LG 1730s - "Problems"
Discussion in 'Video Cards & Monitors' started by Reaper, Jul 3, 2008.
  1. Reaper
    Reaper Member
    11,748
    Brisbane, Qld, Australia
    Q at bottom, story first.
    Ok, so I get this monitor today with the fault that the picture "goes on and off" So I bring it home, plug it into my laptop and fire it up. Sure enough, it flashes off and displays the monitors logo, then returns to the display. It's as though it's putting itself in standby mode.
    It does it a few times more randomly, then after a while, it's all good. The monitor stays on, I play a wide variety of games on it, all good.
    I then actually turn it off at its power button and go have dinner. I come back and turn it on, and it does the auto sleep/wake up thing a couple more times randomly, then after a bit, rock solid again.
    So, my Q is, has anyone had this happen before? And am I right to suspect a signalling fault? Should I suspect a dry joint on the monitor connector within the monitor itself?
  2. Cycle86
    Cycle86 Member
    Jun 19, 2005
    19
    Brisneyland
    i found an lg L1750SQ at the dump a few months back it had the same problem straight away i thought it was bad caps, so i open it up and bam 1 swolen cap, so what i did was swap the bad one for a good one (of the same value) that was in the circuit and it worked fine after that but its only a temporary fix, so to answer your question... you have bad capacitors if you google the issue you should find other people that have had the same problem its a pretty easy fix if you can solder
    Reaper
    Reaper Member
    11,748
    Hey thanks man. :)
    I had it open today too and yea, I know I should have looked at the caps better. Was it on the power board, or the logic board for you?
  4. Cycle86
    Cycle86 Member
    Jun 19, 2005
    19
    Brisneyland
    cant remember exactly but i think it was the logic board, there is about 6 caps on there
