Marine tank water chillers - advice needed
Discussion in 'Pets & Animals' started by Jacom, Feb 5, 2014.
  1. Jacom
    Jacom Member
    May 7, 2002
    970
    Geelong, Victoria
    Hi.
    I've got myself a 300 litre marine tank with a birdnose, tomato clown, some glassfish and wrasse.
    Problem is, the heat in summer is raising the tank temperature to over 30 degrees sometimes ( have a lost a few fish :( ).
    The tank is kept inside out of any direct sunlight (only incidental non-direct sunlight gets to it).
    Frozen water bottles and fans blowing over the top do help a little, but the fan evaporates the water too quickly and I can't always be there to replace the water bottle, so have been considering chillers.
    I have been told Teco unit's are right up there but are pricey.
    Aqua one's seem more reasonably priced.
    I'll be upgrading the tank *sometime in the future* to a larger 880 litre, so a unit that could be used for that also would be great.
    I've read some units also have UV lights and heaters inbuilt. That'd be nice but not required.
    Any thoughts/recommendations? If it costs alot but is worth it I'd still consider it.
  2. !JonZap!
    !JonZap! Member
    Jun 29, 2003
    1,574
    enruobleM
    I have been using a Resun for the last couple of years, it has been reliable and is fairly quiet.
    Jacom
    Jacom Member
    May 7, 2002
    970
    Geelong, Victoria
    Do you remember the model number? (and or if it does heating/UV filter?)
    I've seen some of those advertised.
  4. n3wbi379
    n3wbi379 Member
    May 15, 2006
    4,636
    Melb
  5. sjp770
    sjp770 Member
    Apr 23, 2009
    1,723
    Sticks, NSW
    Haelias or Teco's. I had a Sfiligoi Superflite Chiller for a while but it busted and there were no parts.
    Replaced it with a Teco and it didn't skip a beat.
    sign up to http://www.masa.asn.au/phpBB3/ if you want the best help in aus.
  6. Oniell.au
    Oniell.au Member
    Jun 1, 2003
    371
    NSW
    Shame your not in Sydney, I just shut down my tank and have a Hailea HC-150A that I'm about to throw up on the fee bay, could of given it to you for half the cost of a new one, only had it running for 6months.
    http://www.guppysaquariumproducts.c...-chiller-marine-aquarium-to-400l/prod_38.html
    Is where I bought mine from. I was running this on 350L tank and it kept it at at a constant 26 degrees easy. Very quiet and efficient unit too. Had it set to come on at 26.5 degrees and over the space of about 90minutes it would lower it back down so there weren't any huge fluctuations in temperature.
    Jacom
    Jacom Member
    May 7, 2002
    970
    Geelong, Victoria
    Oh thank you, yeah Geelong is a bit far away but would have been keen.
    Sounds like the Hailea is a good brand then, though still seeing alot of good reviews for the Teco range.
    Might get a Hailea and slowly save up for a future (not sure how far ahead) Teco purchase. (Could then use the Hailea in a future secondary tank).
    Mainly because I really want to get a chiller now but can't afford the top shelf ones.
    Jacom
    Jacom Member
    May 7, 2002
    970
    Geelong, Victoria
  9. yoda123
    yoda123 Member
    Apr 17, 2003
    2,791
    QLD
    Probably too late now, but for future reference they are all similar brand wise. I myself have used both hailea and resun.
    Biggest thing is purchase from someone who will uphold the warranty.
    One such listed online vendor in this thread, with a name nothing to do with MARINE aquariums I think you would have a very hard time getting any warranty support out of.
  10. Dorz
    Dorz Member
    Jan 22, 2007
    1,816
    ive got a HC-500, pretty good chiller. had it cooling my ~650L tank+sump.
    just watch the temperature with a proper themometer, dont trust the inbuilt one. they can be up to half a degree out at times.
    also, it 'should' kick in the chiller at something like half a degree or a degree above what you set it to, and then cool down to a degree below. i cant remember exactly how far it cools, should say in the manual.
