How do you clean out watercooling tubing?
Discussion in 'Extreme and Water Cooling' started by iCrunk, Jul 5, 2007.
  1. iCrunk
    iCrunk Member
    Apr 17, 2006
    702
    Melb SE
    After a few months use of my watercooling kit, it has developed some white cloudy layer on the inside of the tubing... How do i go about clean it ?
    Would i be able to dip it in bleach?
  2. DeNs
    DeNs Member
    Feb 22, 2003
    1,967
    I found the easiest way to clean it was to dunk all the tubes in hot water, then use a rag on a stick (ha-HA!) dragged through the tube to clean it out. Repeat if necessary.
    Seriously though I did use a rag on a stick. Was a bit of cloth threaded through the end of a gun cleaning thingy :)
    ---dens
  3. Turorit
    Turorit Member
    Sep 26, 2006
    202
    Adelaide, South Aust.
    I used a brush thing (looks like a bottle brush/toilet brush) attached to a plastic line. I don't know the technical name for it :p You can buy these things from any aquarium shop, as they are used for cleaning the tubes on canister filters etc for fishtanks.
    Stuff the line through the tube, then pull it from the other end. Do that a few times and everything is clean :D
  4. OCMunkee
    OCMunkee Member
    Jun 28, 2004
    1,340
    Melbourne, VIC
    I believe they're called.... pipe-cleaners? :lol:
    Nathan
    iCrunk
    iCrunk Member
    Apr 17, 2006
    702
    Melb SE
    Thanks for the replies:thumbup:
    I'll give the 'rag on a stick' method a go :lol:
  6. spikes
    spikes Member
    Jul 24, 2006
    1,731
    try a sponge cut to internal tubing size on a stick
  7. Turorit
    Turorit Member
    Sep 26, 2006
    202
    Yeh, pipe-cleaner sounds about right :D
  8. ben_qld
    ben_qld Member
    Apr 19, 2002
    1,533
    if you have used distilled water, with proper corrosion inhibitor, then you should never need to clean the pipes at all
    Ben
  9. Goth
    Goth Grumpy Member
    Jun 22, 2002
    9,228
    /dev/null
    Ah wash mahself with a rag on a stick!
    I use a piece of cotton wool, apply isopropanol or whatever mild cleaning solvent i have sitting around, and use a long thin dowel to push it through the tubing. It needs to be fairly tight so it swabs all the crap off effectively.
  10. Twrecks
    Twrecks Member
    Dec 9, 2004
    1,043
    Somewhere in time...
    Nah, pipecleaners are about 150cm long and used for cleaning tobacco pipes.
    You get them from a tobacconist.;)
  11. javascripterror
    javascripterror Member
    Mar 8, 2002
    3,169
    NSW
    Soak the tubing in vinegar for a few hours then use the "rag on a string" and pull it through the tubing. Rinse and repeat if necessary.
  12. dinos22
    dinos22 Member
    May 8, 2004
    12,329
    clouding after only 2 months :confused:
    what setup are you using and what liquid have you got in there
  13. Frag_Lord
    Frag_Lord Member
    Nov 23, 2004
    1,264
    Replacing tubing is easier, than the hastle of cleaning it all.
  14. DavLe.BeRRy
    DavLe.BeRRy Member
    Jun 11, 2006
    1,989
    Perth, WA
    Agreed, you have to remove all your tubes to clean em anyway and it will save you the time and trouble... unless of course u don't have ~$10 to spare :lol:
    Get some better coolant too. :Paranoid:
    iCrunk
    iCrunk Member
    Apr 17, 2006
    702
    Melb SE
    setup now on my sig, using the swiftech hydrx coolant with distilled water
  16. Frag_Lord
    Frag_Lord Member
    Nov 23, 2004
    1,264
    Their's the problem. Hydrx tends to cloud up tubing really badly.
    Get some different kind of coolant, im using Nulon Ultracool mixed with distilled.
    iCrunk
    iCrunk Member
    Apr 17, 2006
    702
    Melb SE
    I actually have that in the garage, how well does it glow? (want it to look pretty) :lol:
  18. Kaine[zof]
    Kaine[zof] Member
    Mar 22, 2004
    2,176
    the green stuff is widely known to glow well, i use Nulon Red which also glows brilliantly under UV. Enjoy :thumbup:
    iCrunk
    iCrunk Member
    Apr 17, 2006
    702
    Melb SE
    I think i might grab some of the red stuff.
    http://www.nulon.com.au/products.php?productGroup=cooling
    It looks a bit pinkish on the website... is it actually red or pink?
    Anyone know where i can get some blue car coolant? :D
  20. Kaine[zof]
    Kaine[zof] Member
    Mar 22, 2004
    2,176
    i used the Top-Up stuff, diluted until i got the red i wanted. It's actually a lot richer color than it appears there. See my PCDB pics to see how it looks. The UV glow shot didn't come out so well, you'll just have to take my word that it glows a really nice red.
