Iron man arc reactor build with arduino
Discussion in 'Electronics & Electrics' started by DualBios, Jun 3, 2012.
  1. DualBios
    DualBios Member
    Jul 5, 2004
    272
    Mackay
    Hey guys now i would normal play with this stuff my self to learn. but everything has taken so long to get here i wont get a chance to play with the coding etc. I am looking for help to program the etherten. what i will have is two led rings and then im going to put a 10watt led in the middle.
    I want tonight 2 buttons one to power up. first ring fades in then second one follows. Second button fades in 10watt led to 50% and after 3 seconds blast 100%. I also want a buzzer/pazio driver to give off a high pitch noise as it charges up etc.
    Any help would be great. also wondering what driver from jaycar would be suitable for a 10watt led that is dimable?
  2. TERRA Operative
    TERRA Operative Member
    Jul 8, 2005
    6,925
    Niraikanai
    Is this going to be chest mounted? A 10 watt LED is going to need a decent amount of heatsinking and will get quite uncomfortably warm against your chest..
    I don't think Jaycar will have a driver for a 10 watt LED, that will probably be a custom job for your application.
    DualBios
    DualBios Member
    Jul 5, 2004
    272
    Mackay
    hey mate, yeah will be the chest mounted unit the 10w will only run for 3 seconds today at a time maybe put a 1min cool down on it. i have a large heat sink for it though that i think i can build the whole chest peice on which is kinda cool in a way
    DualBios
    DualBios Member
    Jul 5, 2004
    272
    Mackay
  5. TERRA Operative
    Jul 8, 2005
    6,925
    Niraikanai
    If you aren't running the 10w LED constantly, a smaller heatsink should be fine.
    That driver you linked to looks ok. It's small and has PWM input for dimming.
    If it fits, it might be the go, cheap too. Almost worth buying it just for prototyping even if it turns out a bit too big.
    You can always sit it in your pocket with the batteries, and run the two wires up to the LED in the reactor itself.
    DualBios
    DualBios Member
    Jul 5, 2004
    272
    Mackay
    yeah was thinking of running a battery pack arduion etc in a box in my pocket. just run a ribon cable to it.
    for a battery pack i have seen serveral run small lipo's to power it any info on that
  7. TERRA Operative
    Jul 8, 2005
    6,925
    Niraikanai
    Check out hobbyking for cheap, good quality lithium batteries. They won't have protection circuits (being for remote control gear), so you'll have to sort that.
    grab a cheap charger and a small lipo and you should be set.
    DualBios
    DualBios Member
    Jul 5, 2004
    272
    Mackay
    thanks mate
  9. mtma
    mtma Member
    Aug 12, 2009
    4,735
    Keep in mind you'd probably want to adequately protect the lipo cells with a case.
    Round cells might be worth considering based on the above as well as the additional energy density over hobbyking lipos.
    DualBios
    DualBios Member
    Jul 5, 2004
    272
    Mackay
    what do u mean by round battery? like AAA?
  11. mtma
    mtma Member
    Aug 12, 2009
    4,735
    I mean like cells like these (link example only)
    They have comparably higher energy density as well as are physically tougher, which may make them worthwhile.
    DualBios
    DualBios Member
    Jul 5, 2004
    272
    Mackay
    thanks for the link mate ill look in to them now. finally got my 10 watt chip and the non dim driver with it will get pics up soon
    DualBios
    DualBios Member
    Jul 5, 2004
    272
    Mackay
    well pics up https://www.facebook.com/media/set/?set=a.10150999184245751.468361.670515750&type=3&l=609fd73c31
    so now im on to working on hooking the arduion to a n-mosfet driver and led driver i need to know what pins on the mosfet connect to arduion and what goes to the driver im guessing the g (gate) goes to the pwm pin. s (source pin) either positive or negative pin for power depending on placement. d(drain) to the device postive or negative depending on placement yeah?
    DualBios
    DualBios Member
    Jul 5, 2004
    272
    Mackay
    more pictures up, i now have the leo and the etherten arduion for testing. finally all the leds have shown up and am only waiting on 2 led drivers for the repulsors. Last bit of soldering will occur tonight\sat and hopefully on sunday will have a working version
  15. THE_PROFESSOR
    THE_PROFESSOR Member
    May 25, 2002
    278
  16. alch
    alch Member
    Oct 9, 2006
    1,541
    arduino
    K.. Now thats said and done.
    DualBios
    DualBios Member
    Jul 5, 2004
    272
    Mackay
    yeah just noticed that sorry. pics will be up in a second.
    DualBios
    DualBios Member
    Jul 5, 2004
    272
    Mackay
    well new pics of progress so far. programing the speaker is proving to be a pain as i have never done much coding before.
    DualBios
    DualBios Member
    Jul 5, 2004
    272
    Mackay
  20. TERRA Operative
    Jul 8, 2005
    6,925
    Niraikanai
    You going to use the SLA battery for your final item or will you go Li-po?
