High quality DVDs (eg. 2Fast 2Furious)
Discussion in 'Audio Visual' started by li21, Sep 30, 2007.
  1. li21
    li21 Member
    Dec 23, 2001
    2,602
    Hi all,
    Ive noticed quite a few stores use 2Fast 2 Furious as the instore demo dvd.
    Quite simply, its looks fantastic! I often have to tell myself its not Blueray... but just a normal DVD.
    Got a copy for home just to see if it bring out the best in my cheapo LCD and it does!
    Dont know why.. is this an example of better DVD mastering or something? Some DVDs just dont look that crash hot.
    Star Wars Ep3 looks good, but there arent any realistic scenes that quite compare.
    Are there any other DVDs that can compare for visual quality?
    Can we get a list going here?
  2. silenthunter
    silenthunter Member
    Aug 29, 2002
    2,634
    Amsterdam, Netherlands
    Anything animated, finding nemo is a fav of mine makes a 10yr old CRT look like a 1080p LCD.
  3. AMD64
    AMD64 Member
    Jul 13, 2004
    2,982
    NSW
    As good as a blu-ray / HD-DVD ? I doubt that very much.
    But yes it looks awseome for a DVD.
  4. RyoSaeba
    RyoSaeba Member
    Sep 11, 2001
    12,354
    Or you could just be looking at the HD Generator from LG which a lot of stores use to demo LG TVs. The generator put out 1080p signal equivalent of blueray/HDDVD quality and one of the clips that they use is 2Fast2Furious. We have this at work.
  5. Tony
    Tony New Member
    Jun 26, 2001
    9,988
    Sydney, NSW, Australia
    sounds like an upscaling device
    eg. if i use a computer to play back DVD at VGA 1,280 x 1,024 on one of the big work projectors it looks a lot better than playing back at just 720 x 576 which is the normal DVD resolution
    otherwise troll www.michaeldvd.com.au for the reviews of the best looking DVDs
  6. Infest
    Infest Member
    Aug 26, 2004
    4,692
    Northside, Brisbane
    So if I were to purchase a DVD Upscaler, I would get the best out of my DVDs? Therefore not having to convert to either Blu-Ray or HD?
  7. Andres
    Andres Motor Admin
    Aug 30, 2004
    7,947
    It will not be AS good as a BluRay/HD image as upscaling can't produce new information/resolution.
    Realistically it all depends on your TV/eyes/viewing distance though. Upscaled DVDs looks maybe 5-10% better. (I really can't tell the difference msot of the time unless I'm really paying attention). Bluray howeve is quite easily discerenable, especially with text etc on the screen. This is only on a 720p TV for me. I think on a 1080p tv the difference between Bluray/HDDVD would be even greater.
    However, if you're watching on a small tv (32") at like 3 metres, you probably will struggle to tell the difference at all between any. On a 50" 1080p at 2 metres however, you'll easily see the difference in resolution.
  8. qwijibo
    qwijibo Member
    Apr 22, 2004
    408
    Old Sydney Town
    It depends on how much space they had on the dvd for the actual film vs extras and soundtracks. The more space available, the more bits can be used for the video, and it needs to be compressed less.
    e.g. when they put the movie on a dvd by itself, and extras on another dvd, the movie is generally visually better, because they have more bits for it.
    You can also have varying degrees of quality due to how much effort they spent cleaning up the movie and mastering it before doing the dvd version. A lot of older movies had really quick&dirty conversions and looked so-so.
    Its ages since I bought any dvds, but other ones that have decent visual quality are the 4 disc LOTR versions, The Fifth Element (superbit or 2 disc version), Black Hawk Down (3 disc version)
    Still, dvd can't compare to hd-dvd or blueray - they have so much more bandwidth available.
    li21
    li21 Member
    Dec 23, 2001
    2,602
    How do you get comptuer to upscale DVD image? If I play in say WMP its still normal DVD res right?
  10. AMD64
    AMD64 Member
    Jul 13, 2004
    2,982
    NSW
    You can't generate information from nothing, the reason that upscaled dvd's look better then dvd's run through your tv normally is because the upscaler is doing a better job at upscaling the dvd then your tv would, upscaled dvd's cant touch HD-DVD/Blu-ray with a 10ft pole.
  11. RyoSaeba
    RyoSaeba Member
    Sep 11, 2001
    12,354
    I know. It's not generating info from nothing. It's called a HD Generator. It's just a media player with a HDD in it. It doesn't have a bluray/HDDVD drive so it's not either. It's not upscaling anything since everything on it is already at 1080p. It's a loan unit from LG to be used only on LG tvs.
  12. Tony
    Tony New Member
    Jun 26, 2001
    9,988
    just play back DVD in whatever player you use and output it to the resolution that best suits your VGA device
    eg. 1,366 x 768 on most 720p panels
  13. flu!d
    flu!d Ubuntu Mate 16.04 LTS
    13,073
    Mate,
    I can tell you right now, upscaled DVD, when done using a quality scaler or correctly (in the case of a HTPC) looks pretty damn good....
    ....And when Transformers comes out I will be watching it on upscaled DVD just like all you Blu-ray owners will be.
    It's a little too early to be praising the HD formats just yet.
  14. AMD64
    AMD64 Member
    Jul 13, 2004
    2,982
    NSW
    True it looks good, I watch most my dvd's through a good dvd scaler (PS3). But seriously, unless transformers are pulling some magic stuff to get 1080P on dvd it doesnt hold a light even scaled.
    Examples. *WARNING HUGE FILES*
    http://xylon.haloapplications.com/hddvd/chroniclesofriddick/02/
    http://xylon.haloapplications.com/hddvd/harrypotter/01/
    you get the main idea. Plenty more on there
  15. Burners
    Burners Member
    Oct 3, 2005
    562
    West Perth Ghetto
    Although this particular line of formats has been discontinued because of Blue Ray/HD-DVD developments some of the Superbit DVD's apparently available look damn nice.
    http://en.wikipedia.org/wiki/Superbit
    Though I can't say I ever saw them widely advertised or promoted here in Australia.
  16. TERRA Operative
    TERRA Operative Member
    Jul 8, 2005
    6,925
    Niraikanai
    I have the Superbit versions of The Fifth Element and The Fast and The Furious, and can notice an improvement on my 720P projector. Better black detail and no noticeable macro blocking on high motion scenes, two main drawbacks of MPEG encoding. The Fifth Element encode is generally regarded to be of exceptional quality, among the best as far as DVD goes AFAIK.
    Still looking for that Superbit Crouching Tiger, Hidden Dragon though.
  17. wongsta
    wongsta Member
    Jun 20, 2006
    58
    Victoria, Australia
    Yea i guess if its just the a demo, they would have used up as much as the dvd as they could for the short time period, resulting in a really high bitrate.
  18. Infest
    Infest Member
    Aug 26, 2004
    4,692
    Northside, Brisbane
    Some more DVDs are:
    Alien VS Predator: Definitive Edition
    Alien: Definitive Edition
    Can be had for around $12 at Target or $30 at EzyDVD.
    http://www.ezydvd.com.au/item.zml/794812
  19. Zee
    Zee Member
    Oct 27, 2002
    10,229
    SYD/MNL/SIN/SFO
    Which is why you should never use an animated movie to test a screens capabilities. It's easy to make anything look good with a cartoon - use a movie with lots of details, lots of movement, not to mention colours, blacks etc... Oh, and this is the tough part - get it calibrated first.. Or, at the very least, get it off Dynamic!
    Z...
  20. Impression
    Impression (Banned or Deleted)
    Jan 31, 2006
    2,147
    Sydney, Australia
    I wish the Fifth element came out on DVD :)
