Laser Cutting Requests
Discussion in 'Hobby Engineering' started by oRiCLe, Apr 28, 2015.
  1. MoonShadow
    MoonShadow Member
    May 28, 2003
    272
    If it can be done on a router, then I could give it a go.
  2. Excursion
    Excursion Member
    Jan 22, 2015
    33
    Cheers mate, I have a router myself. Didn't even think to try that tool.
    Will give it a try and see how I go.
  3. psychobunny
    psychobunny Member
    Mar 30, 2006
    2,336
    Melbournish 3750
    single flute upcut bit for a router on perspex, low spindle speed and fast travel, you want to get flakes coming off else it will hear up too much
    for carbon fibre you need high speed low travel setup, dust is conductive so watch your electrics, and you need a hepa filter or you will die
  4. MoonShadow
    MoonShadow Member
    May 28, 2003
    272
    I meant a CNC router.
  5. Excursion
    Excursion Member
    Jan 22, 2015
    33
    Thanks for the advice fellers,
    Will finalise the design and give it a stab!
  6. shazbot83
    shazbot83 Member
    Mar 23, 2010
    97
    Melbourne, 3082
    Hey guys, anyone in Melbourne operate a CNC router that can make nice, beveled holes like these in 3-4mm aluminium?
    I want to add extra ventilation to the top panel of my Enthoo Evolv ATX, but there's no chance in hell I'm attacking it myself with a Dremel lol.
  7. Bastard Child
    Bastard Child Member
    Jan 3, 2006
    3,608
    Crooklyn 3012
    Stepped drill bit and a cordless drill
  8. shazbot83
    shazbot83 Member
    Mar 23, 2010
    97
    Melbourne, 3082
    Would much rather have a machine do it :p
  9. psychobunny
    psychobunny Member
    Mar 30, 2006
    2,336
    Melbournish 3750
    panel and hole size?
  10. wezz
    wezz Member
    Sep 1, 2004
    11
    Some Laser and Water Jet cutters have the ability to add a chamfer to the part. (Ie, they can angle their cutting head)
    The place I use in WA could do that on their water jet cutter.
  11. shazbot83
    shazbot83 Member
    Mar 23, 2010
    97
    Melbourne, 3082
    About 520mm deep, 240mm wide and 20mm high, just eyeballing it as I can't find my tapemeasure (yes, I'm that well organized!)
    Top flat surface is about 195mm wide.
    Maybe 20mm diameter for holes?
  12. psychobunny
    psychobunny Member
    Mar 30, 2006
    2,336
    Melbournish 3750
    Too big for my router sorry
  13. Matthew kane
    Matthew kane Member
    Jan 27, 2014
    1,091
    I've done those sort of holes on my drill press. Not a 100% perfect compared to a machined one but close enough. The important bit is the type and quality of the drill bits you use.
  14. aXLe
    aXLe Member
    1,131
    Looking for someone to supply and cut some acrylic sheeting for me - the largest piece would be 525mm x 425mm - probably around 5mm thickness.
  15. StreekG
    StreekG Member
    Oct 7, 2011
    1,807
    Melbourne, 3165
    I'm not too familiar with laser cutting, but can you achieve a stepped cut around the edge of some acrylic panel for a nice flush side panel window?? Is that more of a rebate type thing?
    oRiCLe
    oRiCLe Member
    May 24, 2004
    175
    Sydney, NSW
    Nope the laser will cut straight through or engrave/etch only, you would need a CNC router or similar to achieve what you are after there.
    Alternatively, you could achieve the lip simply by using a dremel with a router bit clamped to a table and a couple of skate bearings for guides to keep the piece straight :p
  17. StreekG
    StreekG Member
    Oct 7, 2011
    1,807
    Melbourne, 3165
    Thanks oRiCLe.
    Can anyone assist with a laser cutting request i have?
    I purchased a replacement side panel with window from another case, i have removed the acrylic window from it, and wish to get an exact size cutout done the side panel of the case i want to mod, then i can just silicon the case window to the new panel and voila, a very good quality case window mod.
  18. shazbot83
    shazbot83 Member
    Mar 23, 2010
    97
    Melbourne, 3082
    I'm back! Can anyone make me some clear 14 slot cable combs to suit 4mm sleeved cables, pleaaaaaaaaaaaaaaase?
  19. hlokk
    hlokk Member
    Jul 18, 2003
    4,263
    WA
    Not for the finish in the picture above ;)
  20. Exodus_AU
    Exodus_AU Member
    Feb 17, 2012
    136
    is there anyone in western sydney who would be keen to come service my laser? its an 80w black and red
    or know any companies that do it?
