Inwin Chopin mITX case power supply fan noisy ?
Discussion in 'Portable & Small Form Factor' started by nai, Apr 16, 2018.
  1. nai
    nai Member
    Nov 20, 2002
    169
    Hi
    I bought an Inwin Chopin mITX case recently but the power supply fan was loud , it is audible even from 3 metres away. The whine sounds like the rpm is definitely more than 2000rpm,may be even >3000 rpm, the rev speed is constant from first boot all the way into Windows, when the PC is idle and under load.
    Anybody here got the same case with this high speed sound ?
    Just wondering if this case is faulty, should I RMA it ?
    Thanks
  2. TheWatcher
    TheWatcher Member
    May 14, 2014
    446
    It should not be loud at all.
