high torque low speed electric motor help
Discussion in 'Electronics & Electrics' started by Salad Fingers, May 31, 2010.
  1. Salad Fingers
    Salad Fingers (Banned or Deleted)
    Jul 21, 2008
    471
    Hey all.
    Mate of mine is designing a mechanical motar and pestal for his final year project at uni. Both he and I suppose, are after some pointers/advice on what motor to use. Initially I though he could flog a motor out of a food prossessor but he'll need all sorts of gearing to reduce the speed and this adds complexity and more chances for parts to fail. I guess were after a bit of a heads up as to whats out there in terms of low speed high torque electric motors. I'm guessing this will restrict us to purely DC??
    Thanks.
  2. LostBenji
    LostBenji Member
    Oct 5, 2007
    6,084
    Up a tower somewhere....
    R/C aircraft use very high torque brushless motors that can be modded and are not badly priced if you shop around.
  3. thrillhouse
    thrillhouse Member
    Mar 3, 2002
    1,825
    sydney sydney sydney
    What sort of movement did you want to achieve? Up and down motion, up and down with some twisting, just rotation of the pestle, etc.
    You could possibly use a high torque servo, or similar.
  4. Jesmol
    Jesmol Member
    Mar 19, 2003
    1,037
    Crafers SA
    How about a seat height adjuster motor. Low speed work drive, capable of lifting pretty heavy weights.
  5. RussellK
    RussellK Member
    Jun 11, 2003
    511
    An easy starting point would be a windscreen wiper motor as it probably already has enough gearing.
    What I'm not sure about, as others have suggested, is the movement required. I'd have though a mortar and pestle would require an eccentric movement in multiple dimensions.
    Salad Fingers
    Jul 21, 2008
    471
    All good suggestions guys. At this stage the idea is to have the pestal move up and down and back and forth while the motar rotates. The windscreen wiper idea would make it easy to implement the pounding and the rotation but not so easy to get the back and forth motion. I think the idea was to only use the one motor but I'll have to ask and find out other wise I reckon we're onto a winner with that suggestion.
  7. RussellK
    RussellK Member
    Jun 11, 2003
    511
    Rather than do the back-and-forth motion of the pestle, you could instead rotate the mortar off-centre and have the pestle fixed and only moving up and down, with the down stroke sychronised so it's down when it's up against the side of the mortar.
  8. LeadAccelerator
    LeadAccelerator Member
    Aug 10, 2008
    837
    This idea sounds a bit like an electric mixer that has the rotating bowl as well as the rotating beaters. ;) ;)
    Salad Fingers
    Jul 21, 2008
    471
    apparently this method is not as efficient as having the pestle move back and forth. so he says anyway.
  10. RussellK
    RussellK Member
    Jun 11, 2003
    511
    Efficient or effective? It strikes me as being a lot easier to implement, with the only critical bit of control being the up-and-down motion, which you'd not only need to synchronise, using some kind of position sensor on the rotating mortar, but also optimise the movement to perhaps prolong or shorten the duration the pestle is in contact.
    Actually, thinking a moment longer, you'd also want the pestle to be able to pivot or rotate, depending on its angle to the mortar, so it caches and crushes the material.
  11. methodMAN
    methodMAN Member
    Jul 8, 2002
    2,590
    God's Own
    high torque and cheap = windscreen wiper motors, some already have gears attached, plastic and metal variations available.
    use a DC motor controller ~$25 off ebay/jaycar for speed control.
    mM
  12. bonox
    bonox Member
    Jul 14, 2001
    3,414
    gearboxes exist for a reason. You'll need one. Only question is whether you want to make it yourself or find one off the shelf.
    Motors don't run slowly. It's a function of their electrical design plus a cooling component.
    A realistic gearbox will outlast everything connected to it as long as you've appropriately sized it for shock loading.
  13. bonox
    bonox Member
    Jul 14, 2001
    3,414
  14. bonox
    bonox Member
    Jul 14, 2001
    3,414
    farnell?
    yellowpages?
  15. the Fan-Man
    the Fan-Man Member
    Jun 16, 2009
    1,596
    Kensington, 2033 Sydney
    go to a scrap yard and you will find electric motors with reduction boxes
    if that helps :S
  16. Goth
    Goth Grumpy Member
    Jun 22, 2002
    9,228
    /dev/null
    Nick the turntable drive motor (quite small, fairly low speed and relatively high torque) out of a microwave oven?
  17. the Fan-Man
    the Fan-Man Member
    Jun 16, 2009
    1,596
    reduction box :)
    yes these are about 9rpm tho
  18. hoopstar
    hoopstar Member
    2,278
    Adelaide..
    Oatley Electronics have a range of powerful DC motors and controllers.. at fairly decent prices too..
    Hoops
  19. TERRA Operative
    TERRA Operative Member
    Jul 8, 2005
    6,925
    Niraikanai
    Damper motors as used for ducted air con will probably work ok. I have two 3Nm rated motors sitting here on my desk which rotate at a tiny bit over 1 RPM (6nM motors are available easily too). The motor inside has an integral gear box and the whole motor/gearbox is about 40mm in dia. and 30mm high. Just supply it with 24V AC to set it spinning around and around and around. Two supply wires and one common, for backwards and forwards directions.
    Salad Fingers
    Jul 21, 2008
    471
    Thanks everyone for all the information- I've passed it on to my mate. He says thanks back.
