MAD MAX TRIBUTE CASE MOD PC BUILD
Discussion in 'Modding Worklogs' started by mnpctech, May 17, 2018.
  1. mnpctech
    mnpctech Member
    Mar 16, 2003
    877
    Minnesota
    Welcome! Thanks for checking out my tribute to Mad Max & his Interceptor build log. This is one of my Bucket list theme PC builds. My mother brought me to the premiere of The Road Warrior movie and I've been fan of this world ever since. This will be a modified desktop PC with liquid cooling. Inspired by visual elements of Max's Interceptor and the Mad Max World. ...and maybe Fury Road. There shall be rust and maybe even a Detonator attached to the PC? (lol). I'll be sharing highlights of it's progression stages, including video clip links as I move along in this thread. I have a basic idea of what PC hardware components will occupy this mad max inspired PC (motherboard, CPU, DDR, GPU, SSD, PSU) The case is an Enermax Equlilence they donated to me last year. If you've followed my past personal builds, I like to find good deals on hardware whenever possible I do plan to fabricate the liquid cooling lines from 361 marine grade stainless tubing. No idea what brand of CPU & GPU water blocks, radiators and fittings I'll use yet.
    The case is the Enermax Equilence I was given. It sorta looks like a Fractal Case, but without any of the well thought out features.
    I apologize in advance if you're expecting me to pose a Mad Max action figure inside the case (haha). The Interceptor's V8 feels more appropriate. The scale Ford engine I'm using is by LIBERTY Classics, http://www.libertyclassics.com/
    I've added motorized shaft to spin the supercharger belt, you can watch it here, https://twitter.com/Mnpctech/status/992023385818492928
    I've modified the supercharger pulleys with larger plates to keep the belt from rolling off.
    I will be fabricating a new engine scoop to emulate Max's Scott Injector Scoop and painting everything dark grey.
    schmoove and Reins like this.
  2. mad_mic3
    mad_mic3 Member
    Jan 18, 2009
    2,790
    Nulkaba
    sweet as:)
  3. nope
    nope Member
    May 8, 2012
    3,738
    Tipshitswitchitin Queeersland
    WHITNESSED
    mnpctech
    mnpctech Member
    Mar 16, 2003
    877
    Minnesota
    Hey guys, Thank you for checking in and posting!
    If anyone's interested, my DIY guide on using hole saw to improve airflow in a plastic PC bezel,
    I cut this opening in the Equilence bezel with a Jigsaw.
  5. nope
    nope Member
    May 8, 2012
    3,738
    you look exactly how i thought a ocau'r would look ;)
    mnpctech likes this.
  6. /invariance\
    /invariance\ Member
    May 23, 2012
    1,228
    Oh boy, this is going to be good.
  7. havabeer
    havabeer Member
    Dec 12, 2010
    7,211
    you can get those silly things that plug into your cars cigarette lighter that sends a signal to the radio to make it play a beefy exhaust noise through the speakers, wonder if you could hook one up to a fan speed controller?
    mnpctech
    mnpctech Member
    Mar 16, 2003
    877
    Minnesota
    Thanks for tuning in guys!
    haha, havabeer, that would be hil-larious, but I'd wanna hear that super charger spool!
    oh, and no RGBs will be used in this build (lol)
    Sn@Ke and millen like this.
  9. GhostXiX
    GhostXiX Member
    Oct 30, 2015
    59
    lol 'leave the Gasoline, But take the hard tubing mods with you.' :lol::lol:
    Defyant likes this.
  10. Defyant
    Defyant Member
    Mar 11, 2004
    1,566
    Defyant Modded "Tail" Lights!
    You lost me bill.
  11. GhostXiX
    GhostXiX Member
    Oct 30, 2015
    59
    i don't think RGB mod will go well with this case mod.
    it should be something dark and metallic.
    mixed with chrome and rust.....
  12. dave_dave_dave
    dave_dave_dave Member
    Mar 17, 2004
    2,917
    Gold Coast
    Shes the last of the v8s, she suck nitro, phase 4 head, twin overhead cam, 600hp through the wheels.
  13. havabeer
    havabeer Member
    Dec 12, 2010
    7,211
    please put this picture at the top of the first post
  14. GhostXiX
    GhostXiX Member
    Oct 30, 2015
    59
    from the original movie, there is a nice scene where you can get the sound off of that B&W roots blower spooling up.
    just after the scene where Dave has posted.
    if i remember the movie correctly.
  15. GhostXiX
    GhostXiX Member
    Oct 30, 2015
    59
    or in the 2nd movie just before the wrecking of that interceptor.
    when he tries to run away from the mob.
  16. Matthew kane
    Matthew kane Member
    Jan 27, 2014
    3,147
    Oh boy this one should be sweet. Big Mad Max fan here.
    mnpctech
    mnpctech Member
    Mar 16, 2003
    877
    Minnesota
    haha, thanks for tuning in guys! Had opportunity to get back into the workshop yesterday and make some progress on my Mad Max / Road Warrior / Fury Road tribute PC build. I've decided to locate the V8 to the top panel. I'm going to mock up a 120mm slim radiator to see how it looks in front of the V8 engine and bezel. Hmm, on 2nd thought, maybe a 80mm radiator would be better scale? I still need to fabricate the proper diamond blower for the engine. The Enermax Equilence case lacks a vertical GPU mount, so I've modified the chassis for this compact ITX/MATX vertical GPU bracket, https://mnpctech.com/case-mods-gami...-mounting-bracket-black-requires-cutting.html It's mounted on aluminum diamond plate, painted matte black. Here's a photo I found of the Falcon XB from the Fury Road movie before some stages I captured of my progress.
    mnpctech
    mnpctech Member
    Mar 16, 2003
    877
    Minnesota
    That's location for the GPU with this do-it-yourself vertical mount. The final GPU will have water block.
    Next stage is modifying the top rear portion of the Enermax Equilence case to hold two water reservoirs to emulate the rear fuel tanks on the falcon XB.
  19. Defyant
    Defyant Member
    Mar 11, 2004
    1,566
    Fantastic start Bill, will there be room for a Defyant Style custom NOS res :D
  20. Vanne
    Vanne Member
    Apr 20, 2003
    3,224
    DXB.. mostly.
    LOVE IT!!!!:leet:
