Low cas 3600 memory and Ryzen
Discussion in 'Memory' started by {V|PER}, Jul 29, 2018.
  1. OP
    {V|PER}
    {V|PER} Member
    Oct 18, 2006
    496
    Ballarat
    Yeah i've seen OC3D remove that filter frame in their tutorial on water cooling in the fortress. Good idea on a magnetic filter variant!
    {V|PER}
    {V|PER} Member
    Oct 18, 2006
    496
    Ballarat
    What are the chances of buying another 16GB of this RAM down the track, installing and not running into any issues?
  3. SnooP-WiggleS
    SnooP-WiggleS Member
    Sep 20, 2004
    2,904
    Ballarat, Victoria
    With ryzen speeds go way down when using 4 sticks of ram or a dual rank dimms.
    {V|PER}
    {V|PER} Member
    Oct 18, 2006
    496
    Ballarat
    Yeah this was along the lines of my thinking. I've read a couple of issues with higher capacity too, ive been using 16GB for a long time now, cant say I've ever needed more think ill just stick to that.
  5. dasa2
    dasa2 Member
    Feb 5, 2003
    671
    Northern VIC
    You can run four sticks of samsung b die single rank fairly well if you get a Asus crosshair MB the ram should still do over 3200MHz unless you get really unlucky with your CPU memory controller.
    {V|PER}
    {V|PER} Member
    Oct 18, 2006
    496
    Ballarat
    Yep getting the Asus Crosshair and EK Monoblock I think.
  7. dasa2
    dasa2 Member
    Feb 5, 2003
    671
    Northern VIC
    Here is what one person found they could do with 2700x and Asus crosshair with b die sticks
    2x8GB 3733Mhz
    4x8Gb 3333Mhz
    2x16GB 3000Mhz
    4x16GB 2666Mhz
