LED Flashlights.. CREE, Xenon and Luxeon, oh my!
Discussion in 'Other Toys/Hobbies' started by damnation, Oct 17, 2007.
  1. Scratch2k
    Scratch2k Member
    Jul 15, 2002
    833
    I personally like this, for under $20 shipped, it can't be beaten.
    http://www.dealextreme.com/p/trustfire-tr-b3-cree-led-flashlight-with-clip-3-cr123a-11919
    It is super bright, very well built, cheap and runs on CR123A's. I have 6 of these spread around my house, you know, in case of zombies.
  2. okisub
    okisub Member
    Apr 6, 2006
    322
    I love this customer review on DX of that torch:
    "Cons:My wife says this torch is "almost too bright". Are you crazy? Get back in the kitchen and make me a sandwich, there's no such thing as "too bright"! "
  3. ChaosMaster
    ChaosMaster Member
    Jul 30, 2010
    1,302
    Vic, 3175
    Lolz, very nice. But any actual comparison shots of it? How's it compare to a Fenix Tk35? Or P7? Or even my new toy, the XTAR A01 (has really nice throw, and is bright, out does my Quark 123^2 by miles and build quality is solid).
  4. Gierke
    Gierke Member
    Dec 27, 2005
    2,071
    Earth
  5. ChaosMaster
    ChaosMaster Member
    Jul 30, 2010
    1,302
    Vic, 3175
    Well, I've just recieved my XTAR A01. Solid build, very good price. 400ANSI Lumens, and it seems like it too. Did a bounce test, torch on table, lit up the room like a 40w light bulb. The way I like it. Only conern with these UltraFire's is that while they claim 900 Lumen, that's not ANSI, it's not even OTF. So I'm just wondering, if it's really worth paying for it? What do you guys think.
  6. Kyl3
    Kyl3 Member
    Jul 13, 2005
    3,035
    The Hunter
    I'm looking for the best damn headlamp torch out there, I currently have a led lenser h7 but it burns through the AAA's.. :( I've considered the rechargeable version but before i get work to buy it for me i thought i should do some research...
    Cliffs: Must be mounted to my hard hat
    Anyone got any recommendations? :)
  7. NanoDuke
    NanoDuke Member
    Feb 4, 2007
    7,630
    If it's for work, and they can pay for it or you claim by tax, then I don't think you can go past ..... ....
    Ah fuck. I can't for the life of me find it now.
    It was a heavy duty industrial one. Suited to miners.
    Not Princeton Tec, and not Petzl....
    They were exxy, and out of the reach of your everyday flashaholic.
  8. tornado33
    tornado33 Member
    Mar 31, 2003
    6,991
    Newcastle
    Got this 900 lumen LED torch yesterday. They say 1000 but its a 900 lumen LED and actually isnt quite driven to full power anyway, which is good for longetivity
    It has an interesting regulation built in. There is a click switch at the end, each time power is turned off then on, one of 3 modes happens. That is full power, lower power and rapid blinking.
    I put a multimeter across the end, and it draws about 1.35 amps at full power, and 0.3 at low power.
    Only bummer is battery is wrapped up in the holder so the charger can be plugged into it direct, though Im sure if the battery dies in the future I can get it out and put in a new one.
    When in low power mode if I hold it near my ear I can hear the hum of the thyristor or whatever its called that reduces power, by chopping it at several kilohertz, if I wave my fingers through the light I can just see the strobing, its very fast though
    Even on low power it is quite bright and adequate for general use. Its fairly well sealed with O rings though I wouldnt fully immerse it in water.
    Supplied charger finishes charge at 4.21 volts, apparently 4.2 volts is the correct value to cease charging of that type of battery.
    http://www.rathboneenergy.com/batteries/battery_cells_by_mfg/sanyo/sanyo_lion_pdf/UR18650F.pdf
    To make the cell last many more cycles I will stop charging when it gets to around 4.0 volts. Also will try and avoid deep discharges too, as mentioned here
    Overall Im happy with what I got for the money
  9. Scratch2k
    Scratch2k Member
    Jul 15, 2002
    833
    lol, check the username on that review :)
    As for a comparison, I would do so but I have nothing to compare it to other than one other decent DX torch (http://www.dealextreme.com/p/romisen-rc-f4-gitd-cree-flashlight-black-3v-8v-3386) which isn't quite as bright but a bit more compact for carrying around.
  10. ChaosMaster
    ChaosMaster Member
    Jul 30, 2010
    1,302
    Vic, 3175
    Then thing with rated Lumens, from generic brands, is that their far from the truth. 900lm is what the P7 is capable of, and at cold temps. Test have shown that OTF lumens are closer to 550lm, or 400 ANSI Lumens, there about. XML based are brighter, and thus P7 are going fairly cheap now. Having said that, $15 for 400 ANSI lumens ain't bad at all.
  11. booboo
    booboo Member
    Sep 13, 2003
    498
    recently got a tk45, really impressed with it too. Ive also used it on my bike for some mountain roads where there's no street lights for about 7km's. just need to find a better mount cause its 39mm diameter makes it a bit harder. the twofish block works but being made from rubber it moves around a bit over bumps. going to try cable ties on a normal handle bar mount....but anyone got any better mounting idea's? a mount that works like this but more solid https://www.fenix-store.com/product_info.php?cPath=92&products_id=274
  12. Gierke
    Gierke Member
    Dec 27, 2005
    2,071
    Earth
    Are you referring to the LD01? I recently got one for work and it's great!
  13. ging
    ging Member
    May 9, 2006
    150
    I've heard pretty good things about 4Seven's Preon 1:
    http://www.4sevens.com/index.php?cPath=297_332_366
    though the S2 model in black (the one i'm after) has been sold out for a while so no hands on experience with it yet.
  14. dualmassager
    dualmassager Member
    Aug 11, 2009
    1,028
    If anyone needs 18650 cells with high discharge rates (10A+), drop me a PM.
    I have some A123 Systems LiFePO4 cells.
  15. Arg999
    Arg999 Member
    Aug 23, 2002
    363
    Briss
    http://www.foxfury.com/
    Was it these guys?
  16. NanoDuke
    NanoDuke Member
    Feb 4, 2007
    7,630
    Interesting... would these be suitable for torches? Do they get hot?
    Close but no dice. The website was pretty poor. Circa 1990's coding :p
    Maybe the company has disappeared.
    This is the closest "cap lamp" I could find
    http://www.nltinc.com/GII_Miners.html
    Designed for rugged environments.
  17. borked
    borked Member
    Apr 9, 2008
    651
    Interested in more info :)
    Lupine
    Mammut
    Silva
    Any of those ?
  18. NanoDuke
    NanoDuke Member
    Feb 4, 2007
    7,630
  19. dualmassager
    dualmassager Member
    Aug 11, 2009
    1,028
    Unfortunately, the main problem with LiFePO4 cells for torches is that they have a lower capacity compared to, say, a Samsung or Panasonic Li-Ion 18650. Only 1.1 Ah rating at a nominal voltage of 3.3/3.2v. However, if you have HEAVY USE, these batteries have a very good lifespan. 100% DoD (Depth of Discharge) and A123 claim over 1000 cycles. Up to 2000 cycles I think with 50% DoD.
    These don't heat up as much as Li-Ion + more tolerant of temperature than Li-Ion.
    Also, if you fear you get you torches crushed and it has Li-Ion batteries (Li-Ion + Damage = Fire/Explosion), LiFePO4 is tolerant to punctures, damage etc. without causing fires.
    Also, much more tolerant of over-charging and over-discharging, and higher discharge and charging rates (discharge up to 30A continuous, 65A peak for 10 seconds; charging max rate at 5A (3.6V), recommended charge rate of 1.5A).
    For the same price of 1 decent Li-Ion 18650 cell, you can get 3 LiFePO4 cells. So, cheaper as well.
  20. PhilDee
    PhilDee Member
    370
    Geelong, Victoria
    My new Fenix TK41 just arrived. Was trying to find the best AA powered torch I could and this seemed like it.
    Very impressed so far, I've had a Fenix L2D for years which has been great but this one makes it look quite dull.
