Issues with 3090 and random restarts
Discussion in 'Troubleshooting Help' started by bondibro, Feb 28, 2021.
  1. bondibro
    bondibro Member
    Jan 18, 2017
    178
    au
    hi everyone,
    I have recently purchased a Evga 3090 FTW ultra video card and after using the EVGA Precision X1 tool to push the power target to 107%, I notice that in games after a period of time the computer will just restart with no warning. Running 100% power target I dont see any issues (yet...)
    I have done some reading and people say it could be an issue with my power supply, however this has only started with the 3090, my 2080TI previously with an OC power target ran fine.
    I am using a Seasonic Titanium 1000W power supply.
    Any recommendations or help would be appreciated - I have tried moving the cables on the PSU side and have also unplugged and replugged the cables into the GPU.
    Cheers,
  2. Sipheren
    Sipheren Member
    Aug 14, 2002
    3,447
    Gold Coast
    Something simple that I see a lot and causes this type of issue is using both plugs on the single PCIe power cable, given this has three 8 pins are you using 2 on one cable and one on the other? Those cables are only good for 150w each so using both connectors on something like a 3090 may be trying to pull to much current through them when it peaks.
    MrSnuffy likes this.
  3. MR CHILLED
    MR CHILLED D'oh!
    Jan 2, 2002
    157,622
    Omicron Persei 8
    Is there another power supply you can try? Even if it's lesser power.
    bondibro
    bondibro Member
    Jan 18, 2017
    178
    au
    Thanks mate, great call I will check that tomorrow. One thing I have done in the interim is stop using Nvidia Geforce Experience and so far also no issues...
    bondibro
    bondibro Member
    Jan 18, 2017
    178
    au
    Yes I will need to catch up with a mate later in the week if this isn't resolved
    MR CHILLED likes this.
  6. spit051261
    spit051261 Member
    Sep 29, 2019
    3,017
    bondibro
    bondibro Member
    Jan 18, 2017
    178
    au
    Thanks, I did already but didn't get a whole lot from it. I will try again cheers
  8. spit051261
    spit051261 Member
    Sep 29, 2019
    3,017
    Join up and ask the question
    Its a good place , especially for Evga GPU
  9. PureFire
    PureFire Member
    Jun 25, 2002
    1,766
    While gaming have a program like HWMonitor or HWINFO open to regularly check temperatures of all components. The 3000 series creates a crap load of heat which can create instability in other components.
    As already mentioned check that you have individual PCIE cables for each power connector on the GPU, especially if you are raising the power curve over 100%
    bondibro likes this.
    bondibro
    bondibro Member
    Jan 18, 2017
    178
    au
    thanks for the tips, I will double check and come back on the thread!
    spit051261 likes this.
    bondibro
    bondibro Member
    Jan 18, 2017
    178
    au
    Thanks guys, appreciate the help. Card is being RMA'd. EVGA just said its faulty and issues RMA to me.
    Sipheren likes this.
  12. Kelvin
    Kelvin Member
    Jul 1, 2001
    2,806
    Melbourne 3103
    Never mind that thread is yours
