Holy Moly GIGABYTE miniITX H55N-USB3 rocking d i5 655K@4.9GHz 3DMARK06 on air cooling
Discussion in 'Intel x86 CPUs and chipsets' started by dinos22, Jun 8, 2010.
  1. dinos22
    dinos22 Member
    May 8, 2004
    12,329
    When news first surfaced of this board i thought...hmmm something i need for the multimedia machine.....i better give it a crack. Next thing you know guys are saying i should overclock it etc so why not :D
    I sat down putting it all together and MSN lights up with youngpro going bananas over the board......i'll let him show off the clocking he did with his Core i7 860 later EEEK
    Suffice to say this little pocket rocket is exactly that. It's dead easy to OC and pushes the new Core i5 655K chip hard. I thought i would crank the voltage and do some 3DMARK06 CPU test runs for a laugh. I started off at 4.2/4.4/4.5/4.6....im thinking wtf this is nuts.......4.7/4.8/4.9 :shock: faints. I left it to finish a 32M Superpi as well...didn't tweak obviously as it was single channel on w7, just wanted to see if its stable with pi too
    Hardware setup:
    • Gigabyte H55N-USB3 mini-ITX (F2 shipping bios)
    • Intel Core i5 655K Unlocked CPU
    • Intel Core i7 875K Unlocked CPU
    • CoolerMaster Hyper 212 Plus CPU Air Cooler
    • Corsair GTX2 Dominator (had clearance issues so just used one stick)
    • WD 600GB SATA3 VelociRaptor
    • MSI HAWK 5770 PCIe Graphics Card
    • Corsair HX620 PSU
    • Windows 7 32bit
    5247MHz validation on air EEEEEK
    http://valid.canardpc.com/show_oc.php?id=1232075
    4.9GHz 3DMARK06
    4.6GHz prime for a couple of hours eek
    Core i7 875K Unlocked CPU results
    PRIME at 3 hour mark
    3DMARK06 at 4.1GHz :D
    32M SuperPi at 4.4Ghz
    [​IMG][​IMG]
    [​IMG].[​IMG].[​IMG].[​IMG].[​IMG].[​IMG]
    [​IMG].
    BIOS SCREENS
  2. dead_man
    dead_man Member
    Feb 2, 2005
    1,676
    melbourne
    fffffffffffffffffffffff
    if only my H55M-UD2L overclocked like that :(
    good job man
  3. Archy
    Archy New Member
    Jan 23, 2010
    1,312
    Glenhaven, Sydney
    I'd love to see what's prime stable. That's awesome, though. I don't know how it's using that cooling, but that's pretty bloody lucky. Got any pics of the board with the cooler and both fans on there?
    dinos22
    dinos22 Member
    May 8, 2004
    12,329
    i didnt want to do prime because i thought you cant use this cooler in a small case anyways
    i am using only one fan
    if you like i can do some prime just for kicks later when i get a chance
  5. tuchan
    tuchan Member
    Aug 23, 2006
    615
    That is wild indeed:thumbup::D
    Now I just want to see a big pot dwarf that board:lol::leet:
  6. core2dubious
    core2dubious Member
    Jul 19, 2006
    676
    Nice overclocks Dinos, I would like to see the board with some mosfet cooling for 24/7 overclocks. I would've have waited for this board if I knew it was coming out but already purchased a ECS H55 min itx motherboard...:lol:
  7. fatguy1992
    fatguy1992 Member
    Feb 15, 2009
    2,152
    Thats awesome, any chance of some sub zero tests? Even under SS or something?
  8. ir0nhide
    ir0nhide Member
    Oct 24, 2003
    4,191
    Epic micro gaming pc anyone? :wired:
    dinos22
    dinos22 Member
    May 8, 2004
    12,329
    hahah i am actually priming now just for kicks
    started at 4.4.........running at 4.6GHz 1.41v at the moment and still going :leet:
  10. Archy
    Archy New Member
    Jan 23, 2010
    1,312
    Glenhaven, Sydney
    lol. That's still a lot of volts, though. What sort of temps does that entail?
    dinos22
    dinos22 Member
    May 8, 2004
    12,329
    I've started priming about 2.5 hours ago with 4.4GHz bumped it to 4.5 at hour mark and 4.6GHz at 1.5hour mark
    I just bumped it to 4.7GHz and it's still going :cool:
  12. Archy
    Archy New Member
    Jan 23, 2010
    1,312
    Glenhaven, Sydney
    With an inch of thermal headroom to boot. Damn these chips look good. I'd love to see what the i7 can do. :D
    Godd luck.
  13. koma_white
    koma_white Member
    Jun 3, 2002
    2,442
    LDN.UK
    What sort of temps are the mosfets running at?
    Has Gigabyte specified a TDP limit?
    dinos22
    dinos22 Member
    May 8, 2004
    12,329
    i couldnt measure the temps as it was too narrow a place to stick a probe and i stopped priming now
    i'll try mount one when i put an i7 CPU in there for testing
    TDP limit i dont know mate but it supports the i7 CPUs
  15. Archy
    Archy New Member
    Jan 23, 2010
    1,312
    Glenhaven, Sydney
    What sort of i7? The K? Because I've heard the unlocked i7s aren't any better than the 860s, whereas the i5-655k go a lot further than their locked counterparts.
    dinos22
    dinos22 Member
    May 8, 2004
    12,329
    i have 870s and 875K
  17. gregzeng
    gregzeng Member
    Apr 25, 2002
    1,103
    ACT
    In-ear infra-red thermometers work ok
    Bought the cheapest on eBay (ex Hongkong). Useful for everything. HHD, IN & OUT FANS, GPU, MEMORY, CPU, etc.
    In winter, ceiling is 3 degrees warmer than floor, easy to detect outside air temperature leaks. On my netbooks & notebooks, the effectiveness of the fan or fanless coolers. Easily obtained AA batteries last a very long time.
    dinos22
    dinos22 Member
    May 8, 2004
    12,329
    i was pushing this MSI Hawk 5770 last night....really nice little card and doesnt clock too bad on air cooling either
    here are the max clocks i could get out of the setup
    dinos22
    dinos22 Member
    May 8, 2004
    12,329
    dinos22
    dinos22 Member
    May 8, 2004
    12,329
