Looking for new fish tank
Discussion in 'Pets & Animals' started by Alson, Nov 28, 2012.
  1. Alson
    Alson Member
    Jan 29, 2012
    19
    Hi guys,
    Just letting you guys know I'm a complete newbie in this area :)
    Looking to buy a fish tank built into a stand. I've been looking at custom built tanks, and also Aqua One tanks. I'm currently after tanks that look like the Aqua One tanks, but without the price tag...it is pretty pricey.
    Can you guys recommend a place where I can buy tanks that look like the Aqua Ones? In particular the AquaReef/AquaGrande range. I'd be looking at getting something around 5ft
  2. shane_3800
    shane_3800 Member
    Mar 20, 2012
    41
    Fish tanks are pricey get used to it if you like fish.
  3. jayc
    jayc Member
    Aug 20, 2001
    1,156
    What price is pretty pricey? What's your budget?
    The Juwel and Jebo brands are possible alternatives to the AquaOne.
  4. shane_3800
    shane_3800 Member
    Mar 20, 2012
    41
    Those brands are alternatives but if the initial price of the tank is to much then you have no idea on the cost of setup Ie: filter gravel plants fish then there is the cost of maintenance which over a year can add up.
    Alson
    Alson Member
    Jan 29, 2012
    19
    Initially at looking to spend under $1000. Thanks for the brands, I'll look into them. I've found them stocked at thereefshop and amazingamazon. Do you guys have any other suggested places I could check out? I've just discovered a forum with a selling section, so I might search for those brands there.
    Yeah, I know how costly it can all add up to be. It's just the initial cost for the tank that I was trying to cut down a little bit because AquaOne shocked me quite a bit.
    Cheers guys
  6. Buc Nasty
    Buc Nasty Member
    Mar 9, 2006
    99
    have a look at petbarn if u want a name brand tank. first item is 20% off if u join their free membership, so its a big discount for a large tank, making them cheaper than any store that i've found. their range isnt huge but plenty of Aquaone tanks.
  7. jayc
    jayc Member
    Aug 20, 2001
    1,156
    I would suggest getting a standard tank and going down to a 4 footer.
    Like this one from amazingamazon
    http://www.amazingamazon.com.au/aquariums-melbourne-fish-melbourne-337.html
    It's just such a huge jump in price when going to a 5 footer.
    Even accessories like lights have limited choice for a 5 footer.
    It's easier finding stuff for a 4 footer.
    Going with a standard tank, you get to choose your own lights & filter canister which is a normally going to be better than the built in equipment from AquaOne, Jebo or Juwel.
    Also check out Aquariums R Us.
    http://www.aquariumsrus.com.au/
    Who do package deals or choose from a large selection of sizes and stands or cabinets.
    You can even customise a Starfire glass front panel for extra $$ to give you the ultimate clarity.
    Alson
    Alson Member
    Jan 29, 2012
    19
    Thanks for that. Sorry I just realised I didn't mention that I'm after a tank around 4ft. They don't seem to have any tanks of this size.
    Like I said above, I totally forgot to mention that I was after a 4 footer :)
    The only reason I'm going for these branded tanks like AquaOne/Jebo/Juwel is basically because of the design of the stand/cabinet. The tank that you mentioned has a great price, but I honestly don't think it looks very nice and modern, and definitely wouldn't fit in well with my home...Unless...I buy a tank and cabinet separately. I haven't really thought about this yet though
  9. killedbycrimson
    killedbycrimson Member
    Apr 15, 2006
    1,233
    Renmark South Aus
    I got mine made at a glass cutter shop. cost me the price of the glass and an hours labor.
  10. Buc Nasty
    Buc Nasty Member
    Mar 9, 2006
    99
    I got my 4ft Aquaone horizon from there, was only under $400. pretty sure they got them..maybe try another store
    Oh and if you're in Melbourne, try coburg aquarium, a lot of tanks there or aquascape(name?) in Richmond, they have modern style tank/cabinets that seems to be fairly well priced.
  11. Daft_Munt
    Daft_Munt Member
    Jan 23, 2003
    7,691
    Hobart, The Federal Group
    I suggest you have a good look at the stands/cabinets and what they are made of eg MDF which isnt the most water friendly thing to use in a tank stand. Also check this thread out. I prefer the euro style tanks and dislike the effect one gets with curved glass.
  12. jayc
    jayc Member
    Aug 20, 2001
    1,156
    Gotta agree with that. The curve glass makes viewing the fish unnatural.
  13. Sleepy Dude..
    Sleepy Dude.. Member
    May 5, 2008
    1,669
    Parramatta,NSW Status:MIA
    Send Kosti a PM. he has quite a few tanks that he is looking to get rid of.
  14. 5p1k3y
    5p1k3y Member
    Feb 12, 2008
    304
    buy a used one from Petlink mate. So more worth the money than a brand new tank. Stay away from aqua one tanks they are pretty poor quality especially the stands.
    If you want a 5ft tank and want a new one get one from abyss aquariums they build very good tanks. Try and specify for black silicon, beveled edges and 10-12mm glass for the tanks. It will look stunning.
  15. yoda123
    yoda123 Member
    Apr 17, 2003
    2,791
    QLD
  16. aL4n
    aL4n Member
    Aug 18, 2003
    714
    Cade or ADA tanks is what you want.
