Logitech G Owners and Discussion
Discussion in 'Overclocking & Hardware' started by Akh-Horus, Aug 20, 2010.
  1. MR CHILLED
    MR CHILLED D'oh!
    Jan 2, 2002
    162,444
    Omicron Persei 8
    Use a good mouse mat and there shouldn't be any lint build up, not even on mouse feet with modern mice.
  2. CAPT-Irrelevant
    CAPT-Irrelevant Member
    Sep 7, 2007
    7,658
    Big update with release 2022.7.
    And for the changed layout.
  3. Current
    Current Member
    Aug 10, 2021
    1,245
    Does anyone else have the issue where logitechs software just sits on loading forever?
  4. Will S
    Will S Member
    Aug 15, 2003
    6,264
    Coniston (Wollongong)
    Oh yes...just happened so I gave it a nice one start rating ..that L just goes around and fires blanks
    Have a new mouse ...made a mistake and getting it...MX Master 3 ..the side buttons are just hard to access but the scroll wheel is good for sound control
    The have defintely taking the lead from Gigabyte and Logitech in the bad software stakes....jeez, even iCue is better then those 3
    walker_2003 likes this.
  5. walker_2003
    walker_2003 Member
    Jan 15, 2003
    13,884
    I had to stop using iCue as if was causing pubg to crash.
    Just ordered a G pro superlight X to replace my G pro wireless. Keen!
  6. Will S
    Will S Member
    Aug 15, 2003
    6,264
    iCue was terrible a few years ago......if you had problems with your PC it was sure to be iCue but then it came good and was the best I have used for my fans.
  7. walker_2003
    walker_2003 Member
    Jan 15, 2003
    13,884
    yeah a shame it still messes with PUBG.
    I moved to signalRGB which covers all my devices nicely.
  8. mareke
    mareke Member
    Jun 1, 2003
    8,004
    Sydney, NSW
    A few days ago I bought a new Logitech G703 Lightspeed Wireless Gaming Mouse on eBay sealed in the factory box for $79 including free postage. Another eBay seller has it for $232 while EB Games sells it for $189.95 and JB Hi-Fi for $190. I bought it because it's heavy rather than light and you can use it corded or cordless. I've never liked a light mouse but I'm not a gamer. It's basically identical to my Logitech G403 except that you can charge it wirelessly using a charging mat (which I won't get because it's too expensive). The battery in my G403 went dead years ago but it still works with the cord attached. I could buy a replacement battery on eBay but I'd probably break the mouse trying to open it to reach the battery.
  9. MR CHILLED
    MR CHILLED D'oh!
    Jan 2, 2002
    162,444
    Omicron Persei 8
    Nope, never had that issue.
    New software is actually ok, quite zippy for me and probably a little more intuitive than previous. Looks all fairly much the same for my G502 on the sub screens though.
  10. Jaff
    Jaff Member
    Apr 10, 2002
    7,595
    Hawkesbury, NSW
    Picked up a new G512 to replace my old G512... except this time went with the linear keys for the quieter noise levels (didn't bother me but nobody else was a fan - was bought pre-WFH).Feels very nice and very slick. Not sure why so many reviews commented it wasn't a great board to type on. It's almost perfect for me. Also picked up a Pro X headset the other week - also a very nice piece of kit.
  11. s4Rg3
    s4Rg3 Member
    Jun 15, 2002
    808
    4160, QLD
    Nice one! I might have to try the G512, not overly a fan of this EVGA Z20 cheap kb, keys keep getting stuck and weird squeak with the space bar already.
    When I first installed the Pro X I thought they were shite, until I chose a preset and was far more impressed
  12. Sphinx
    Sphinx Member
    Sep 16, 2001
    10,707
    That's the GX BROWN instead of the GX BLUE switches right?
  13. Tinian
    Tinian Member
    Jan 3, 2009
    20,504
    15.0° N, 145.63° E
    My G910 has started developing sticky keys. I'm wondering if I should pull it apart for a deep clean?
  14. Jaff
    Jaff Member
    Apr 10, 2002
    7,595
    Hawkesbury, NSW
    GX Red instead of GX Brown. My old G512 had the tactile keys - and that wasn't by choice it's just what happened to be on the shelf at 50% off at the time, and I didn't have much idea on mechanical keyboards at the time.
    GX Blue (Clicky), GX Brown (Tactile), GX Red (Linear)
    Sphinx likes this.
  15. macktheknife
    macktheknife Member
    Jul 26, 2005
    2,424
    Sounds like it for sure. Pull the keys and soak them in soapy water, dry them, get out a paintbrush to clean the board and use some rubbing alcohol if there's any stubborn stains left.
    Tinian likes this.
  16. mareke
    mareke Member
    Jun 1, 2003
    8,004
    Sydney, NSW
    Got my Logitech G703 mouse a couple of days ago that I bought on eBay. Was it new sealed in the box as the seller claimed? Maybe but maybe not. The seller owns a pawn shop and the sticky tape sealing the box was only round on one end instead of completely round like you usually see on boxes. Nevertheless it looked new or close to it and the price of $79 was too good to pass up.
    The first thing I discovered on trying the mouse was that the Logitech gaming software I used with my G403 mouse didn’t see the G703 so I couldn’t configure it to behave the way I wanted. This meant that I couldn't stop the lights in the mouse cycling through a range of colours or configure the buttons or the DPI setting. Then I discovered G HUB at the Logitech website and on installing it I found a way of configuring the lighting in the mouse the way I like as well as making the buttons to do what I wanted. G HUB isn't easy to use and you have to play around with it to figure out how to configure the G703 mouse.
    I also discovered that the USB sender unit for the G703 to make it work wirelessly was specific to the G703. The G403 mouse looks identical to the G703 mouse but the sender units for each mouse are specific to each mouse. Overall I'm happy with the G703 but anyone who isn't computer literate would be pissed off if they didn't like the lighting constantly cycling through a range of colours and couldn’t work out how to configure the mouse using the convoluted G HUB program.
  17. Tinian
    Tinian Member
    Jan 3, 2009
    20,504
    15.0° N, 145.63° E
    Did as you suggested and it's working like new. :thumbup:
    Just a build-up of dust and hair (hopefully more cat than mine).
    macktheknife likes this.
