How much power does a dremel use.
Discussion in 'Electronics & Electrics' started by xc351, Oct 31, 2018.
  1. xc351
    xc351 Member
    Dec 30, 2005
    2,297
    I’ve checked the dremel website no power levels.
    I’ve got to dremel some holes in the dash and solder up some connections and cause I can’t be bothered to run an extension cord out one at to use a can sized inverter rated to 150w/300w peak. My soldering iron is 15-40w so that’s easy. Pretty sure a dremel should be under 150w just making sure really.
    As a bonus can just leave stuff in car instead of packing it up.
  2. holdennutta
    holdennutta Member
    Apr 14, 2002
    7,250
    I think the beefiest of the dremels is rated at about 170 or 180W.
    xc351
    xc351 Member
    Dec 30, 2005
    2,297
    Yea bit more research bunnings has a 130w model and a generic 170w model. So I should be good long as I don’t push it to hard. Just
