LAN Addressing Best Practices?
Discussion in 'Networking, Telephony & Internet' started by ewok85, Jul 22, 2012.
  1. plasticbastard
    plasticbastard Member
    Jul 30, 2003
    4,004
    Sector ZZ9 Plural Z Alpha
    Edited. Please delete.
    ewok85
    ewok85 Member
    Jul 4, 2002
    8,097
    Tokyo, Japan
    My users facebook updates are likely the most sensitive data on the network - we don't handle personal information, and all other data is non-sensitive. Email is provided by Google, which is all using HTTPS.
    Yes - we have a public website running from a server in the DMZ (which looks like it was made 10 years ago... because it was), and some random ports open for specific purposes (eg. PHP page hosted on internal server which is used to lookup inventory stock numbers). We have a Cisco ASA 5505 with SSLVPN licences so generally that is used if access to internal resources is required.
  3. Gecko
    Gecko Member
    Jul 3, 2004
    2,715
    The only time I've done an IP renumber was when one of our inherited sites was using 192.168.0.x/24 for servers and was causing hell for anyone connecting into it via VPN from home networks.
    If your subnets are big enough to fit everything in, you don't have IP conflicts across sites and you haven't put ~1,500 hosts into a single subnet (worked at a site that did that - the amount of broadcast traffic was hilarious) then just leave it as is.
    Like others here, I follow a general rule of 10.site-id.subnet-id.host-id/24. Create a new subnet when it makes sense to group devices (VoIP phones are a good example) or if you have specific security requirements.
  4. FiShy
    FiShy Member
    Aug 15, 2001
    9,682
    null route any host addresses that in end in .13, they are bad luck.
  5. PabloEscobar
    PabloEscobar Member
    Jan 28, 2008
    14,678
    +1 To this,
    Also, do not use any switchport or patch port labelled 13
  6. plasticbastard
    Jul 30, 2003
    4,004
    +11eleventy
    Always use port 8, label all your patch ports with the number 8, and only ever use eight port switches.
  7. grommet80
    grommet80 Member
    Oct 28, 2003
    496
    Lismore NSW
    We do more or less the same. We have allocated device ranges too but they aren't subnetted. It used to be different but we've just renumbered as we've rolled out Cisco routers to all the "sites". Wouldn't have bothered otherwise, it was working how it was, this is just neater and it was still a pain in the arse to do.
  8. _omni_
    _omni_ Member
    Jun 17, 2005
    4
    Sydney - 2112
    All that can be ignored if you use gap filler on the last 6 ports on your 48 port switch(s).
    - On topic, cheers for the info etc posted in here, I am currently looking at a similar thing.
  9. OMGguru
    OMGguru Member
    Apr 1, 2003
    3,488
    CFS
    DEFINITELY don't segment into VLAN's too much, as to get between them has to be routed. Either via a router or via a Layer 3 switch (which is basically a router).
    This is not too bad for things like VoIP where the only traffic traversing the 2 networks is probably http management or something, but between workstations and servers, if there are large amounts of data, then it can choke up really quick.
    I like the system you have now, everyone on a 10.x.0.0/16 so locally all traffic is layer2, then traffic to other sites layer3. This is how it should be =).
  10. FiShy
    FiShy Member
    Aug 15, 2001
    9,682
    l3 inter-vlan is done in hardware at line rate, you would run out of port capacity in most cases before you hit the hardware limits.
  11. driver
    driver Member
    3,583
    Correct - a true layer 3 switch doesn't suffer any noticable performance issues like your average router would. Even multicast ghost with server and PC's on multiple VLANs is unaffected.
  12. ltd73
    ltd73 Member
    Apr 14, 2005
    1,724
    your statement may have been accurate/correct in/around the mid 1990s.
    its not true of any half-decent L3 switch.
    the old adage is 'route where you must, switch where you can' does still hold true, but smart network folks don't build large L2 networks.
  13. evilasdeath
    evilasdeath Member
    Jul 24, 2004
    5,025
    It really depends on the year your in, it seams to swap back and forth slowly. You can probably thank Cisco for that.
    Cisco says you should switch your network, everyone buys switches.
    Everyone has switches
    Cisco says you should route your network, everyone buys routers.
    Everyone has routers
    Cisco says you should switch your network again by which time the older switching hardware is behind the times. Rinse and repeat.
  14. chip
    chip Member
    Dec 24, 2001
    3,984
    Pooraka Maccas drivethrough
    Cheers for the tip!
    I try to use /16 or larger subnets. More zeros in the mask = less CPU load in the routers.
  15. ltd73
    ltd73 Member
    Apr 14, 2005
    1,724
    this made me laugh.
    because its actually _true_.
    If you did use a /16 then there are likely less 'strides' to use in a m-trie lookup algorithm, used by pretty much any networking equipment be it hardware or software.
    https://www.google.com/search?q=m-trie
  16. 192.168.0.1
    192.168.0.1 Member
    Nov 18, 2004
    1,540
    Postcode: 2528
    As a rule of thumb
    Enterprise => 10.0.0.0 - 10.255.255.255 (10/8 prefix)
    Enterprise/SMB => 172.16.0.0 - 172.31.255.255 (172.16/12 prefix)
    Home/SMB = 192.168.0.0 - 192.168.255.255 (192.168/16 prefix)
  17. fR33z3
    fR33z3 Member
    Jul 16, 2001
    2,164
    My brain just exploded
  18. IACSecurity
    IACSecurity Member
    Jul 11, 2008
    760
    ork.sg
    That makes you a House then? What is is like being a House?
  19. FiShy
    FiShy Member
    Aug 15, 2001
    9,682
  20. mjunek
    mjunek Member
    Apr 1, 2003
    1,146
    Western Sydney
    This is what we implemented. Each site, datacentre, customer etc, gets a 10.X.0.0 /16 subnet, with that subnet split for VLANs. Head office, for example, has Prod, ESX Mgmt, Dev, Citrix, Demo, Voice and Legacy VLANs, each having their own /24 subnet on the head office site. An edge router does inter-vlan routing, which allows us to control ACLs and vlan-vlan traffic.
    Each site router then connects back into the core networks, which are 10.255.x.x/16. This /16 supernet is basically the OSPF area 0.
    Having each site with its own router and 10.x.0.0 subnet allows decent route summarisation on the ABRs, so route tables around the network contain a smaller number of routes to each site.
