HTPC Help
Discussion in 'HTPC' started by cassius, Apr 7, 2010.
  1. alvarez
    alvarez Member
    Jun 25, 2006
    2,623
    Geelong 3218
    Yes you would arrange the expansion cards like that,
    But your biggest issues are why are you throwing money away on such high end components and on windows.
    For a decent media center *nix is your best option, unless you want .wmv and ads. With *nix you will also want an Nvidia card as ATi is an enemy of your freedom.
  2. phantompisser
    phantompisser Member
    Jul 2, 2001
    977
    H55 and I5-650 is the way to go IMHO .
    I built mine a month ago , it's extremely quiet plays everything and best of all passes unencoded DD and DTS to my amp without stuffing around .
    Windows 7 Media Centre works extremely well , It leaves me wanting for nothing . Resuming from sleep using the remote works .
    Went with the : Antec 2480 case (very quiet with 430W PSU)
    Leadtek 2000DS tuner $80
    GB H55 mobo $119
    1.5TB WD Hard Drive $130
    2gb Ram $60
    I3-530 $140
    Aim media remote $25 (Leadtek remote was not as nice)
    cdrom , hot swap drive bay I had lying around
    Best part is my wife has no dramas operating it .
  3. cyrax83
    cyrax83 Member
    Feb 5, 2005
    5,074
    hurstville, sydney
    is this the remote you got ?
    http://cgi.ebay.com.au/AIM-REMOTE-C...QQptZAU_Input_Peripherals?hash=item4cee1b3a81
    couple of questions if it is :
    1) is the infrared generic or is it tied to this particular remote ?
    2) is it a learning remote ?
    3) can you sleep from the remote ?
    cheers
