HTPC HDD Options - Power saving
Discussion in 'Storage & Backup' started by BlackTigerTech, Jul 19, 2008.
  1. BlackTigerTech
    BlackTigerTech (Banned or Deleted)
    Jan 27, 2008
    61
    2040 Sydney
    I'm having a hard time to deicide between a couple of options I have regarding the build of a new HTPC.
    I have decided to build a very energy efficient machine based around a mini-itx platform, and need a tiny bit of local storage for the OS locally.
    The thing is, I do not really want to use normal hard-drives as they have a pretty high power consumption. My other options are either a cheap 32 GB SSD drive (found one for just over $200 in SATA format) or to get a CF<->SATA or IDE adaptor and a cheap 32GB card.
    The machine will be on 24/7 mostly playing radio or music, and will play the occasional video over the network, so the chosen storage will not have to be very fast or large. I am looking for something reliable as I do not want to redo this machine for at least 3 years or so:)
    Link for the cheap SSD drive: http://flashmemoryking.com/shop/index.php?main_page=product_info&cPath=10_11&products_id=26
    Found some cheap CF there: http://www.hboutlet.com.au/catalog/index.php?cPath=1732_1764
    Will there be a big difference between the SSD and CF drive in my situation? As basically either solutions would work out to be the same price!:thumbup::D
    Thanks Guys!
  2. neon_87
    neon_87 RIP
    Mar 6, 2005
    2,756
    just grab a 5400rpm 2.5" sata drive. they dont use much. More than a SSD, but cheaper. 320gb - $140.
    BlackTigerTech
    Jan 27, 2008
    61
    2040 Sydney
    That's the thing tho, I will not use even 10% of that 500GB, which seems like a waste. The power requirements are huge too, as those little SSD Drives only use a few hundred mA of power.
    And for $50 difference, wouldn't it be better to go SSD?
    I plan on trying to run this off a 12v brickpack for the entire system, as to make it portable to carry to the garden and run off a car battery or something...:thumbup: I would only be having MythTV and probably 10-15GB of MP3s on it at any one time at the most!
  4. infiltraitor
    infiltraitor Member
    Sep 7, 2002
    3,801
    melbourne Donated:$133.70
    thought about getting an ipod instead?
    BlackTigerTech
    Jan 27, 2008
    61
    2040 Sydney
    Definitely. But If I have success with the power consumption of the whole system, I may build another one to use as a mail server at home. And maybe even another one for file storage with a couple of Samsung 1TB green power HDDs, with the HDD shutting down when not in use.:thumbup:
  6. deva_da_man
    deva_da_man Member
    Aug 30, 2007
    347
    why not just buy a smaller 2.5" drive?
    they 160gb ones are $66 now! and the 120's are like $55
    BlackTigerTech
    Jan 27, 2008
    61
    2040 Sydney
    Good idea, I wil look into that.
    SSD still seems to be the way to go so I may order some tonight or tomorrow. Can't go wrong with 32GB for $200!!!:thumbup::D
  8. _the_duke_
    _the_duke_ (Taking a Break)
    Sep 3, 2004
    5,179
    Hey Dadelaide
    I'd just grab a notebook hard drive, even if it uses more power, it will probably take years for power savings of the SSD to make it worthwhile.
  9. terrastrife
    terrastrife Member
    Jun 2, 2006
    18,766
    ADL/SA The Monopoly State
    whats wrong with a usb flash drive?
  10. BurningFeetMan
    BurningFeetMan Member
    Apr 22, 2003
    8,966
    Veg City
    Did you end up buying a SSD? Have you had any problems or dramas, or are there only good things to report?
