Internet Explorer in XP problem!!!
Discussion in 'Windows Operating Systems' started by staden, Aug 9, 2002.
  1. staden
    staden Member
    Jul 3, 2002
    136
    I have a problem with internet explorer in XP, it cannot open a new window, it opens the window however it stays as a white screen and doesn't load anything, you have to manually copy the link, open the new window and paste the link for it to work.
    However for some javascript links this is very difficult or impossible, does anyone else have this problem or know of a solution??????
    Thanks!!!
  2. kasar
    kasar Member
    3,509
    Pyrmont, Sydney
  3. Strange1
    Strange1 Member
    3,377
    Sunshine Coast
    Probably better off in the Software forum :)
  4. Ali _G
    Ali _G Member
    Jun 10, 2002
    109
    Yeah I get the same probs here as well. I think its a java issue.
  5. Bluntman
    Bluntman Member
    Jan 4, 2002
    45
    Wollongong
    i had the same problem for weeks,
    i forget exactly how to fix it but basically you have to re-register a
    internet explorer dll in the registery (spl?)
    I eventually found this out by searching through pctech sites
    good luck
