Jonsbo V9 - 17L Micro ATX Case
Discussion in 'Portable & Small Form Factor' started by raincloudx, Mar 6, 2021.
  1. raincloudx
    raincloudx Member
    Dec 18, 2007
    2,109
    Victoria
  2. Kelvin
    Kelvin Member
    Jul 1, 2001
    3,011
    Melbourne 3103
    holey moley..that a MicroATX case.. not a ITX case..
    should be cheaper than the NR200P no need for a riser obviously..
    raincloudx
    raincloudx Member
    Dec 18, 2007
    2,109
    Victoria
    Yeah it’s small for a micro ATX, shroud really could be a bit wider/longer for better cooler and gpu compatibility
  4. Kelvin
    Kelvin Member
    Jul 1, 2001
    3,011
    Melbourne 3103
    17.6L.. for a mATX board..
    Definitely, be getting of those, if PLE stocks them at a reasonable price..
    just built a system in this today - 15.7L
    JONSBO A4 - CaseEnd
    Absolutely awful, due to the ITX board I used (X570 PG TB3), tried three AIO, couldn't get any of them to fit..
    except, used the intel L9X65, which simply can't cope with the 3900XT....
    A microATX board, with a "standard cooler" could work a lot better..
    PS.. you are right.. the graphics card height could be an issue...
    raincloudx
    raincloudx Member
    Dec 18, 2007
    2,109
    Victoria
    Reference 6800 series cards will fit nicely :)
    I'll keep an eye out on OCUK/PLE - hopefully not too long before these are available, I do like the look of the case
  6. phreeky82
    phreeky82 Member
    Dec 10, 2002
    9,827
    Qld
    UMX3 is a little bigger but gets better cooling (inc bottom intake breathing space), longer GPU + ATX PSU support, while still staying pretty damn small. I think the V9 looks the goods though if you can live with the GPU length limit, however some taller feet for it wouldn't go astray. It shouldn't be hard finding a quality CPU cooler that'll fit.
    Being really tight, the Jonsbo cases don't really put things in place for good cable management so that's something you'll have to put some effort into.
  7. Kelvin
    Kelvin Member
    Jul 1, 2001
    3,011
    Melbourne 3103
    Available on PLE for pre-order now
  8. Phido
    Phido Member
    Jun 20, 2003
    7,765
    Dark City
    Has anyone built around one of these?
  9. Kelvin
    Kelvin Member
    Jul 1, 2001
    3,011
    Melbourne 3103
    Yes... requires a not too tall video card and a SFX power..
