Hyper Case DM-01
Discussion in 'Modding Worklogs' started by Defyant, Mar 8, 2020.
  1. havabeer
    havabeer Member
    Dec 12, 2010
    6,185
    when are you going to give up your day job and just go into case development? surely you'd kill it, send some of these designs off to the big case makers
    Elmf and Defyant like this.
    Defyant
    Defyant Member
    Mar 11, 2004
    1,430
    Defyant Modded "Tail" Lights!
    Cheers HB That would be a dream job :thumbup: This is really just the hobby, The real coin is in head and tail light mods :D
    juzz86, ShaggyMoose, mad_mic3 and 2 others like this.
  3. Stax
    Stax Member
    Apr 8, 2002
    314
    Redcliffe, Perth
    Holy f'ing WOW. Amazing, just amazing. Great work and lots of patience required.
    Defyant likes this.
  4. slamaa
    slamaa Member
    Jun 1, 2006
    2,063
    Reservoir, VIC
    Mate! Amazing build top job
    Defyant likes this.
    Defyant
    Defyant Member
    Mar 11, 2004
    1,430
    It's good to be back on the horse :)
  6. fureien
    fureien Member
    Apr 11, 2013
    99
    man this is like if antec and phanteks had a baby. looks brilliant
    what kind of mesh are you using? looks like fabric, but up close looks like punched metal of somesort
    also what is that fabulous cable covering for the GPU psu plug?
  7. mad_mic3
    mad_mic3 Member
    Jan 18, 2009
    2,564
    Nulkaba
    any updates
    Defyant
    Defyant Member
    Mar 11, 2004
    1,430
    Cheers fureien :thumbup: appols for the late reply. The mesh is repurposed case and speaker grills. I was lucky enuf to have an old NZXT phantom case i could tear down.
    The mesh is cut down and reshaped :thumbup:
    [​IMG] [​IMG]
    Heya mic hope you are well mate :thumbup:
    Work has really ramped up the past couple months....12 hour days with Saturdays as well..... The work shed is full of cob webs :( Can't wait for some time off @ Xmas and i can get some quality mod time in and finish this one off.
    DSTM (Dougie) and mad_mic3 like this.
    Defyant
    Defyant Member
    Mar 11, 2004
    1,430
    Cheers for the spur on mic, it's just what was needed :thumbup:
    It's not much but it's some thing
    Changing up the shape and design a little to maximise window size ...its a double layer with overlay to allow the window to sit in snug
    The section that will attach to the front of the vent will be a separate piece and will be painted black.
    Flipping the panel over shows how the vents will sit flash against the window
    mad_mic3 and DSTM (Dougie) like this.
    Defyant
    Defyant Member
    Mar 11, 2004
    1,430
    Merry Xmas all :)
    A qik update for the hols.
    The orig plan was to hard glue the vents to the inside of the vent.... but this was going to make painting and future changes/upgrades a pain.
    So i decided to remake a set for the 3rd time...... this time in a "Cartridge" form. That way i can just paint and socket them into place. This would also make the process of clear and tinted window changes easy too.
    The whole assembly is strong enuf to just be slotted into place press fitting against the inside of the vent and the window and the be secured.
    The excess over hang will get trimmed but i'm still not 100% if i want them to angle in / or out \
    The shortest one you see being the reference.
    Removing the paper of the test clear panel im still deciding if i should cut a hole to make them a vented or just leave them as dummy vents.
    A quick ruff trim of the backs for a look.
  11. mad_mic3
    mad_mic3 Member
    Jan 18, 2009
    2,564
    Nulkaba
    Merry Xmas mate
    Defyant likes this.
    Defyant
    Defyant Member
    Mar 11, 2004
    1,430
    Same you Mic hope you had a good one :)
    mad_mic3 likes this.
    Defyant
    Defyant Member
    Mar 11, 2004
    1,430
    Got a few extra days off for Xmas :D So decided to throw these into the mix
    Some themed speakers to match the case mod. (Hyper Speakers?)
    I'm no sound engineer but i know the sound i like ... and that's loud and deep :) Not much for treble a touch of mids and lotsa boom boom.
    That's a hard thing to get on a desktop with out having to use a sub.... and i'm not keen to do that.... just yet.
    Ive been playing around with the Swan BS3 Drivers for a while now and really like them, A 30 Watt Full range that work pretty well without the need for X-Over work.
    SO Loud is not prob since i'll run 2 x Swan drivers in each cab but getting them to go deep would be a bit of trial and error.
    As cool as the clear looks these wont stay that way i have plans for these so maybe another clear set for the wifey :)
    Anyways after a couple of fails and ruff mock ups i ended up with this.
    Allowing the Speaker to sit back like this puts the drivers out of phase. So a Custom stand will be used.
    I'll prolly end up making a few types of stands :)
    The texta mark is where the port will sit.....
    The Ports is hard glued in and the Drivers added.
    Being narrow i really have to place them just right...but after a lotta listening and tweaking they are loud and they really do go deep :D
    DSTM (Dougie), zFirehawk and mad_mic3 like this.
    Defyant
    Defyant Member
    Mar 11, 2004
    1,430
    I decided to keep the first one as the tuning speakers and get to making another 2. This will help down the track and get me half way to having a set made for the missus :)
    Magnets are used to attach the front panels
    The stands are hefty , they have to be... these things are heavy !
    Locating lugs are added so the speakers dont slide off
    For now these are pretty much done, I'll leave all the filling primer and pint work till i get have the new side panels ready :)
    Defyant
    Defyant Member
    Mar 11, 2004
    1,430
    The speakers while not painted yet are sounding amazing and really handle some volume and put out some really nice deep bass. I recently brought the Topping MX3 Dac/Amp/Headphone Amp. And while it's a great AIO Desktop solution it lacks a the solid punch these speakers need. The headphone stage dosn't quiet stack up to my Schiit Modi / Magni Combo.
    So.......
    Hyper Amp ! ......
    Well Amp/Dac :)
    I always loved the look of the Peechtree Audio gear so went with that style with a little Hyper-ness thrown in.
    The victims being a 2020A+ amp and a Muse Dac chosen for the power and the sound and seem to combine pretty well.
    The first thing i'll do is chuck the plastic knobs for some sexier ones
    The new housing is pretty simple with a slight angle to match the case mod and speakers.
    There's a fair bit of work to do inside still and a active fan and back panel will round it out.
    A single 12V / 6 amp psu will supply more than enuf grunt for both amp and dac.
    Some gap filling sanding and primer work.......
    And some high fill... then left to sit for a week before a final wet sand and paint with the speakers and side panels :grin:
    DSTM (Dougie) likes this.
