HP Proliant Generation 8 Microserver Club
Discussion in 'Storage & Backup' started by ktmrida, Jul 18, 2013.
  1. stiben
    stiben Member
    Aug 5, 2001
    524
    The G8 does have an internal USB port, I'm booting ESXi 5.5 from that.
    When boot order is set to USB first, the BIOS has a second setting for whether to boot from internal or external USB.
  2. fido666
    fido666 Member
    Jan 5, 2008
    572
    OK thanks but is it a commonly available one?
    So I take it all the people with non-standard cards are running a hardware raid mode that the onboard doesn't support?
    Thanks for confirming. I have since located the online manuals which do show all the slots, etc.
    http://h20628.www2.hp.com/km-ext/kmcsdirect/emr_na-c03787037-4.pdf
  3. DaveQB
    DaveQB Member
    Apr 30, 2002
    2,695
    Narellan, Sydney
    ebay? I was watching that. I had my mouse hovering over the buy button...
  4. Sarquiss
    Sarquiss Member
    Jan 2, 2006
    573
    Yup :p. I have another ML310e Gen8 server which I will be setting up as the primary ESXi server so not entirely sure what to do with the Microserver just yet..
  5. DaveQB
    DaveQB Member
    Apr 30, 2002
    2,695
    Narellan, Sydney
    You could give it to me :thumbup: ;)
  6. fido666
    fido666 Member
    Jan 5, 2008
    572
    G8 Noob alert here :o
    I have just received my G8 1610T today and of course the first thing I did was rip off the cover to look at the innards. I can see the molex cable coiled up under the ODD bay but it appears to be plugged into another molex (splitter perhaps). Is there another or do I have to slot a piggy back plug between the 2 existing connections?
    I do know about the HP cable linked in the 1st post but looks like it's hard to source.
    Alternatively, will this floppy to SATA adapter work?
    http://www.ebay.com.au/itm/SATA-15-...47?pt=LH_DefaultDomain_15&hash=item540f6001e7
    Actually, I think it needs to be this one but the postage is a killer :-
    http://www.ebay.com.au/itm/4-pin-Fl...708?pt=LH_DefaultDomain_0&hash=item462850731c
  7. fido666
    fido666 Member
    Jan 5, 2008
    572
    I have searched and searched but am unable to locate a molex to SATA adapter that has a piggy back plug on the molex end. I've also searched for a floppy to SATA adapter but can only find ones with female ends, the G8 needs a male ended cable to connect to the supplied HP cable in the ODD bay. I did find some male ended ones on eBay but postage alone was nearly $20.
    Short of stumping up $20 odd dollars for the HP cable or an eBay sourced alternative does anyone have a local source at a reasonable price?
  8. DaveQB
    DaveQB Member
    Apr 30, 2002
    2,695
    Narellan, Sydney
    I am pretty sure I bought from ebay for this and it wasn't that expensive. I'll have to check what I have when I get home.
  9. fido666
    fido666 Member
    Jan 5, 2008
    572
  10. fido666
    fido666 Member
    Jan 5, 2008
    572
  11. the_fuzz
    the_fuzz Member
    Sep 6, 2004
    9,806
    Just started setting mine up and there is alot of FUD out there,
    Can anyone confirm if you can use a SSD in the ODD slot as a OS boot drive whilst also having the other 4 drives working in AHCI mode?
    From what I can see you have to use the onboard raid controller if wanting to boot from the ODD?
  12. Tronador
    Tronador Member
    Jun 3, 2015
    534
    I just bought one as well, waiting for it to get delivered.
    I was going to run it was ESXi with pfsense and Xpenology.
    ...I used to have an account on here, not sure what happened to it :(
  13. JasonBM
    JasonBM Member
    Apr 30, 2012
    51
    Get the modded BIOS installed and you can do exactly that.
  14. screwball
    screwball Member
    Feb 9, 2002
    422
    Gold Coast
    I have finally setup mine at home after upgrading from the N54L
    Bought the G2020T Model with and put in 16GB of EEC Ram so it is a similar setup to the remote location servers we currently install for work.
    Anyone know what to do with multiple EEC 2GB Modules (HP branded?) I have quite a few now left over as we have around 10 of these unit out in the field.
    Anyway for my home setup at the moment
    ESXi 6.0 (HP ISO) on Flash Drive
    Sophos UTM (Home Edition)
    Windows 2012 R2
    Open Media Vault
    Windows 10
    Just installed that Windows 10 to see some of the features. It won't remain there very long.
    Absolutely love the iLO feature of these units now that it is built in compared to the N54L and ESXi ISO which is completely supported is fantastic
    Sophos works brilliantly on this unit as a software firewall and is great for blocking sites that you don't want your kids to be on regardless what device they use.
    Looking to maybe load a SSD in for the ESXi host caching however only reading up about it at the moment and not sure how much of a difference it would make to the system. Would like it if anyone has any feedback on improvements this might make.
    Very happy with my system so far.
  15. the_fuzz
    the_fuzz Member
    Sep 6, 2004
    9,806
    Thanks mate, Do you have a link - I have a G2020T and my googlefu is not functioning this morning....... :)
  16. JasonBM
    JasonBM Member
    Apr 30, 2012
    51
    Sorry scratch what I wrote, I thought this was the Gen 7 thread.
  17. Sektion8
    Sektion8 Member
    Sep 21, 2004
    142
    ...Still Searching...
  18. passivekid
    passivekid Member
    Sep 10, 2003
    332
    Perth, WA
  19. fad
    fad Member
    Jun 26, 2001
    2,673
    City, Canberra, Australia
  20. Mudg3
    Mudg3 Member
    Mar 1, 2010
    480
