make Sound sensitive switch
Discussion in 'Electronics & Electrics' started by mr_wrxman, Sep 10, 2006.
  1. mr_wrxman
    mr_wrxman Member
    May 1, 2005
    2,381
    Sydney 2141
    Hi,
    What sort of components do i need in order to make a sound sensitive switch. i.e. clap and light turns on for a moment (until sound stops). Similar to this linky
    Is there any place to buy them cheap (a couple of dollars) or where can i get instructions/parts to make it.
    Thanks
  2. nux
    nux Member
    Jan 20, 2002
    16,780
    The Jaycar kit will be one of the cheapest and easiest options.
    There are plenty of circuits available, just do a Google.
    Here is one that I found.
    Another, another, another...
    mr_wrxman
    mr_wrxman Member
    May 1, 2005
    2,381
    Sydney 2141
    The JayCar kit is about $12, if that's the cheapest, it would be better just to go with the sound sensitive switch module from PCCG. They are the same thing right?
  4. Goose1981
    Goose1981 Member
    Sep 30, 2004
    19,355
    Buy a second hand dancing coke can from the 80's. They were awesome..
  5. sinerster_one
    sinerster_one Member
    Oct 2, 2004
    193
    yep probably buying one from pccasegear seems to be the go except for the $10 postage fee :Paranoid:
    what are you planning to use it for?
  6. genesis[OFT]
    genesis[OFT] (Banned or Deleted)
    May 27, 2006
    261
    lol, my next door neighbour has one of them....so cool...i want one :D
