Is curved worth it?
Discussion in 'Video Cards & Monitors' started by rickbishop, Apr 19, 2017.
  1. rickbishop
    rickbishop Member
    8,807
    Petrie, QLD
    So I'm planning my next rebuild, and given the length of time I tend to keep a system for (still rocking a Q6600 rig), I'm looking at going high end to give the maximum life.
    This means a BIG 4k monitor. I'm thinking 32" up to 40".
    Now I've heard about the 40" Philips flat, but it seems to be EOL, and been replaced with a curved one. So in this size, is curved worth it? I'm sure it would take some getting used to, but as they say, you don't know how awesome something is until you've had it and had to do without.
  2. bart5986
    bart5986 Member
    Jan 31, 2006
    5,293
    I think HDR, Freesync/Gsync, IPS and Refreshrate are more important
  3. power
    68,331
  4. whatdoesthisdo
    whatdoesthisdo Member
    Jan 19, 2011
    10,487
    Gold Coast
    Before I bought one I thought curved was just another gimmicky concept. I was wrong. I love the curved screen for gaming and I do think it is much more immersive.
  5. elvis
    elvis Old school old fool
    46,599
    100% agreed. LCD is terrible technology, and all of the above are finally making it less terrible after this long. They're the first things I look for when buying a monitor.
    The only thing I'd add would be objectively measured input lag (via a Leo Bodnar tester or similar device), but that's more an issue for console gamers than PC gamers.
  6. spank36
    spank36 Member
    Feb 17, 2013
    281
    Theres the LG 38"? Or a 34 ultrawide?
  7. cvidler
    cvidler Member
    16,142
    I run a pair of 32" 4K flats. and recently upgraded the TV to a 55" 4K flat.
    instore demos of curved screens didn't do anything for me.
    (FWIW I don't game on my PC, but have a XB1S on the TV)
    rickbishop
    rickbishop Member
    8,807
    Petrie, QLD
    Yeah nah, not digging the ultrawide concept.
  9. power
    68,331
    I've imagined a curved screen in my living room and I think it'd suck - surely you have to sit directly in the middle to be able to appreciate it properly.
    As far as those suggesting ultra-wide, I know a bloke that bought one - loved it at first, then got really sick of the stupid resolution because it's uncommon.
  10. ysu
    ysu Member
    Sep 27, 2005
    1,111
    Central Coast
    Personal preference, and only works if you're the only one looking at the screen. A sideways perspective is rubbish (i.e. someone sitting not completely in front of the screen - e.g. next to you).
    Get the 43" philips instead ;)
  11. cbb1935
    cbb1935 Guest
    Curved is only good if the monitor is filling your entire field of vision.
    Kinda like wrap around sunnies :)
    I've got a 31.5" AOC Agon Curved for my racing cockpit. Works fine because of how close/far you are from it.
  12. spank36
    spank36 Member
    Feb 17, 2013
    281
    AOC are bringing out a curved 32 inch 144hz 1440p, should be available next month. One might tempt me back to the 16:9 world
  13. MR CHILLED
    MR CHILLED D'oh!
    Jan 2, 2002
    162,121
    Omicron Persei 8
    40+" curved would be awesome. Whether it's worth it? Well overall if it adds to your experience then I'd say yes, but it's debatable whether you really would notice it after a week.
  14. voltare1
    voltare1 Member
    Jun 6, 2002
    400
    Could get a 40" 4k tele, depending on its support for game mode.
  15. havabeer
    havabeer Member
    Dec 12, 2010
    7,314
    I just went from 40" 4k Phillips to an average x34 curved.
    Personally the curved isn't worth it at all, the gay community and higher refresh rate is
    The curved is just a gimmic in my opinion, but there's no real 30" + high refresh + gsync + 4k monitors out at the moment
  16. MR CHILLED
    MR CHILLED D'oh!
    Jan 2, 2002
    162,121
    Omicron Persei 8
    That would be a downgrade to me.
    It feels a bit that way yes.
  17. havabeer
    havabeer Member
    Dec 12, 2010
    7,314
    Honestly I've swapped between the two to show friends and the screen tearing and roughnessof the 60fps its quite apparent. But yes graphics wise big step down
  18. xplod140
    xplod140 Member
    Jun 1, 2002
    4,663
    Melbun
    I thought it would be crap but anything wider than a 16x9 32" seems to look better with a slight curve.
    I had a flat 34 ultrawide and could see a tinly blur towards the edges but now have an LG 38 with the most minimal curve I don't even see it when sitting centred.
    As for TVs, I wouldn't go curved as you don't sit so close.
  19. dcyloo
    dcyloo Member
    Apr 7, 2002
    5,062
    You'd really need a tight curve to really appreciate the difference of the curvature when sitting in front of the monitor TBH.
    The X34 Acer Predator has a very slight curve and only perceived when viewing the screen from above or at the very edge of the side. When in front, effectively the screen is as flat as any other flat screened monitor.
    The X34 Predator is not there for the fact that it's curved, it's there for the IPS screen coupled with 100Hz refresh in an ultrawide format.
    rickbishop
    rickbishop Member
    8,807
    Petrie, QLD
    Yeah, a drastic curve would probably end up shitting me. The 40" Philips only has a slight curve, so it wouldn't be too bad sitting 3 feet away from it.
