HP n40L power on / off
Discussion in 'HTPC' started by b-man, Jan 1, 2017.
  1. b-man
    b-man Member
    Mar 1, 2009
    134
    Im trying to get my HTPC so its easy to power on and off.
    i tried to set it up ages ago but didnt have much luck so i used to run the HTPC 24/7 so never really bothered with it.
    now im looking to be able to easily power on and off the HTPC again
    i tried setting wake on lan but the HTPC would just turn on a minute or so after i turned it off.
    is there some sort of wake on usb where my usb infrared sensor can pickup a command from the harmony remote and turn it on? or os any remote button going to turn it on?
    and ideally wake on lan for when i want to use it as a server
    Power off...
    to turn it off - i can do it with the remote if im in front of it but since its a server aswell i would like to turn it off if im not there
    i currently log in via remote desktop and run a shutdown.cmd i have made.
    is there any easier way?
    is there a way to cancel shutdown if i want?
    b-man
    b-man Member
    Mar 1, 2009
    134
    ok so i finally got WOL to work without turning back on again every 5 minutes. I don't know if it was the bios update or reinstall of lan driver and setting it up again.
    i have have a WOL widget on my phone that can turn it on great. (Android App: Wake on Lan)
    i can also access the WOL through my router to turn it on when i am not at home.
    and also have a shutdown app on the phone. but it does require installing something on your pc (Android App: Shutdown Start Remote)
    it would be nice to turn it on somehow with my harmony 650 but unsure how.
  3. cheddo7
    cheddo7 Member
    Dec 19, 2004
    481
    For Windows use this, just make sure USB/keyboard wake from sleep is enabled from Bios:
    http://slicksolutions.eu
    Been using this for years, does it without any setup for my Win10 HTPC, using MS remote control off button to sleep/wake.
