Installing XP Pro w/SP3 onto a SATA drive
Discussion in 'Windows Operating Systems' started by neomatt, Jul 13, 2008.
  1. neomatt
    neomatt Member
    Mar 28, 2006
    272
    WA
    I've been looking around on Google and it seems XP Pro doesn't support SATA unless you slipstream the driver onto XP.
    Is that the case? Or will it work fine with a copy of XP Pro w/SP3 slipstreamed onto it?
    The mobo I'll be buying/using is P5Q-Pro and the Sata Drive will be 750gb Samsung.
  2. suicidal
    suicidal Member
    Oct 17, 2003
    232
    It will depend on the controller you decide to use and whether it is in legacy/RAID/AHCI mode.
    Legacy/IDE - will install fine without
    RAID/AHCI - will require drivers; via floppy or slipstreamed with nLite.
    neomatt
    neomatt Member
    Mar 28, 2006
    272
    WA
    I was right then, I will need the drivers. Will the samsung SATA drivers come with the drive on a floppy? Or will I need to DL?
  4. Taceo Corpus
    Taceo Corpus Member
    Sep 19, 2005
    3,257
    Osaka, Japan
    No drivers come with drives. You'll need to download them from samsung's site.
  5. kogi
    kogi Member
    Jan 23, 2003
    5,491
    2031
    Drivers should come with the motherboard, not the drive.
    neomatt
    neomatt Member
    Mar 28, 2006
    272
    WA
    So SATA drivers for all drives for XP Pro will come with my mobo?
  7. Reaper
    Reaper Member
    12,159
    Brisbane, Qld, Australia
    Yes.
    It's controller dependant, not device connected dependant for the drivers that XP will require.
    And you don't need to slipstream, just press F6 when the first loading bar appears when you go to first install XP. Watch for the message. Then you just insert the floppy disk that you copied the drivers to from the CD that came with your motherboard when prompted.
  8. Drew_
    Drew_ Member
    Feb 20, 2007
    2,045
    Floppy disk? Who has those these days...
  9. Zzapped
    Zzapped Member
    Jul 8, 2001
    12,368
    Mandurah
    To clear up the confusion.The Hard drives themselves do not require a driver of any form, the motherboard controllers are what require drivers in some cases.As has been said, if you set the motherboard sata controller to legacy/native.ide or whatever the oprions are in your particular bios then you should not need any sata drivers. If you have the motherboard sata controller set to raid/ahciu or whatever your motherboards bios calls it then you will need the drivers.
    Cheers
    Z
  10. checkers
    checkers Member
    Jan 22, 2007
    613
    Is there any way to avoid having to install drivers via floppy with the newer OSes such as Vista and Server 2008? As far as I know, nlite doesn't work with them, and there's no equivalent tool. Can the Windows installers load off USB drives?
  11. RoNiNSan
    RoNiNSan Member
    Dec 15, 2002
    624
    oz
    Vista and 2008 support usb so you don't need floppys anymore to load raid drivers etc
  12. KNoodles
    KNoodles Member
    Jun 28, 2002
    180
    I had the same issue.
    I have an old XP Pro CD (no service pack) and Windows could not find my SATA drive.
    XP with SP2 and XP with SP3 have a generic SATA driver already there. So, you're right. Slipstreaming the SP will (most likely) fix your problem.
    There was also another issue. Windows did not see more than 130GB of my drive without SP2.
    I never manually installed any drivers for the SATA controller.
  13. pheonix991
    pheonix991 Member
    May 16, 2005
    153
    AR, USA
    I installed nlite'd xp sp3 on my p5n-d(brand new quad core setup) last week. It worked great. I installed it onto my sata drive, no problem.:thumbup:
  14. mc_konazz
    mc_konazz Member
    Aug 29, 2006
    48
    Ok... i've had to do F6 installs for many machines.
    For native SATA/AHCI you will need the motherboard drivers. These can usually be sourced from the mobo's manufacturers website. It has nothing to do with the HDDs! I get my nVidia drivers from the mobo manufacturer's website, but I get Intel driver's from either the manufacturer or from Intel's website. For ICHxx Intel drivers, look for Intel Storage Matrix drivers.
    I don't do slip streaming, so I'll give you a run down on F6 installations.
    XP: You'll need a floppy drive... its the only way unless you slip stream. Unzip the drivers onto a floppy drive, and during the initial installation of XP, the first time you see the blue screen, you'll see a label at the bottom like: "Press F6 for drivers..." or something close. Press F6. It'll go through all its other crap, but instead of going into EULA, it'll go into your driver installation. Now enter the floppy, and install both the RAID and SATA/AHCI drivers. You may have one, or both, depending on your controller. Once they've loaded up properly, take the floppy out, and continue with the installation. You'll be fine now... thats it
    Vista/S2008: pretty much the same way, but you can unzip the drivers onto a USB key, as these OS's recognise USB drivers immediately - just use the correct drivers (i.e. not XP drivers). You don't need to press F6. You'll get to a screen a bit into the installation, where you get to choose your HDD/Partition. There should be a button to install additional drivers. Here is where you can scan, and let it show you what possible drivers to use. Just install, remove USB drive, and return to the main screen and continue installation.
    On intel machines, I usually also install the Intel Matrix software, but haven't quite found a use for it, as now i'm using dedicated HDD controllers in my system.
    Anyway, hope that helps... its really not that hard - google is your friend.
  15. Zzapped
    Zzapped Member
    Jul 8, 2001
    12,368
    Mandurah
    If your bios supports it then you simply switch the sata controller mode to native and you dont need sata controller drivers despite having a sata contyroller.This is how I install XP on my HP laptop and a few others that I have done lately
    Cheers
    Z
  16. ECHO
    ECHO Member
    Jun 17, 2002
    642
    I had an issue with installing XP on a new Toshiba laptop recently.
    I tried 2 different USB floppy drives and multiple drives, and setup refused to copy a file across. iStor.sys or something similar.
    Anyway, to cut a long story short, I ended up slipstreaming it with nLite (which is EXTREMELY easy I might add). Definitely worth doing to save yourself a lot of time.... and why not customise your XP installation while you're at it ;) nLite is great!
  17. suicidal
    suicidal Member
    Oct 17, 2003
    232
    I recall reading that native mode is related to IRQ assignments for the controllers. For older operating systems, you'll want it disabled; for 2k/xp onwards/linux, enabled. AFAIK this has no bearing on the above drivers required for the controller when running AHCI/RAID. You can experiment with existing IDE legacy setups by enabling/disabling in the BIOS, and then checking your IRQ assignments in device manager.
    Your actual SATA controller will (or should) have have the options of IDE legacy, AHCI & RAID (if available) as configurable options, with the latter two requiring the above F6 or slipstream method for XP.
  18. Aetherone
    Aetherone Member
    Jan 15, 2002
    9,567
    Adelaide, SA
    Ah the fun of controllers and the confusion they cause. Its not helped by every mobo manufacturer using slightly different names and descriptions in their BIOS entries :Paranoid:
    Native / legacy
    controls how the drive is presented to the operating system. It's for backwards compatibility of old OS'es (Win9x).
    Native or legacy does NOT require drivers in either mode.
    IDE / AHCI / RAID
    The mode in which the controller behaves. AHCI is required to enable things like NCQ and advanced power saving (IIRC per drive spindown instead of per-controller). RAID is what it suggests.
    IDE: supported in the OS (NO extra drivers needed)
    AHCI: requires extra drivers
    RAID: requires extra drivers
  19. Agisthos
    Agisthos Member
    Jun 16, 2003
    11
    Exactly the same here. Many new notebooks, notably Toshiba and ASUS,will require the drivers slipstreamed onto Cd before XP can be installed.
    I also tried 2 different USB floppy drivers and neither would copy all the files across, getting stuck just as ECHO describes.
    Use nlite to slipstream.
  20. te27te37ae86
    te27te37ae86 Member
    Jul 9, 2008
    282
    Installing XP PRO with SP3 onto Sata drives
    With XP search Microsoft Tech Net AHCI support is covered there,there is actually a bit more to it than just F6 to fully enable it.
    Slipstreaming is the preferred option as a reinstall if required then is no longer an issue.
    Vista comes ex factory with AHCI support so make sure you set AHCI not IDE compatability in the BIOS for Vista.
    As a side note if anyone wants to dual boot with Later Linux 26 series Kernel Distro's they wont even find a Drive unless AHCI is enabled in BIOS.
    This means if you want to dual boot either Fix the XP issues (XP-PRO X64 as well) or go into the bios to reset Controllers for whatever OS you need to boot,What a pain.
