[Mac OS X 1.5] USB Hub Stuck on 1.1
Discussion in 'Apple Desktop Hardware/Software' started by wwwww, Jul 4, 2010.
  1. wwwww
    wwwww Member
    Aug 22, 2005
    6,410
    Bangkok
    I just installed Mac OS X 1.5 from a USB drive and that hub is not stuck on 1.1, consequently all my external ports are very slow, Bluetooth doesn't work. Is there a way to upgrade the drivers/software so that they run at 2.0 speeds short of buying a Firewire drive and reinstalling?
    Macbook Pro Unibody 13"
    Under USB Device Tree in the System Profiler, it lists:
    USB Bus
    USB Bus
    USB High Speed Bus
    USB High Speed Bus
    The first two have the AppleUSBOHCI driver and the latter two has the AppleUSBEHCI driver. I need the first two to have the AppleUSBEHCI driver also. This may have been caused by installing the OS from a USB DVD drive.
    Is there a way to change the drive installed on a Mac OS? In windows you just right click, update driver. I don't suppose Macs would make it that easy?
  2. bugayev
    bugayev Whammy!
    May 15, 2003
    4,092
    It has nothing to do with installing from a USB drive, for some reason the hub is presenting itself as USB1.1 to the OS.
    wwwww
    wwwww Member
    Aug 22, 2005
    6,410
    Bangkok
    It's not the hub, if I install from the internal drive I get USB 2.0, if I install from a USB drive I get USB 1.1, but I have two drives in RAID1 so I need to install from the USB drive to get it up and running.
    I've tried that Apple+Shift+Ctrl+Power stuff already (clearing CMOS equiv).
  4. xcalibur
    xcalibur Member
    Sep 12, 2002
    1,405
    Taringa, Brisbane
    TelL us more about your hub. What are the specifications and is it powered.
    wwwww
    wwwww Member
    Aug 22, 2005
    6,410
    Bangkok
    Two of the internal hubs that come with the Macbook Pro 13" Unibody. It comes with 4 hubs, I believe they're just the standard Intel ich8r hubs which are all USB 2.0.
  6. xcalibur
    xcalibur Member
    Sep 12, 2002
    1,405
    Taringa, Brisbane
    i've never had an issue like that. i can only recommend that if your mac is in warranty, call apple or you can book it with a genius.
  7. Stanza
    Stanza Member
    2,901
    Are you talking the USB via the keyboard?
    ie the keyboard has 2 x usb port... and is USUALLY usb1.1
  8. bugayev
    bugayev Whammy!
    May 15, 2003
    4,092
