Laser Cutting Requests
Discussion in 'Hobby Engineering' started by oRiCLe, Apr 28, 2015.
  1. m3k
    m3k Member
    Dec 29, 2007
    689
    yea ill do it man hit me up
  2. Butcher9_9
    Butcher9_9 Member
    Aug 5, 2006
    2,182
    Perth , East Vic Park
    If only you were in Perth :( . Been eyeing one up for ages.
  3. kot0005
    kot0005 Member
    Nov 11, 2011
    696
    melbourne
    Its sold now :)
  4. bliaker
    bliaker Member
    Oct 30, 2004
    385
    Hi there,
    I'm working on an automated rotating platform using a stepper motor and an arduino and I'm trying to figure the best way to rotate it using gears. I have the arduino/stepper motor part of the equation sorted, but what I'm looking to do now is mount a large gear to the rotating platform and the stepper motor with a smaller gear to the mount.
    Like this:
    https://geargenerator.com/#725,475,...,1,0,0,0,0,0,23,5.75,4,20,0,0,0,0,0,0,1,3,-47
    I note that theres a 3D print request thread on here but I'm not sold that plastic is the best material for the gear and unsure how gunky the gears would come out. Would anyone on here be able to quote me on a CNC of some aluminium gears at 3mm or 4mm thickness? Looking at 110mm diametre for the gear so a 150mm sided square of material is all that would be needed. I can also provide a file for CNC from the above generator but it might be easier using your own workflow/gear plugin for whatever setup you use. A workflow I was looking at can be seen on youtube here
    Not fussy on the ratio as I'll adjust to suit within the ardunio and speed isn't such an issue.
    Recommendations are very welcome :) Thanks gang
  5. ericks
    ericks Member
    Nov 3, 2012
    83
    Hi...i have made gears from acrylic, nylon and poly carbonate. Not sure how good aluminium would be. I can machine both plastics or aluminium:)
  6. markgabriel
    markgabriel Member
    May 9, 2010
    23
    Are you capable of machining a Distro plate?
  7. ericks
    ericks Member
    Nov 3, 2012
    83
    In Aluminium?
  8. m3k
    m3k Member
    Dec 29, 2007
    689
    https://hackaday.com/2018/05/15/hawkeye-the-3d-printed-tourbillon-movement/
    3d printed gunky gears ;)
    also most older 3d printers rely on 3d printed gears to run :p
    u dont want anyone printing it though- You need a decent printer and good self lubricating plastic if you want long use parts that are small.
  9. akashra
    akashra Member
    Apr 25, 2003
    3,799
    Melbourne, AU
    If I were to get/pay someone to laser-cut me some prototypes from 300gsm cardboard and design the files for it, what changes would I have to make to be able to take that design and give it to a commercial company to then cut that on say 0.5/0.8/1.0mm aluminium/stainless steel?
  10. dirtyd
    dirtyd Member
    Jan 4, 2006
    4,016
    Melbs
    Pretty much nothing depending on how accurate you need to be (eg, width of cut might differ). Most places will accept DXF, PDF, AI
