Home made soft box
Discussion in 'The Gallery' started by sealish, Sep 8, 2007.
  1. sealish
    sealish Member
    Jun 7, 2005
    510
    Melbourne's Wild West
    I had a bit of time on my hands this morning, and a few bits and pieces lying around, so I finally built my own soft box after seeing so many around the net.
    Now what in the hell do I take shots of!? :confused:
    A shot of the screw driver used to replace one of the halogen globes
    The obligatory lens shot
    The EOS300 with the 20mm
    Lemons, not limes - they just aren't ripe
    My "studio" - where the magic happens (note: EOS 300 with cord to laptop :confused: )
  2. tin
    tin Member
    Jul 31, 2001
    6,416
    Narrabri NSW
    Oh, you could have gotten so much more creative...
    Should have taken photos of "the materials you'll need to make one". Started off well, but I don't think the lemons are needed :p
    Edit: Also, what did you use? Looks a bit like a cardboard box in the last photo. I may have a need to have something like this soon, only possibly somewhat bigger.
    sealish
    sealish Member
    Jun 7, 2005
    510
    You can't make one of these without lemons! What would your tequila mix with?
    Here's the basic model I used for mine: http://strobist.blogspot.com/2006/07/how-to-diy-10-macro-photo-studio.html
    There's some other designs out there that look a little nicer, but since I had cardboard boxes, white poster paper and my garage halogens already sitting there I followed that model.
    http://www.google.com/search?source=ig&hl=en&q=diy+softbox&btnG=Google+Search
    Here's a couple more from this afternoon, my housemate's traditional, Saturday, hangover fare was running late today and I managed to steal it for a whole minute for a shot before he took it back:
    A model car my son left here:
  4. cgheaven
    cgheaven (Banned or Deleted)
    Jan 23, 2007
    522
    S.E
    Crazy, How would I go about building one of these?
    EDIT (ow I see the link there)
  5. Croc
    Croc Member
    Feb 9, 2002
    1,361
    Moon
    bloody fantastic !!!
    sealish
    sealish Member
    Jun 7, 2005
    510
    Thanks guys, and one final update before I find something worth shooting with it.
    My two guns:
  7. Pilum
    Pilum Member
    Aug 29, 2004
    164
    Adelaide, SA
    Nice results!
  8. Arch-Angel
    Arch-Angel Member
    Sep 6, 2005
    6,912
    Wow, they're probably some of the best lightbox shots I've seen for a good while, which is particularly good because its a ghetto setup! :leet:
    Only comment I might make would be to consider a direct front light also. The lens shot demonstrates this the best - little dark in the centre.
    (These are just nitpicking comments though, on the whole it is very well done)
  9. Iscran
    Iscran Member
    Nov 17, 2006
    635
    World Traveller
    Very nice results. Time for some abstract lightbox art. :thumbup:
  10. Kataton1c
    Kataton1c Member
    May 1, 2002
    1,466
    What lights / globes are you using?
    I believe I have the same lights bought from Bunnings, but didn't know which globes to put in them. Obviously need the white ones, the normal ones produce the typical Yellow.
  11. Dinuc
    Dinuc Member
    Jun 2, 2002
    4,428
    Nope, use those ones. Do a custom white balance first.
    Dna
    sealish
    sealish Member
    Jun 7, 2005
    510
    Exactly what Dinuc said. They are Bunnings cheapy halogens that throw a lot of hot, yellow light. A quick snap and custom white balance is set and everything looks very white.
    Some front fill is a very good idea, might throw the stofen on the 580 and dial it down a couple of notches - see how that does. I need more nice things to photograph in it though - First time in my adult life I've said it, but; "I need a vase." :D
  13. xhanatos
    xhanatos Member
    Mar 5, 2004
    6,040
    :thumbdn: to the vase. borrow your son's toys :lol:
  14. Kataton1c
    Kataton1c Member
    May 1, 2002
    1,466
    :O
    I was under the impression I'd need new globes etc.
    I'm starting out, great tip and saved me plenty of money.
  15. Julz
    Julz Member
    Jul 4, 2001
    2,709
    Melbourne, Victoria
    i just made myself a similar soft box with a box from some logitech computer speakers - perfect size.
    Didn't use hot lights for my first few shots, used a crappy fluro desk lamp which is quite dark due to its age. Haven't got a wireless flash trigger either or an off shoe cord so i had to play with the angles of my top mounted flash.
    Quite happy i made one as i sell a few things on ebay and this will be perfect for product shots. Should wire in some white CCFL's to the inside (or outside) of the box to remove the need for hot lights. I've also just used computer banner paper, a bit thick but i couldnt find the tracing paper.
