[WORKLOG] Lian Li V3000 Plus | Hardline
Discussion in 'Extreme and Water Cooling' started by QuinRiva, Nov 27, 2023.
  1. QuinRiva
    QuinRiva Member
    Nov 16, 2006
    132
    I'm migrating from my venerable TJ07 into a new case, and putting together my first hardline build. So thoughts & advice would be much appreciated.
    One of the main issues with my current build, is that there is substantial galvanic corrosion and some sort of leakage. I'm pretty certain that everything is Nickel/Brass/Copper, and yes I know that Nickel copper will still form a galvanic cell, but the amount of crap in the system seems excessive. I have used some coolant in the past, but due to some weird leak, I've mainly just been topping up with distilled water.
    The leak issue - this confuses the crap out of me, I'm topping up like 50-100ml every few months. I've run coloured coolant, wrapped everything in paper towel, and then pressure tested - and the only thing that isn't airtight is the fillport on the reservoir. It's just hard to believe that so much water could evaporate out of that.
    Anyway, this is part of the reason for replacing just about everything in the build (combined with a bunch of components being 10+ years old). I'm basically just keeping the CPU block and the pre-installed motherboard block. The CPU block should be easy to clean, but not sure how I would go about cleaning the motherboard block?
    This time I plan on using a proper corrosion inhibiting coolant.
    Some parts are coming over from the TJ07, some slightly used second hand parts, and some new.
    Some renders of the proposed loop below. A few things to note, the GPU block dimensions should be accurate, but I was too lazy to fully model it; radiators in the render are EK Coolstream Classic, rather than EK Coolstream; the V3000 model is missing the bottom side radiator mount plate, so the radiator appears to just be floating, but it should be in roughly the right spot.
    Bottom rad connections:
    https://imgur.com/a/Nnxg0dS
    Agg, brayway, juzz86 and 1 other person like this.
  2. h2oxide
    h2oxide Member
    Dec 9, 2009
    4,633
    Subbed for the nostalgia... mmm dat sweet late 2000s TJ07 meta
  3. Wacko02
    Wacko02 Member
    May 26, 2003
    1,231
    that system is begging for a CPU upgrade! :lol:
  4. OCGear
    OCGear Member
    May 21, 2023
    55
    Apparently Go Chiller has a 5 year operating lifetime coolant; the "Ultimate". Haven't used it myself, but I could smell the corrosion inhibitors in their standard formulation.
    Btw, you'll need to attach the Leakshield on top of the res, or some place with an air gap as I think it needs at least 100ml of air. (Also got some in stock in case Aquacomputer is still out of stock.)
    QuinRiva
    QuinRiva Member
    Nov 16, 2006
    132
    I do game exclusively at 4k, so I'm not entirely sure the benefits are worth it at the moment (I'd need to replace the motherboard and RAM too). I know at lower res there's a more substantial gap, but at 4k?
    But for rendering, I mean, I guess I'm maxing it out....
    kimbecause and modernshoggoth like this.
    QuinRiva
    QuinRiva Member
    Nov 16, 2006
    132
    Ended up ordering it from Germany, I couldn't find a local source for a waterblock for my Zotac RTX 4090, so I was already paying the $180 shipping :upset:
  7. OCGear
    OCGear Member
    May 21, 2023
    55
    Funnily enough... I did order in a 4090 for the Zotac, but I got sent an MSI unit instead. The challenges of being far away from the rest of the world.
  8. juzz86
    juzz86 Member
    Nov 15, 2013
    2,771
    Forth, NW TAS
    I initially looked at the specs and thought the same as Wacko, but after pondering it a bit I don't reckon it'd be at all bad in 'real' usage.
    A 5800X3D would plug straight in (no new board or RAM) and sort any low-99% issues you were having - I noticed a little jump (~5-9FPS) overall coming from a 3700X, but it was the 'smoothing' of the FPS trendline that was the clincher - 95% of the troughs were gone. In ARK especially.
    I'm at 3440 though, so not quite 4k.
    Wacko02 likes this.
  9. MAdMungo
    MAdMungo Member
    154
    One thing to check regards the slow leak is the radiators. I used to have a pair of old 240 rads and one of them developed a pinhole leak from one of the fan screws butting up against one of the tubes. I suspect it was caused by vibrations in the machine over the 5-6 years it was in use, as it was about 6 ish months before upgrading that I too was filling my res every 3 weeks.
    Regards your loop, I would run the output of the gfx card through the top rad before going into the cpu/vrm cooler.
    QuinRiva
    QuinRiva Member
    Nov 16, 2006
    132
    It's a bit tight, but I should have enough room at the top of the reservoir (provided I only half fill the reservoir).
    brayway and Spyder6052 like this.
    QuinRiva
    QuinRiva Member
    Nov 16, 2006
    132
    Soooooooooo many fittings:
    Rupet2019, brayway and tunksy like this.
    QuinRiva
    QuinRiva Member
    Nov 16, 2006
    132
    Finally an update!
    Cleaning
    Plastic cover removed from the motheboard, exposing the block - 16 screws!
    Disassembled the mobo block - weirdly not a lot of (visible) build-up, which is great because this would have been a bitch to clean. I scrubbed it and got a bit washing out, but given the gunk was copper in colour, it's a bit hard to see.
    The acetal was much easier to clean as the gunk was clearly visible:
    Forgot to take a photo of the CPU block - but the underside of the jet plate was packed full of gunk.
    Here's the CPU block and mobo cleaned and reassembled. I cleaned dust from the chipset fan too.
    Reassembled the Velocity CPU block - I forgot that I had some Themogrizzly Hydronaut and ended up using some Artic Silver 5. Wondering if I should disassemble and re-apply the better paste?
    QuinRiva
    QuinRiva Member
    Nov 16, 2006
    132
    GPU Block Assembly
    This thing weighs a tonne - Alphacool Core GeForce RTX 4090 AMP with Backplate
    Retention bracket removed from card:
    Board opened up:
    Underside of the Alphacool block:
    Comparison of thermal pads between the Zotac air cooler and the Alphacool waterblock - weirdly, there were no pads for the top of the coils - should I be concerned?
    Although there was one additional pad for this chip:
    Hey look I found the thermogrizzly!
    Paste applied
    The backside had loads of pads though - weird given that the Zotac had bugger all on the backplate:
    And making sure that I removed all the plastic!
    Alignment as a bit of, so had to loosen the retention screws a bit and adjust
    Fully assembled:
    Rupet2019 likes this.
    QuinRiva
    QuinRiva Member
    Nov 16, 2006
    132
    Assembling the tubing
    Not sure how I screwed up this dimension - but I must have had the radiator at the wrong height? I had to use a 41-69 telescopic fitting instead of the 22-31 telescopic fitting.
    Model for comparison:
    I spent ages trying to find the 41-69 fitting for the CPU, only to realise I had used it above - so had to improvise:
    The model was also a tad off on the height difference between the CPU block and the mobo block - CPU block was apparently 2.5mm taller than the Mobo block, so I would need to adjust by adding a 7.5mm extender and a 10mm extender to make them the same height. I think the mobo model is missing the lip of the block attachment, which means that they are actually the same height.
    Main fittings in place
    I picked up some nice corsair tubing on the cheap ($9 for 3m) so am trying that out. It certainly cuts much more smoothly, it isn't as brittle when reaming the ends - but being matte white, it's really easy to scuff.
    Not a perfect run here, but I always new this would be tricky - it looks like it's a single bend, but it's actually a bend and twist (two bends)
    The other tricky bend was from the outlet of the reservoir to the front radiator - again it looks like a single 45 degree bend, but it's actually bending in three dimensions.
    I didn't like the leakshield being obscured by the the pipe in front - so I made this contraption - not exactly straight:
    Tried re-bending it a bit - a bit straighter
    But there's bit of flex between the pipe, the fitting and the reservoir mounting
    Realised I hadn't modelled in a drain port - so added that in
    QuinRiva
    QuinRiva Member
    Nov 16, 2006
    132
    Leak testing!
    I ran it overnight and didn't encounter any leaks, but better to pressure test. I took the leakshield back off, and tightened all the fittings.
    Pressure at 11am
    And pressure at 3:30pm
    So happy that it's holding pressure!!
    Decided to replace excess soft tube in the bottom of the case with a quick connect - this way I can drain easily without having 50cm of extra tube just lying around.
    QuinRiva
    QuinRiva Member
    Nov 16, 2006
    132
    Final system prep
    I ran some Go Chiller Prep-Cool - I'm not entirely sure this was necessary, but really wanted to make sure that there was no gunk in the system. Ran this for 10 hours, drained the system, then added deionised water and ran overnight.
    Drained the system, now it's time to add the final coolant - I don't want anything staining or gunking up the system, so just running clear.
    I was surpised that it started going cloudy within about 30 seconds of adding it to the reservoir, before I even switch the machine on to start circulating things? Also, as soon as I turned the machine on it really started foaming. I figure this would clear up over time.
    Ohhhhhh so wrong...... I turned the machine off after running for a couple of hours, and this is what it looked like in the morning:
  17. h2oxide
    h2oxide Member
    Dec 9, 2009
    4,633
    There's no pic
    QuinRiva
    QuinRiva Member
    Nov 16, 2006
    132
    Image added above.
    Cabling
    This still needs a bit of work - I want to buy some custom cables. For example, I have a 60cm daisy chain molex cable for running the Octo, but a 30cm cable with a single connection would reduce the cable clutter.
    8 pin is fine, but I don't have red cabling for the 4 pin.
    Comb on the 24 pin spreads things out a bit much - also need to replace this cable, as it's an extension and I end up with waaay to much cable on the rear.
    Sata connectors are all a bit loose - the cabling is quite tight on them, so they are being pulled a different angles:
    Rear is a bit of a mess still. I can't for the life of me figure out where to mount the Octo, maybe just double sided tape?
    So much excess cables....
    brayway likes this.
  19. h2oxide
    h2oxide Member
    Dec 9, 2009
    4,633
    If you're open to suggestions, modDIY cables are high quality and more affordable than the likes of CableMod.
    QuinRiva likes this.
    QuinRiva
    QuinRiva Member
    Nov 16, 2006
    132
    Ran some benchmarking and I'm not happy with the temperature on the GPU (crashed within 30 seconds):
    • CPU: 33C idle, 60-70C under Prime 95 - I think this is pretty reasonable
    • Motherboard: 33C Idle
    • GPU Core: 28C Idle - 90C under Cyberpunk load
    • GPU Hot Spot: 38C Idle - 112C under Cyberpunk load (before crashing)
    Clearly something is wrong with the GPU mounting.
    I pulled apart the GPU block to clean the gunk - honestly it wasn't too bad, and it wiped away pretty easily. I probably didn't need to actually pull it apart.
    All cleaned up - really annoyed that Alphacool used adhesive to secure the in/out plate :( Not cool.
    Pressure tested for 17 minutes - no drop
    Clearly the die isn't making good contact:
    I wiped off some excess thermal paste and smoothed out the remainder
    I also noticed that I missed taking the plastic cover off one of the thermal pads on the backside. Weird because I was counting them as I took it off to make sure I didn't miss any, and I even took photos to makes sure too. But all corrected now.
    Flushed the system 5 times - this is my bucket - it's actually quite blue, but looks grey in the red bucket.
