How do fix broken nbn fibre cable?
Discussion in 'Networking, Telephony & Internet' started by slashnet, Apr 9, 2022.
Thread Status:
Not open for further replies.
  1. slashnet
    slashnet Member
    Apr 6, 2002
    253
    Hi all,
    My nbn connection recently switched to mobile data and after a bit.of diagnostics I realised the fibre cable that plugs into the modem is broken.
    I am pretty sure a mouse has gotten to it.
    I have only worked with ethernet cables in the past, so fibre is new to be.
    What connector and tools do I need to buy to get this going again?
    Here is a photo.
    Thanks
  2. caspian
    caspian Member
    Mar 11, 2002
    13,147
    you report it your ISP and they will get NBN to fix it.
    PULS8R, Rass and Pugs like this.
  3. Rass
    Rass Member
    3,285
    Brizbekistan
    What Caspian said. That side of the NBN boxen is the responsibility of the telco / nbn and it's a really bad idea to mess with it (fibre is fun to terminate, you generally need expensive tools and expertise to deal with it).
    Pugs likes this.
    slashnet
    slashnet Member
    Apr 6, 2002
    253
    It's inside the house so thought it would be my problem to fix, would there be a charge to fix it?
    If they didn't make such a big hole a mouse wouldn't have got through.
    Had a look through ebay and you can get cheap termination tools.
  5. Elmf
    Elmf Member
    Jan 6, 2007
    5,691
    Is this another one of those threads where the answer to your question is in the first two posts then you avoid the advice and do your own thing anyway?
    Please reconsider, as my head might explode.
    PULS8R, supasaiyan and Pugs like this.
  6. ernie
    ernie Member
    Dec 2, 2002
    17,973
    Don't attempt to fix it yourself, it's not your property.
    Report it to NBN via your ISP. They will come out in a day or so usually.
    - Ernie.
    Pugs likes this.
  7. spankyofoz
    spankyofoz Member
    Jul 29, 2001
    3,455
    Fuck these sensible folk.
    What you need is:
    700ml Jim Beam
    Roll of duct tape
    A steady hand
    Method:
    Drink the Beam to remove autonomic trembles that may naturally be present. Carefully align the broken fibre to the terminal and tape into place. Be careful as you will need to be micrometre accurate or it may not work.
    Or you know, lodge a fault with the NBN if you are a coward and want to wait a whole few days for them to fix it, while you regret your ineptitude
    Zippy7 and disco frank like this.
  8. Snoops
    Snoops Member
    Jan 17, 2004
    1,991
    Oh FFS.. Lets be at least reasonable here... He needs to start with Chivas Regal.
    bcann, disco frank and Pugs like this.
  9. Pugs
    Pugs Member
    Jan 20, 2008
    9,767
    Darwin, NT
    Once the cable is fixed Use some expanding foam or clear sealent to fill the hole
  10. TheWedgie
    TheWedgie Insert Custom Title Here
    Jun 16, 2002
    3,393
    This.
    Thread Closed.
    Pugs likes this.
Thread Status:
