Luthier notched straight edge
Discussion in 'Musicians' started by Skexis, Jun 6, 2018.
  1. Skexis
    Skexis Member
    Dec 27, 2011
    226
    Adelaide, 5158
    Anyone know where I can get one of these for a bass at a price that won't make me weep uncontrollably? Prices in the USA are around USD$20. Prices over here are up around the AUD$100 mark even though it's still just a piece of metal measuring around 800x3.5x38mm.
    Beginning to think it might be cheaper to get someone to knock one up for me.
  2. Agg
    Agg Lord of the Pings
    Jun 16, 2001
    30,901
    A Reported Post Near You
    Sounds like a hole in the market. :) But you're right, it doesn't sound like a particularly difficult thing to fabricate. Does it have to be metal? Could you get one 3d printed?
    Skexis
    Skexis Member
    Dec 27, 2011
    226
    Adelaide, 5158
    Don't know anything about 3d printing but I suspect not as the edge needs to be dead flat and have no give. Most metal ones are machined. Might get away with thick perspex I suppose.
    I've also wondered if I could get a suitable meter ruler and use a Dremel to cut the notches.
  4. negatron
    negatron Member
    Jan 27, 2008
    1,270
    yep, +1 for dremelling the metal ruler.
    Skexis
    Skexis Member
    Dec 27, 2011
    226
    Adelaide, 5158
    Well I went to Bunnings today to look at metal rulers but ended up buying an aluminum bar instead as I reckon it'll be easier to cut. Currently looking for a Dremel or similar on Gumtree but might look at using an angle grinder as I've already got one of those.
  6. Ratzz
    Ratzz Member
    Mar 13, 2013
    7,344
    Cheltenham East 3192
    An angle grinder? Your notches wont exactly be thin, even with the thinnest of cutting wheels. You'd be better off using a hacksaw, much more controllable and much thinner notches than you'll ever get with an angle grinder. Dremel is a better choice of tool if you want finer notches, but a hacksaw would be far superior to an angle grinder. Aluminium is not hard to cut.
  7. negatron
    negatron Member
    Jan 27, 2008
    1,270
  8. oculi
    oculi Member
    Aug 18, 2004
    10,064
    does it just have to clear the frets? just use a file.
    Skexis
    Skexis Member
    Dec 27, 2011
    226
    Adelaide, 5158
    No, thats for a regular guitar with a scale length of around 24". Basses have a longer scale of around 34" and the frets are more widely spaced. Anything non-notched will only indicate if the top of the frets are level.
    My issue is the bass I'm fixing up has been left unloved for so long that the fretboard is significantly out. Only when this is straight is it worth looking at what the frets are up to.
  10. hello people
    hello people Member
    Jul 27, 2006
    309
    In a bucket
    If there's one thing consistent with products in Australia...you get gouged.
    Skexis
    Skexis Member
    Dec 27, 2011
    226
    Adelaide, 5158
    ...and will continue to be, even more so now the GST free threshold has been done away with. Thanks Gerry, not.
