Increasing Headphone Volume?
Discussion in 'Audio Visual' started by Madengineer, Aug 1, 2016.
  1. Madengineer
    Madengineer Member
    May 27, 2011
    14,783
    Hey guys,
    Got a pair of Headphones the other week (just a set of Plantronics 2). Nothing too fancy. But I'm noticing the volume isn't particularly loud, even when I've got its volume all the way up (on cable control) and OS volume set to 90%
    Is there a way I can get it louder? would introducing an amp increase volume?
  2. power
    68,201
    what exact model?
    USB, bluetooth, stereo pin??
    Answer will change depending on what they are.
    Madengineer
    Madengineer Member
    May 27, 2011
    14,783
  4. Joehax
    Joehax Member
    Sep 2, 2006
    2,794
    Try a cheap headphone amp?
  5. power
    68,201
    then you can look at some sort of headphone amp, or a halfway decent sound card.
    Madengineer
    Madengineer Member
    May 27, 2011
    14,783
    Yeah, I'm looking at getting this: https://www.jbhifi.com.au/headphone...r-ha400-4-channel-headphone-amplifier/990400/
    And possibly a soundcard. My motherboard has limited PCI/e slots accessible due to graphics.
    How do you think that headphone amp would go?
    The motherboard is a H97I Plus BTW. It's supposed to have decent sound as it is?
    I may not actually have the audio drivers installed... (Other than generic ones Win10 installs?)
  7. mesaoz
    mesaoz Member
    Jan 15, 2015
    8,258
    South East QLD
    Madengineer
    Madengineer Member
    May 27, 2011
    14,783
    Sites not loading for me?
    But if that's the site I think it is, I've looked at it already (they had a useful page for deciding whether you need an amp or not).
    Didn't have the drivers installed, but it hasn't really made much difference...
    Madengineer
    Madengineer Member
    May 27, 2011
    14,783
    So just bought a Behringer MicroAmp (HA400) $60 posted off ebay.
    Got a lot of good reviews and stuff. Since I can't get a soundcard, this is literally the only other option :D
    At least now I'll be able to hook up both my speakers and my headphones...
  10. Renza
    Renza Member
    Dec 1, 2004
    4,947
    Hate to tell you, but they are only $45 new with shipping...
    You probably wouldn't want to run speakers off it as well, as it outputs an already amplified signal, reducing quality.
    Could have gone a USB DAC with a headphone amp.
    Madengineer
    Madengineer Member
    May 27, 2011
    14,783
    I saw that, but couldn't find any with stock/in australia. But I'm ok with the cost. If it does the job and I get what i need out of it I'm ok with that.
  12. Spork!
    Spork! Member
    Jun 5, 2009
    2,307
    Tasmania
    Just curious why you have windows volume @ 90% instead of 100 if you want it louder?
    Madengineer
    Madengineer Member
    May 27, 2011
    14,783
    Cause having it at 100% would make me feel like it's too loud :D
    Like, if I have it at 100%, that's absolute max. Doesn't make any sense, but yeah...
  14. Spork!
    Spork! Member
    Jun 5, 2009
    2,307
    Tasmania
    Wouldn't want you to harm your hearing. :D
    Most ppl. who understand what they are talking about seem to suggest having windows volume @ max and adjusting with the external amp. if you have one.
    Something about bits being removed by windows volume control...
    Madengineer
    Madengineer Member
    May 27, 2011
    14,783
    Yeah thats what I plan to do. Then I'll use max windows volume and vary the volume on the amp
    Madengineer
    Madengineer Member
    May 27, 2011
    14,783
  17. sammy_b0i
    Jun 29, 2005
    4,796
    ACT 2905
    Madengineer
    Madengineer Member
    May 27, 2011
    14,783
    Madengineer
    Madengineer Member
    May 27, 2011
    14,783
    Sooo got the right adapters... Didn't get the right extension lead :D Needed to get a male to male. I got a male to female :(
