Home Theatre PC build questions
Discussion in 'HTPC' started by RhysG, Jun 21, 2010.
  1. RhysG
    RhysG Member
    Sep 24, 2005
    1,010
    Hi all, I am looking at building a home theatre PC but am unsure of certain components - whether or not they'll be overkill or not etc. If anyone could take a look at these spec's and give me some advice it'd be greatly appreciated.
    Asus ATI Radeon HD5450 Silent 1GB Low Profile
    Logitech DiNovo Mini Palm Sized Keyboard
    Patriot PC3-10600 2x2GB DDR3 PSD34G1333KH
    Lian Li PC-C37B Black
    AMD Athlon II X2 245
    Gigabyte GA-880GMA-UD2H Micro ATX Motherboard
    Comes to about $800 all up, delivered from PC Case Gear which seems pretty expensive... it would be an easy decision if it was around $500. I don't know if it's worth it because I already have a WDTV (not Live) but am really keen to make full use of my Windows Home Server as a media server rather than having to ferry my media around on USB. Also easier to access my collection digitally than leafing through DVD wallets/browsing the server from a client and transferring to USB.
    Thanks, Rhys.
    P.S. I thought this would be better off in the AV forum than What/Where to Buy because it is pretty topical.
    RhysG
    RhysG Member
    Sep 24, 2005
    1,010
    ASUS AT3IONT-I Deluxe Motherboard
    SilverStone SG06 Black Cube Mini-ITX Case
    Or I could go with an ITX system but it doesn't work out that much cheaper and would the onboard VGA be enough for flawless HD playback?
  3. Namheul
    Namheul Member
    Aug 18, 2003
    1,701
    Victoria
    The ION motherboard will display HD videos no problem, as will the 880G motherboard in your first post.
    Neither will need a discrete video card.
    Your decision will depend on whether you need more CPU power (the microATX choice) or whether you just want to watch videos (Atom choice).
    RhysG
    RhysG Member
    Sep 24, 2005
    1,010
    I'll just be watching videos, what sort of application did you have in mind for the increased CPU power?
  5. Namheul
    Namheul Member
    Aug 18, 2003
    1,701
    Victoria
    Well, i recently built a little PC. I used:
    Intel i3-530
    Intel DH57JG motherboard (ITX)
    2 x 2GB DDR3
    I went with these specs as im a programmer/web developer, and do some video encoding too. The more powerful CPU helps with this.
    If its purely for watching videos and internet browsing, the Atom/ION combination will be perfect.
    RhysG
    RhysG Member
    Sep 24, 2005
    1,010
    Sweet, well I've been trying to shave the price a little and was wondering whether 2GB would be enough for seamless HD playback?
    Antec ISK310-150 Mini-ITX Case
    Corsair VS2GB1333D3 2GB (1x2GB) DDR3
    ASUS AT3IONT-I MiniITX ION Motherboard
    These components bring the price down to the mid $500's.
    RhysG
    RhysG Member
    Sep 24, 2005
    1,010
    Just wondering which OS is in vogue for HTPC at the moment? Not very good with Linux so looking for Windows and 3rd party software combo.
  8. nathanblogs
    nathanblogs Member
    Mar 31, 2005
    3,079
    windows + xbmc, 2gb is plenty.
    I would just get the cheapest cpu + mobo + ram ( search the for sale forum ) you can find and put it with a gt210/220 or hd 5450 and use dxva2 which will play any 1080p easily.
    Also consider sound when making a htpc, make sure its quiet.
    I use a E6350, 4gb ram ( used to be 1gb ), some gigabyte board I had lying around and a hd 5450.
    1080p uses ~5% of the cpu.
  9. Namheul
    Namheul Member
    Aug 18, 2003
    1,701
    Victoria
    That is a nice case. Nice and small too. You will need a laptop optical drive though (if you want an optical drive at all). 2GB should be fine.
    Windows 7 Media Center is perfect for a HTPC. I use it with the "Media Browser" plugin and it works great. Allow room in your budget for a Remote too.
  10. Omnomnom
    Omnomnom Member
    Oct 7, 2009
    278
    Windows 7 + XBMC is brilliant, it is currently the setup I use.
  11. mr_mordred2095
    mr_mordred2095 Member
    Mar 9, 2004
    3,904
    What about tuners? BD ROM? Antennas for tuners? HDD?
    RhysG
    RhysG Member
    Sep 24, 2005
    1,010
    BDROM is going to come a while down the track but not right now. Tuner I probably won't need because I have Foxtel IQ2 and don't see the need to record much TV at the moment or watch it live through the HTPC.
    RhysG
    RhysG Member
    Sep 24, 2005
    1,010
    I have heard great things about XMBC, I have a spare Windows 7 x86 so I will use that. I think I'll try and save money on the RAM via the FS/WTB forums but I doubt the other stuff will show up. I have budgeted for a Logitech DiNovo Mini which I want to use in place of the usual remote and keyboard/mouse. It looks the goods.
    RhysG
    RhysG Member
    Sep 24, 2005
    1,010
    OK, the current quote:
  15. banshee
    banshee Member
    Sep 8, 2001
    1,771
    Springwood, West of Hell (Sydney, actually)
    I use the greater CPU, mainly because I record shows & don't watch them all straight away, so use MCE Buddy to shrink them down overnight, if I have not watched them within a week...
  16. stevo4
    stevo4 Member
    10,631
    And is terrible to type on.
    Definitely a coffee table remote.
    RhysG
    RhysG Member
    Sep 24, 2005
    1,010
    Well I'm not writing my magnum opus on the thing... just need to quickly type in search strings etc. Also like the mouse/directional pad included.
  18. stevo4
    stevo4 Member
    10,631
    Painfully slow, just to do that.
    Till you use one.
    Also slow, and imprecise.
  19. Doso
    Doso Member
    Jul 16, 2002
    6,081
    [Vic]Melbourne
    I found my dinovo mini to be acceptable, but I manly use a universal remote (logitech 525) for navigation in windows 7 media center
  20. Dropbear
    Dropbear Member
    9,720
    XBMC has a couple of major drawbacks
    1. No support for tuners - so you won't get any PVR functionality
    2. It runs in a tight loop - not event driven so the CPU will be basically running ALL the time -whether you're doing anything or not ..
    IMO Windows Media Centre + Media Browser is a better solution.
