HSF for temp cooling whilst WC is in shop
Discussion in 'Overclocking & Hardware' started by Ding.Chavez, Mar 14, 2017.
  1. Ding.Chavez
    Ding.Chavez Member
    Jul 27, 2001
    420
    HAve a Corsair H100i v2 but needs to go back to manufacturer so I need a HSF for LGA1155 i5 ... just something to get me by, any recommendations? will be temporary so I dont want to really form out too much $$
    Thanks all in advance!
  2. zero_velocity
    zero_velocity Member
    Sep 16, 2010
    2,398
    QLD
    The stock cooler that came with the CPU would be the obvious answer...
  3. havabeer
    havabeer Member
    Dec 12, 2010
    3,155
    Yeah I'd find a cheap stock cooler and just turn overclocking off
    Ding.Chavez
    Ding.Chavez Member
    Jul 27, 2001
    420
    didn't come with one, should of mentioned, but guess if i am here looking for one this would be obvious
  5. zero_velocity
    Sep 16, 2010
    2,398
    QLD
    It may be obvious to you, but we as a communuty have no gauge of your memory or intelligence.
    I cant believe i have to spell it out as i personally thought it would be obvious; go to your local, ask if you can have a stock cooler if they do custom builds or sell you a stock cooler on the cheap.
    Short of that, go to that same local store and ask the man "what is the cheapest hsf you sell for xxyy socket" and buy that. For reference xxyy should be replaced with your actual socket type, i thought that would be obvious, but its apparent we need to define these things.
    You can also substitute going to your local store with ordering from the internet such as pccg, megabuy, umart, msy...
    Take this hsf home, turn off your pc and overclock and install hsf while you wait for warranty....
    Tldr get the cheapest hsf you can find because you only need it temporarily and overclocking isn't necessary
  6. terrastrife
    terrastrife Member
    Jun 2, 2006
    18,207
    ADL/SA The Monopoly State
    I thought the classified WTB forum would be the obvious place to post this.
  7. i7Baby
    i7Baby Member
    Jul 3, 2012
    290
