How do I calibrate my screens in Eyefinity?
Discussion in 'Video Cards & Monitors' started by Omarko, Mar 12, 2010.
  1. Omarko
    Omarko Member
    Nov 25, 2004
    4,129
    Kellyville
    hi guys
    first of all, I am a total noob when it comes to calibrating monitors.
    I just got myself 3 new Dell 2408wfp screens and I am using them with my 5870 in Eyefinity...
    thing is, that there is slight color differences between them and I am not sure how to calibrate them to make them look same.
    especially because windows sees the individual screens as one screen so I asusme it applies one setting to all three.
    any thoughts ?
    also, is it worth getting a device like this one - LINK ???
    thanks in advance ...
  2. warcraft
    warcraft Member
    Dec 20, 2006
    937
    SA
  3. CQGLHyperion
    CQGLHyperion Member
    Feb 3, 2003
    1,372
    North Rockhampton
    Tried the inbuilt monitor presets?
    Otherwise you will have to muck aroudn with the settings yourself I guess.
    Omarko
    Omarko Member
    Nov 25, 2004
    4,129
    Kellyville
    the Spyder3 Pro wont work even though it can calibrate multiple monitors, it can not calibrate eyefinity setup where windows sees the screen as one giant screen, not as 3 separate screens.
    any other thoughts?
  5. Vladdo
    Vladdo Member
    Apr 12, 2005
    8,498
    Laverton, Melbourne
    You can't as yet.. however, i do believe that 10.3 drivers will fix this issue..
    Omarko
    Omarko Member
    Nov 25, 2004
    4,129
    Kellyville
    how ? :) ....
    as in , should I still get the Spyder3 calibrator and the new drivers ill support individual monitor calibration ?
  7. FatBoyNotSoSlim
    FatBoyNotSoSlim Member
    Sep 9, 2002
    14,066
    Melbourne - 3174
    Couldn't you do it the old fashioned way, and get a colour/gradient chart, fullscreen it on each monitor, and use the monitor controls to tweak them all to look the same?
  8. Vladdo
    Vladdo Member
    Apr 12, 2005
    8,498
    Laverton, Melbourne
    http://www.anandtech.com/video/showdoc.aspx?i=3743&p=4
    It looks like you can config CCC to adjust settings etc, but i don't know if it allows you to load a colour profile for each monitor.
    atm, on my 3 x 24 display, i use my spyder2 pro (you need the pro version otherwise you can only do 1 display, not 3), and it allows me to load a profile for each screen. But, as you say, eyefinity generates 1 massive screen. Only time will tell if it supports individual monitor profiles.
  9. cvidler
    cvidler Member
    11,682
    Why use EyeFinity and not just extended desktop?
    Current solutions will work with extended desktop just fine. (I use a Huey)
  10. Vladdo
    Vladdo Member
    Apr 12, 2005
    8,498
    Laverton, Melbourne
    You can't use extended desktop in games.
    Omarko
    Omarko Member
    Nov 25, 2004
    4,129
    Kellyville
    thanks Vladdo ...
  12. warcraft
    warcraft Member
    Dec 20, 2006
    937
    SA
    Hmm well that sucks , I was thinking you could just match calibrate each monitor so they look the same , thats what I was going to do with my spyder 3 pro sitting in a box next to me ,Ill give it a try when I get my eyefinity set up going , just need a card ;(
    anyway that spyder 3 pro is at a good price :)
  13. r3s
    r3s Member
    Feb 9, 2005
    6,735
    logan ( 4133 )
    can't you use extended desktop to calibrate the screens then change to eyefinity? :confused:
    Omarko
    Omarko Member
    Nov 25, 2004
    4,129
    Kellyville
    well once you change them into eyefinity it will only use one profile, not separate 3 profiles ...
  15. r3s
    r3s Member
    Feb 9, 2005
    6,735
    logan ( 4133 )
    I thought you changed the settings through the screens own OSD's to get them to match, my bad.
    Omarko
    Omarko Member
    Nov 25, 2004
    4,129
    Kellyville
    I have been fiddling with the screen settings (using the screen buttons) all night yesterday and I think I made it worse so I ended up resetting everything back to stock.
    I really hope that the 10.3 catalyst will offer separate display color profiles so I can then just get the spyder3 pro machine to do all the work.
  17. Alba
    Alba Member
    Jan 2, 2002
    4,754
    Shellharbour
    :lol: I did the same thing, spent bloody ages trying to get the colours right and made it worse, so reset and tried again. I think I have it pretty close now just using the OSD and not CCC.
    Omarko
    Omarko Member
    Nov 25, 2004
    4,129
    Kellyville
    ended up ordering one of the Spyder3 pro tools ...
  19. warcraft
    warcraft Member
    Dec 20, 2006
    937
    SA
    Sweeet , can you post what you learn , then I can get mine out the box :D
    Omarko
    Omarko Member
    Nov 25, 2004
    4,129
    Kellyville
    yeah absolutely, will post results / experiences when I get it ...
