DIMM DDR3 support 800/1066/1333/1600(OC), and maximum capacity is 8GB.
    1 X PCI-E X16 for user to install Low Profile VGA card.
    Realtek ALC892 supports 7.1 channel and High Definition Audio technology.
    24 + 4-PIN power connector.
    4X blue SATAII support by H55. It’s SATA2 and no RAID function.
    IO
    1 X DVI-D
    1 X HDMI
    1 X D-SUB
    2 X USB 2.0(Yellow)
    2 X USB 3.0(Blue)
    1 X eSATA/USB 2.0 combo (Yellow)
    1 X S/PDIF fiber output
    windwithme
    windwithme Member
    May 11, 2007
    879
    USB 3.0 chip is NEC D720200F1
    As per the components and spec, the user price is around 4000NTD, about 127USD.
    Although there are only 3 ITX MB in the market, after comparing, H55N-USB3 C/P value is quite good.
    System Configuration
    CPU: Intel Core i5-655K
    MB: GIGABYTE GA-H55N-USB3
    DRAM: CORSAIR DOMINATOR CMD8GX3M4A1600C8
    VGA: Intel Clarkdale 733MHz
    HD: CORSAIR Force SSD 60GB
    POWER: Thermaltake ElementQ 220W
    Cooler: Intel Cooler
    OS: Windows7 Ultimate 64bit
    Case uses Thermaltake ElementQ for OC real test.
    The product dimension is 130 x 220 x 330 mm
    Left side is built-in 220W SFX PSU and also can install 2x 3.5” devices and 1x 5.25” device.
    ElementQ design is for mute. However if you have system fan, it will be great help for internal heat flow.
    As H55N-USB3 design layout, it causes ElementQ Power/Reset cables are not long enough.
    Although MB and CASE are good C/P products, but you should know such detail before buying.
    Real installation test, it should close the chassis and test how long can run normally under OC condition.
    Performance Test
    CPU 200 X 20 => 4000.4MHz 1.216V
    DRAM DDR3 4GB 1600 CL8 8-8-24 1T
    GPU 733MHz 64MB
    Hyper 4 X PI 32M=> 15m 11.167s
    CPUMARK 99 => 626
    Nuclearus Multi Core => 15752
    Fritz Chess Benchmark => 15.19/7293
    CrystalMark 2004R3 => 198722
    CINEBENCH R11.5
    CPU => 3.36 pts
    CPU(Single Core) => 1.35 pts
    PCMark Vantage => 14672
    655K OC to 4GHz is stable. The full speed temperature is around 70 degree C. The temperature control is also acceptable.
    If the chassis is opened, using the original cooler can OC to 4.3GHz. The full speed temperature is around 90 degree C.
    I personally hope to test OC in chassis to find the balance between stable, temperature and performance.
    After many OC combo test, 4GHz is the most stable condition inside complete close for long time usage.
    Currently, the best tool to enhance the system performance is SSD.
    With CORSAIR FORCE SERIES F40, I hope it can have better performance in this ITX system.
    Size is 2.5” and ID is F60. The highest performance is 285/275 MB/s.
    Random 4K writing performance can reach 50000 IOPS which improve the 4K writing issue in past SSD.
    windwithme
    windwithme Member
    May 11, 2007
    879
    ATTO DISK Benchmark over 16k benchmark result is max read 286.1 Mb/s and write 266.8 MB/s
    EVEREST File Benchmark over 512k benchmark result also above 250 MB/s.
    EVEREST Linear Read Average 235.1 MB/s
    AS SSD Benchmark
    Seq Read - 200.00 MB/s Write - 44.00 MB/s
    4K-64Thrd Read - 102.03 MB/s Write - 56.93 MB/s
    Recently, SSD price is dropping a little and performance is better due to controller chip improvement.
    Some hi-end SSD almost reach the SATA2 300 MB/s bandwidth. I believe the market will be even booming after SATA3 being more popular.
    ITX platform uses CORSAIR F60 can shorten the system boot, open application and access files time.
    Now, I use open air to test the higher OC performance.
    POWER: ANTEC Neo ECO 400C
    Cooler: Mega Shadow Deluxe Edition
    BIOS OC setup
    Tuning CPU ratio, frequency and DRAM multiplier page.
    When pull the high clock, QPI Clock Ratio set at X44 is the best. The performance is also good.
    CPU related technology items
    C1E is for power saving. When CPU utilization rate is low, the CPU will lower the frequency and voltage.
    Turbo Boost is opposite with C1E. When CPU loading is low, you still can pull to higher speed.
    DRAM setup page supports X.M.P. auto OC technology.
    DDR3 parameters setup page
    Voltage page
    Load-Line Calibration
    CPU Vcore 0.50000~1.90000V
    QPI/Vtt Voltage 1.050~1.990V
    GraphicsCore 0.200~1.800V
    PCH Core 0.950~1.500V
    CPU PLL 1.000~2.580V
    DRAM Voltage 1.300~2.600V
    You can see GIGABYTE Micro ATX H55 BIOS items are rich and vary.
    The overall OC ability is also good. I can pull 655K to 200MHz stable easily and don’t need high Vtt.
    Above setup is for 200/1600 stable OC ratio. You may need to minor tuning due to the different components character.
    You can refer to this setup as your need.
    Performance Test
    CPU 200 X 23 => 4600.4MHz 1.376V
    DRAM DDR3 4GB 1600.2 CL8 8-8-24 1T
    GPU 733MHz 64MB
    Hyper 4 X PI 32M=> 13m 46.692s
    CPUMARK 99 => 718
    Nuclearus Multi Core => 18083
    Fritz Chess Benchmark => 17.136/8333
    windwithme
    windwithme Member
    May 11, 2007
    879
    CrystalMark 2004R3 => 217668
    CINEBENCH R11.5
    CPU => 3.83 pts
    CPU(Single Core) => 1.55 pts
    PCMark Vantage => 15924
    After changing to high end CPU cooler, OC to 4.6GHz and pass the benchmark are not big deal. It pull high the performance 10~15%.
    Due to 655K is 2 Cores, the OC range is higher than 4 or 6 Cores CPU. The perivous review of 660/661 also can achieve 4.6GHz.
    Of course, you can see the strength of 32nm manufacture.
    It really help to lower the temperature, power consumption and pull the CPU clock.
    DRAM bandwidth test - DDR3 1600 CL8 8-8-24 1T
    CPU OC 4GHz
    Sandra Memory Bandwidth - 15180 MB/s
    EVEREST Memory Read - 12050 MB/s
    CPU OC 4.6GHz
    Sandra Memory Bandwidth - 15232 MB/s
    EVEREST Memory Read - 12125 MB/s
    You can see the difference between 655K and Core 2 Duo structure by the test result.
    In the past, in LGA 775 platform, the higher CPU clock means higher DRAM bandwidth.
    LGA 1156 built-in Memory Controller in CPU, so the CPU clock doesn’t impact DRAM performance much.
    However this design make LGA 1156 basic DRAM bandwidth is 20~30% higher than LGA 775.
    This is why even yopu pull LGA 775 CPU clock to extremely high, the bandwidth still cannot catch up LGA 1156.
    Temperature
    System standby - 40~41
    CPU Full Speed - 71~73
    Intel Burn Test v2.4,Stress Level Maximum
    The standby temperature is not high and full speed at 73 is also acceptable.
    If you use this cooler, CPU temperature will be higher inside the chassis.
    But it still can long time use under acceptable temperature condition.
    Power Consumption
    CPU 4GHz
    System Standby - 62W
    CPU Full Speed - 100W
    CPU 4.6GHz
    System Standby - 68W
    windwithme
    windwithme Member
    May 11, 2007
    879
    CPU Full Speed - 130W
    No matter OC to 4G or 4.6G, the standby power consumption is lower than 70W.
    The full speed gap is bigger, but the highest is around 130W. It’s very green platform.
    If CPU works at default 3.2GHz, the power consumption will be much lower.
    Finally, pull CPU voltage to 1.488V, 655K air cooling can OC to 5GHz.
    CPUZ Certify
    Intel Core i5 655K OC 5G / windwithme
    Early Jan, I OC Core i5-660/661 CPU to 5GHz and now 655K also can OC to 5GHz.
    And using 655K 5GHz to enter OS, the voltage is lower to 1.488V. You can see Intel CPU yield rate is improved.
    Since Intel launched LGA 1156 in early 2010, 2 Cores CPU started to built-in GPU.
    It becomes a new choice of ITX market, price and performance. CPU combination is more vary.
    There are Core i3-530/540, Core i5-650/660/661/670/655K.
    The price is also more flexible for different budget.
    For MB, early this year DFI launched LANPARTY MI P55-T36, and few months later ECS announced H55H-I and GIGABYTE GA-H55N-USB3.
    These 3 models all break the old barrier and image for this kind of products.
    They all emphasize OC and rich BIOS items. The performance is almost same as Micro ATX or ATX MB.
    No matter NooteBook or Desktop PC all go for smaller form factor.
    Like PC, the normal size is ATX and smaller goes for Micro ATX.
    Now, MB starts to move to ITX, and more MB brands provide the products.
    Also Intel pushes new series Core i3/i5 CPU, 32nm manufacture and built-in GPU technology.
    This year, ITX visibility is higher. I hope ITX products can be more popular and more brands to join this competition.
    The customers can enjoy smaller PC which saves home space and good PC performance. :)
    This article is also posted in my blog: WIND'S 3C
    Welcome 3C fans to drop by.
  6. crag_v
    crag_v Member
    Feb 27, 2002
    1,875
    3091
    Thanks a lot for taking the time and effort to share this with OCAU. I had a quick read earlier today then came back tonight to soak the numbers in properly. I found this thread inspiring! I love little projects based on ITX designs, and it just keeps getting better and better. This board and CPU combination is very affordable and so powerful! Love it. Thanks, Windwithme :)
  7. mrbean_phillip
    mrbean_phillip Member
    Jun 18, 2002
    4,917
    Doreen (3754) Vic
    Great review/test as always, WWM, thank you. Your efforts are appreciated!
    It is just unbelieveable how well that little board overclocks - I have several SFF boards, but they are all for carputer use.
    Would be nice to play with one of these little monsters though, and that clock on air is just insane!
    Keep up the good work, Mate :flowers:
  8. nguyenvandau
    nguyenvandau Member
    Apr 29, 2005
    28
    great shit
    now thats something we wanted to see, not some geek overclock by using liquid nitro what a lame as if all the public got a spare tank laying somewhere and some days came to work with a frozen hand because of misused.
    GREAT OC
  9. Smuffy
    Smuffy Member
    May 4, 2010
    258
    The hole
    was the 5Ghz overclock done on the megashadow cooler?
    that's amazing :weirdo:
  10. AgB deano
    AgB deano Member
    Jan 31, 2009
    912
    Bendigo, Vic.
    And here I was, thinking 5ghz was a typo :shock:
    Very nice work mate, was a good read!
    I agree with moving towards a smaller form factor, I love my mATX rig but I am not quite ready for ITX. I was considering building an ITX gaming rig (I lan a lot :)) but I am not happy with the cases out there, nothing really appeals to me yet.
    Can also only hope that the new sandybridge line clocks half as well, ey.
  11. Glide
    Glide Member
    Aug 22, 2002
    1,151
    Was: Sydney Now: USA
    The other problem when I was looking to build one a couple of years ago, is extracting the heat out, without it sounding like an airport - OK for lans, but not so OK when at home :)
  12. AgB deano
    AgB deano Member
    Jan 31, 2009
    912
    Bendigo, Vic.
    I know what you mean ey.
    Everything out there is either too square or lacks the height for a full sized GFX card or ATX PSU for that matter. You can barely fit in 80mm fans let alone 92mm fans or 120mm fans in a lot of them.
    I think it is entirely possible to have an ITX sized gaming rig but there are simply no cases (or case manufacturers out there) that are building cases for even looking towards this sort of solution.
    If I were to build an ITX gaming system, ideally my case would be the size and shape of a large shoebox. I would be using 120mm fans and a windtunnel design to lower noise and heat while maximising airflow. It would be a damn tight squeeze but you would potentially have a mini beast that could easily fit in a large backpack.
    I plan on making my own case one day just to build a blazing fast ITX rig, unfortunately it requires time and that I have little spare.
