low profile USB wall wart
Discussion in 'Electronics & Electrics' started by caspian, Jan 14, 2021.
  1. caspian
    caspian Member
    Mar 11, 2002
    11,908
    wondering if anyone knows of any low-profile USB wall warts available in Australia. I need a high current unit (to run a dual pad inductive charger) that is relatively flat and has the USB posts on the side, so it can go behind a piece of furniture without causing too much stand-out from the wall.
    something like this would be ideal: https://www.amazon.com.au/Nekmit-Portable-Charger-Smart-White/dp/B07FJNWC3Y
  2. Renza
    Renza Member
    Dec 1, 2004
    4,926
    caspian
    caspian Member
    Mar 11, 2002
    11,908
    trying to avoid those, because the cable run to the charger pad is already pretty short.
  4. Hater
    Hater Member
    Nov 19, 2012
    5,527
    can you swap the GPO out for one with USB in it and then use 90 degree USB cables?
    caspian
    caspian Member
    Mar 11, 2002
    11,908
    might be the easiest way I suppose. I have USB output GPOs in there now, but they're older low current ones. I see I can get 3.4 amp ones now.
  6. merlin13
    merlin13 Member
    Apr 12, 2003
    2,139
    back in BrizVegas
    Yeah, that 3.4 amp rating is for each, or total combined for multiple USB outlets?
    Other trick/trap with the high current wall plate ones will be make sure your (presumably?) longer USB cable will happily play passing the higher current. Encountered a few instances where running 3 metre USB cables on high output chargers didn't actually result in the devices doing fast charging. Shortened the cables right down they then did... even buzzed the cables out to see matching pinouts.
  7. cvidler
    cvidler Member
    15,310
    Need to check teh specs of whatever unit you buy. I've seen some where one port is 3A and the second is 1.5. others where either port will do 3A but only 4A in total etc. etc. plenty of ways to be dodgy with the advertises vs. the actuality.
    Also, thin gauge wire (like that in USB cables, especially cheaper ones), will have lots of voltage drop as they get longer, so charging will be affected. use the best quality and shortest cable you can, and if possible the fancier higher voltage chargers (quickcharge, that run at 9 or 12 v, they're less affected by voltage drop/distance).
    caspian
    caspian Member
    Mar 11, 2002
    11,908
    I only need one port to deliver high current. well aware that the rated capacity is total, and the USB cable is standard length - I just can't afford the additional length from the GPO to the floor. nor can I use a shorter cable anyway, as the end on the charging pad is nonstandard.
    the cable will also will be the same regardless of whether I use the supplied wall wart or a GPO with integrated charger, so it won't make any difference what the power source is.
    thanks, buying some replacement GPOs tomorrow morning.
  9. wintermute000
    wintermute000 Member
    Jan 23, 2011
    2,562
    You could use one of those vertical ones with 4 or 5 ports and place it sideways
  10. -AL-
    -AL- Member
    Jul 16, 2001
    41
  11. mjunek
    mjunek Member
    Apr 1, 2003
    1,101
    Western Sydney
  12. Fred Nurk
    Fred Nurk Member
    Apr 5, 2002
    2,247
    Cairns QLD
    I was of the impression that a lot of the inductive chargers rely on the proprietary Qualcomm fast charge and that mere high current 5V output doesn't get it to behave, at least not from an inductive fast charge point of view.
    I'm not aware of any of the hard wired USB outlets that support the proprietary shit though, plenty of units that'll do 2.5A at 5V however.
