Kaby Lake/Skylake Overclocking, Info, Delid Guide and Owners thread.
Discussion in 'Intel x86 CPUs and chipsets' started by headin2001, Dec 31, 2016.
  1. AstinGC90
    AstinGC90 Member
    Nov 6, 2013
    537
    FNQ
    Might be worth buying a Kaby G4560 for $75.00 and trying a direct die cool for a laugh with added bonus of the lid you need :leet:
    Better yet a cheap K i3 haha
  2. straiton
    straiton Member
    Feb 12, 2003
    391
  3. mr_mordred2095
    mr_mordred2095 Member
    Mar 9, 2004
    3,891
  4. coolroy
    coolroy Member
    2,346
    Yes but its non conductive which some people require & it still performs much better than a raft of non conductive pastes!
  5. LukeD_NC
    LukeD_NC Member
    Jul 21, 2016
    41
    so here's some food for thought about overclocking:
  6. Ratzz
    Ratzz Member
    Mar 13, 2013
    5,998
    Cheltenham East 3192
    That's fine for those who have a pair of 1080Ti's. Nearly 3000 points difference in physics doesn't make a big dent in a score of 29000 in Firestrike, but its the difference between hero and zero when you only have a 1080 and you are struggling for 20000.
    You too will care about the extra 3000 points when all the non reference 1080Ti SLi setups get into the hands of the overclockers and start making even 29000 seem like pissing in the rain.
  7. LukeD_NC
    LukeD_NC Member
    Jul 21, 2016
    41
    Someone's a little cranky today.
    Why would i care about 29000 points in a test that depicts a GPU load the same as half life 2 ? Anything over 90 fps (or some would say 120fps) and you can't see the difference.
    Why would i care about non reference 1080Ti cards when I'll put mine under water and they'll take up less space and perform within a margin of 1% performance difference and probably suck 5-10% less juice, without having to heal with huge saggy PCB's.
    And just so happens that there's a perfectly timed video of buildzoid talking about 10xx series reference boards and custom boards
    Quote: "We've seen that custom 10 series cards do not clock ANY better than the reference cards so far, again so this does not matter unless you're doing LN2 overclocking..."
    Link: YouTube
    Also, its irrelevant if you're using 1080Ti SLI, 1080Ti or RX480 ... CPU scaling in overclocks will pretty much stay the same.
    Stop being a sour-puss kid and stick to the topic.
  8. Ratzz
    Ratzz Member
    Mar 13, 2013
    5,998
    I'm not cranky, if I came across that way I am happy to apologise.
    You appear to be saying, as far as I can see, that overclocking reaps minimal benefits. My point being, those minimal benefits can mean a lot to some people. I don't even game, so for me those minimal benefits help my only interest.. getting as much as I can out of what I have. I'm an overclocker and PC enthusiast, not a gamer.
    The reference to water cooling is pretty pointless. You think they won't be able to do the same? Take a look at my rig and you'll see I'm well aware of the advantages, and I don't have a reference card either. Actually it might be on a reference PCB, being a Gigabyte, I'm not sure, but its certainly not reference specs.
    CPU scaling remains about the same regardless of the GPU, exactly as you say, which is why I say it makes it less relevant for high end GPU's than low end, because the physics becomes less influential on the total score in the case of a lowly i7.
    I so want a 6950X :( .. now THAT amount of physics would make a difference on your rig.
    Insulting me is hardly the way to have a rational discussion.. and unless you have been on an old age pension for many years you probably shouldn't be calling me a kid.
    I'm interested in knowing just how it is that I have deviated from the topic too incidentally?
  9. LukeD_NC
    LukeD_NC Member
    Jul 21, 2016
    41
    Mate you definitely came off as cranky. Hence my snappy response back to you.
    If you don't game then why do you care about 3d mark scores ?
    The point I was making with the benchmarks is that at some point you're creeping into the area of diminishing returns. It sure seems to be that way with 7700k.
    I am happy running mine @ 5ghz but the extra power draw, heat and cooling required aren't really worth it.
    Delidding mine helped take the temperature down heaps and that was worth it. Being able to overclock over 5ghz was fun, but i dont see the benefit in real world applications.
    I like to fine tune and find a balance between those variables. I spend my money where it counts because I'm the type of person that likes to run the setup I have on a 700 Watt platinum PSU, instead of paying an extra hundred dollars for a 1000 Watt PSU which is completely uncessary.
    Same goes for people that run 2 x 360mm radiators ... there's no point. You're spending so much more money for 1-2% gains. And your components won't overclock much higher if they're running at 35c or 60c.
    And once again a 6950X is useless to a gamer, it doesn't make a gaming experience any better. If you're some sort of designer, graphic artist or movie maker, sure ... but to buy a 6950X just to get a better physics score in 3dmark is a total waste of money imo.
  10. bennyg
    bennyg Member
    Dec 16, 2005
    3,152
    Melbourne, Oztraya
    More proof that if you're delidding and not putting liquid metal under there, why bother.
    The small size of the die surface is the biggest source of thermal resistance in the cpu->ihs->heatsink->heatpipe/loop->rad->air heat transfer process. That's where choosing the most conductive option gives the biggest benefit.
  11. Ratzz
    Ratzz Member
    Mar 13, 2013
    5,998
    Why do I care about scores? Its a challenge. The website is after all called overclockers.com.au.
    I'm the type of person who likes to spend my money on whatever takes my fancy.... but yeah, I run a single 280 rad because its enough. The 7700K actually hits a pretty big wall at about 65C, most people will not get much gain at all if it gets hotter than that. A 280, delidding and conductonaut are a cost effective combination that works very well at keeping temps below that, at high clocks on a 7700K. Its the most amazing consumer chip ever. And I run my system on a 550W Gold PSU, but I don't and never will have 2 GPU's (ITX is a bugger for that).
    Your two GPU's cost more than my whole rig. You want a law of diminishing returns, look no further. How much actual difference to gameplay does that kind of GPU make? The ability to run 100fps at 4k? Why don't you sell one of the cards and play @ 1440? Is it really so much better now that you have spent the extra $1100 or so on FE cards?
    Of course this is your choice to make, and I wouldn't mind having your GPU's. But I can overclock with a C2D and a GTX560 so what I have is more than what I need for what I like to do.. just as what you have is more than what you need for what you like to do.
    A 6950X would be slightly useful to me as I like to mess with cad programs, but not so much that I would ever spend the money on one, not new anyway. I'm not up for changing platforms right now anyway, I like what I have. I would love the extra points for one, but it will have to wait until one day I feel the urge to buy myself a present.
    Your game is BF4 or whatever.. my game is overclocking. I spend less money on my game than you do on yours. I support your choices, they are what turns you on. What turns me on is getting an extra couple hundred points better on a bench than I did the last time with the same rig. Each to their own.
    If the truth be known, I could probably use an i3 and onboard graphics for what I NEED... just like my wifes Haswell rig. What I WANT though is what matters to me, and clearly to you to. We just have different wants.
    I'm still struggling to understand why you think overclocking is only about gaming, and how I'm off topic in the Kaby Lake/Skylake Overclocking, Info, Delid Guide and Owners thread.
  12. LukeD_NC
    LukeD_NC Member
    Jul 21, 2016
    41
    Let's go back to the beginning, because this conversation has gone off on so many tangents.
    The reason I posted those scores was not to brag, even though you made it sound like i was.
    To me, what I wanted to understand by running the benchmarks I did was: Would a 5GHz CPU come in handy if GPU's weren't a constraint.
    That turned out to be false.
    Whilst the gains from overclocking are clearly visible in CPU intensive apps like Cinebench, they are not so clear when running 4k content. The gains are higher when running 1080p content, but what is the point of running 1080p content at 500 fps when you can run it at 4k (with greater detail) at over 100 fps.
    So whilst SLI 1080ti's seems like overkill to you, they are still a bottleneck for 4k enthusiasts out there.
    However, to state that an SLI setup is an area of diminishing returns is not completely true. Sure, not all applications will scale well in SLI, everyone knows that, but the gains are there to be had (especially in higher resolutions):
    I'm not much of gamer myself these days because I dont have much time to game. And no, im not a BF4 fan, I actually don't like FPSs at all. They dont ring my bell.
    And yes, you did go off topic, because I talked about the diminishing returns of overclocking kaby lake for 3d applications in an environment where GPU's aren't a bottleneck, and you went off about how I will care when non-reference PCB's start coming out beating my scores.
  13. mr_mordred2095
    Mar 9, 2004
    3,891
    I can't agree with you. Cities Skylines, going from stock to 5Ghz saw me go from 27FPS -> 30FPS in a heavy zoomed-in scene. Adjusted on the fly for comparison. It certainly makes a difference where CPU is the sole limiting factor :) The ~11% increase in clock speed lead to a direct 11% performance gain.
  14. LukeD_NC
    LukeD_NC Member
    Jul 21, 2016
    41
    Oh definitely. But that's happening for two reasons....
    1) Cities Skylines is a very CPU intensive game
    2) 3 fps is much more noticeable when you're struggling to get 30 fps than 60 fps.
    Just to show you the other end of the spectrum, here are some benchmarks i did today for Ghost Warrior Wildlands. Differences are negligible.
  15. cbwolf
    cbwolf Member
    Dec 23, 2001
    2,322
    The difference of going from 4.5 - 5Ghz will be negligible in most games currently, as most games are currently GPU bound - not CPU bound.
    There are exceptions, where games like Cities Skylines, Attila Total War and some others do see notable FPS increases from CPU clock speed and/or core count.
    What the future holds - who knows. It's certainly not going to hurt to be running an extra 500Mhz on your CPU :thumbup:
  16. mozmo
    mozmo Member
    Jul 2, 2001
    43
    You're only talking about 10% gains at best and that would be in cpu limited situations, currently most games never get to that point with a 7700k @ 4.5ghz.
    I like the 5ghz number but year it's kind of disappointing going to all that effort for very little real world gain. It's not like the days of old when you could get a good 20-30% boost from overclocking.
  17. Ratzz
    Ratzz Member
    Mar 13, 2013
    5,998
    Need a spare 270 board. Or a spare 170 board I guess, but one always strives for more than they need !
    I only want it to test a couple of chips.. not willing to risk my good board in case one in particular turns out to be the mobo killer I suspect it is. Being a 6700K I'd like to make sure its actually dead before I literally bin it..
    I'd also like something I can mess about with in the shed without pulling down my main rig every time I want to try something new..
    So I've been window shopping. OK, I had the filter to cheapest first.. but you tend to keep scrolling.. or at least I do !
    I came across this ROG Maximus IX Extreme E-ATX board. Holy fuck.
    $929 (Pre-order). Apart from an insane Asrock board I remember looking at once, this has to be one of the most expensive mainstream boards I've ever seen. The sad thing is that I'm considering buying it.. truly a thing of beauty.
    Step away from that credit card Kev.... :lol:
    Now to scroll back up and look for that expendable board I started out searching for... but I'll be back..
  18. Supersize
    Supersize Member
    Jul 30, 2008
    1,558
    Gold Coast QLD
    $899 at PCCG
    https://www.pccasegear.com/products/38310/asus-rog-maximus-ix-extreme-e-atx-motherboard
    But what's with PCCG's 6700k/7700k pricing, the 6700k is $21 dearer than the 7700k.. :confused:
  19. nCrypt
    nCrypt Member
    Feb 12, 2010
    1,470
    Many hear with the APEX? Could use a hand trying to get my 7350K to 5ghz, got it running 4.9 no problems, just doesnt want to go to 5.0! (will be delidding the bastard soon!)
    I picked up an APEX today, not bad for only $499
    paired with a 7350K for now, going to get a 7700K at some point.
    i have a Z170 MSI Gaming carbon as well with a G4560 (kaby)
    can test your 6700K if need be.
    6700K old stock, PCCG not wanting to loose money prob.
  20. Jonbanez
    Jonbanez Member
    Dec 12, 2007
    274
    Newcastle
    Well I seem to have done ok in the silicon lottery with my 7700K.
    I followed the Asus overclocking guide to start with (49 multi with 1.30 adaptive vcore) and slowly improved from there. I managed to push it up to 5.1ghz before getting a BSOD on that voltage. Now I've set it back to 5.0ghz and am slowly reducing the voltage.
    I'm seeing some strange discrepancies in the reported voltage, depending on the app I use. Using adaptive voltage seems to overvolt the chip in the order of 0.03-0.04 volts when under load. At first I thought this must be an LLC issue, but adjusting that makes no difference.
    I understand there is a difference between vcore and VID, but I'm not sure which figure to look at. I did some quick research, and apparently it is just a byproduct of using adaptive voltage :confused: I still prefer to use it because I don't like the idea of pumping 1.30+ consistently into the chip, even at idle.
    I'm managing it by setting the adaptive voltage level much lower than my desired vcore, to account for the overvolt. I've managed to creep down to 1.25 so far (which spikes up to 1.29v for some apps), which is Realbench stable with max temps around 60 degrees. Loving this chip! :D
