Lumin Disc or Plasma Globe - able to cause damage
Discussion in 'Electronics & Electrics' started by psychobunny, Jun 4, 2013.
  1. psychobunny
    psychobunny Member
    Mar 30, 2006
    2,393
    Melbournish 3750
    Hi, just wondering what effects a plasma globe or a lumin disc could have on a PC if it is in close proximity?
    could they fry a PC or wipe a drive if in contact or if they are close by?
  2. Fishface
    Fishface Member
    Mar 17, 2004
    1,612
    Absolutely no effect whatsoever.
    Might interfere with some computer speakers.
  3. 2xCPU
    2xCPU Member
    Jan 21, 2005
    3,328
    Saigon
    Depends on your definition of "close by".
    On the far side of a room - no.
    Deliberate coupling - absolutely.
    Have a read of the Wiki article.
    The voltage inside is well above 'normal' ESD protection built into modern chip.
    2.
    psychobunny
    psychobunny Member
    Mar 30, 2006
    2,393
    Melbournish 3750
    I'm thinking mounting a globe or disc to or inside a case - that close
  5. aXis
    aXis Member
    5,548
    Kalgoorlie, WA
    Inside a case is a terrible idea.
    No, they wont wipe a drive, the magnetic feild required is too high. They will however put out lots of EM (radio) radiation, and the wires on your motherboard will act as antennas. I think it would be very easy to have bits flipped and data corrupted whilst in transit between the CPU and RAM/peripherals.
    If you did put it inside a case you'd want it seperatred from any electronics by a decent faraday cage.
  6. 2xCPU
    2xCPU Member
    Jan 21, 2005
    3,328
    Saigon
    It sounds like a prop in a 1940s SiFi film!
    Get your oldest / least wanted PC (or find one on hard rubbish). Set it running Memtest (or super Pi if it has an OS). Drop the globe in and see what happens.
    I'd think it'd kill the PC, but perhaps not.
    Remember that ESD damage is cumulative, so just because it doesn't fail instantly, doesn't mean there is no damage.
    2.
  7. desertstalker
    desertstalker Member
    Feb 5, 2005
    386
    A grounded mesh screen (attached to the metal case) on the back of the globe should block the EMF though.
    But yeah, I would not run one inside the case of a PC (the metal case of a PC is a pretty good Faraday cage as long as it does not have too many holes).
  8. 2xCPU
    2xCPU Member
    Jan 21, 2005
    3,328
    Saigon
    Rather defeats the purpose of putting it in a case if you can't see it.
    2.
  9. desertstalker
    Feb 5, 2005
    386
    Presumably there is a window in the case so you can see the globe, if you cover the section between the globe and the PC components with mesh then you can protect the PC and still see the globe.
  10. Duff Man
    Duff Man Member
    May 16, 2005
    1,919
    Where abouts are you thinking of getting a lumin disk here in Australia? I was looking on Amazon but they won't ship here.
