Jaycar Delta 3d printer!
Discussion in 'Hobby Engineering' started by rainwulf, Feb 27, 2016.
  1. rainwulf
    rainwulf Member
    Jan 20, 2002
    4,238
    bris.qld.aus
    http://www.jaycar.com.au/Tools-&-So...r-Power-Tools/Arduino-3D-Printer-Kit/p/TL4100
    Just finished building and calibrating it. Sending my test print in now!
    Building it was fun, you actually get WAY more nuts and bolts then you are actually need which threw me off for a while.
    I didnt't assembly the power supply in the top and im using a seperate 12 volt supply.
    After calibrating it which was actually pretty easy, the first print is coming out now. Will post pics when its done.
    edit: responds well with slow feed rates. 1/4 feedrate makes it smoooooth.
  2. kjparker
    kjparker Member
    1,434
    This thread is useless without pics! :)
    rainwulf
    rainwulf Member
    Jan 20, 2002
    4,238
    bris.qld.aus
    Will get some pics tomorrow, the robot i printed as the first print has been "appropiated" by my little girl.
    This thing prints AMAZINGLY. The quality is incredible, the kapton tape on the hot bed means just a slight tap is required to remove the print.
    Im incredibly impressed. Will post some pics tomorrow with some decent light.
  4. aL4n
    aL4n Member
    Aug 18, 2003
    714
    pics now!
    10chara
  5. roamin
    roamin Member
    Jan 21, 2002
    2,748
    melb / Crimebourne
    agree with this!!!!
  6. roamin
    roamin Member
    Jan 21, 2002
    2,748
    melb / Crimebourne
    also why did you choose this printer over the aldi printer? considering the aldi has a larger print bed?
    rainwulf
    rainwulf Member
    Jan 20, 2002
    4,238
    bris.qld.aus
    had no luck getting one.
    also this one was a kit, and building it myself tickled me in the right place.
    rainwulf
    rainwulf Member
    Jan 20, 2002
    4,238
    bris.qld.aus
    rainwulf
    rainwulf Member
    Jan 20, 2002
    4,238
    bris.qld.aus
  10. yippy
    yippy Member
    Jul 12, 2001
    553
    That's a nice looking print :thumbup:
    rainwulf
    rainwulf Member
    Jan 20, 2002
    4,238
    bris.qld.aus
    Just learnt the hard way how to reinsert new filament. The hot end has a lip inside it that can block new filament from going through, so lesson learnt is to sharpen the end of the new filament so that it doesn't get caught on the lip inside the filament path.
  12. PRiME2007
    PRiME2007 Member
    Feb 10, 2007
    357
    Adelaide Gawler
    I just use some nail clippers to cut my filament at a angle for easier insertion. You can find designs on thingiverse for filament thumb cutters of types.
  13. Azrael
    Azrael Member
    8,988
    I printed this last time, works well http://www.thingiverse.com/thing:1249929
    Cant find it now, so should print another one.
    Edit: now that i look closer it wasnt that exact one, but pretty close.
  14. AgB deano
    AgB deano Member
    Jan 31, 2009
    926
    Bendigo, Vic.
    Almost looks like you printed a little cyberman :D
  15. hippyhippy
    hippyhippy Member
    Apr 1, 2004
    8,759
    Does anyone print anything useful? The only thing i see people printing are little toys you can get from china for 2 cents.
  16. Aussiejuggalo
    Aussiejuggalo Member
    Sep 14, 2010
    2,217
    Sunshine Coast Queensland
    To print useful stuff specifically for you, you need to know how to do 3D models.
    But in an answer to your question yes people print useful stuff, on thingiverse theres a lot of useful stuff from basic hooks to more complex Raspberry Pi cases, USB stick holders etc. If you have a big enough printer you can print whole cosplay costumes.
  17. Azrael
    Azrael Member
    8,988
    Check out /r/functionalprint for lots of functional printing. But the reason you will see lots of little robots and vases is that they are calibration items, and so showing that your printer is printing good calibration items means that it is working well.
    The rest of the stuff that people print is generally only interesting to one person, the user.
    rainwulf
    rainwulf Member
    Jan 20, 2002
    4,238
    bris.qld.aus
    At the moment im just getting into the hang of it, seeing where there are inaccuracies and things i can adjust. For example, im adding a 12 watt LED downlight to give me some decent light onto the print surface.
    I have also picked up some more PLA filament today, i now have blue, clear, black, white, aluminium filled and wood filled.
    Im building a dedicated repetier host machine (dual core atom), and a proper sealed storage system for the PLA filament.
    The wood filled filament is for doll furniture for my little girl, same with the white, the clear is being used to print clear little figurines and shapes that i will be lighting from the inside for night lights, camping lights.
    I also will be printing some attachments for my camping kitchen for light stands, and project boxes. That's what the black is for.
    That blue robot went to the Jaycar store in aspley and its being used as a display model :)
    To be 100 percent honest, it was a bit if an impulse buy and I really couldn't find that many things to print.. now that i have it though holy crap.
    The printer is pretty well active 24/7 now! The accuracy and stability improvements have made a difference. I am now printing at 220 percent faster then my first print, and yet it still looks fantastic and way better then a lot of the stuff i see on the internet which looks like it was printed with a 1mm layer height!
    Im still waiting for my tiko, which will also be added to the repetier host.
    Also, im sure i will see the aldi printer for sale here, where i will snap that up and modify it as well for higher accuracy and repeatability.
    As you can see from the first print, the delta tower can produce some amazing detail, and quickly too as it doesn't have to lump around the stepper motor on the hot end.
    I did blow the power supply up that came with the kit, as i dropped it and it went pop.
    I had an old dell "desktop replacement" laptop power supply though which supplied 12 volts at 19 amps, and that has worked a charm.
    So yea, i have lots of plans. Gonna teach me some sketchup so i can start designing things from scratch too.
    rainwulf
    rainwulf Member
    Jan 20, 2002
    4,238
    bris.qld.aus
  20. PRiME2007
    PRiME2007 Member
    Feb 10, 2007
    357
    Adelaide Gawler
    The only stuff I really print is practical stuff, atm I'm printing a cable chain for my printer but also working on a speaker stand for the hell of it. Last week I printed out a couple plastic bits for some household utensils. Guess I'll get around to printing out some useless junk again soon :)
