MAX11L - in pictures
Discussion in 'Modding Worklogs' started by miahallen, Oct 6, 2010.
  1. OP
    miahallen
    miahallen Member
    Oct 3, 2010
    65
    Northern Japan
    Thanks everyone :cool:
  2. Stagea
    Stagea (Banned or Deleted)
    Jan 31, 2010
    92
    Sydney, 2176
    Power to size ratio has never been pushed as hard as this build. What a wonderful piece of work you have here! :thumbup:
  3. static1800
    static1800 Member
    Jul 1, 2010
    846
    South Coast, NSW
    What is the ambient temp like in the case? does everything breath ok with the hot air from the radiator venting into the case? Also what's the noise like?
  4. fang_laluna
    fang_laluna Member
    Sep 5, 2009
    1,186
    tight as...
  5. de_overfiend
    de_overfiend Member
    Jul 12, 2001
    2,526
    Gold Coast
    best mini pc build i have ever seen, ever :thumbup::thumbup::thumbup:
    just one question.... what are your temps like... load and idle - cpu/vid and hdd
    miahallen
    miahallen Member
    Oct 3, 2010
    65
    Northern Japan
    Thanks again :thumbup:
    All performance data published here:
    http://www.techreaction.net/2010/09...art-2–-max11l-featuring-corsair-and-gigabyte/
  7. pepsimax
    pepsimax Member
    Oct 24, 2008
    1,928
    The Shire
    i love this rig such a good job:thumbup:
  8. LostBenji
    LostBenji Member
    Oct 5, 2007
    6,084
    Up a tower somewhere....
    Not a fan of the questionable PSU mods. There is a reason why the LV and MV stages are kept away from each other. Open ended wires stuck to the inside of the case aint smart either. Guessing that your not licensed ?
    As for the rest, tight squeeze but it's in there now and working, just needs a LAN-bag to carry it.
  9. millsy
    millsy Member
    Mar 31, 2007
    13,589
    Where did he do that?
    You don't need a license to work with 12v either afaik :)
  10. Oppressa
    Oppressa Member
    Jun 5, 2004
    5,573
    Thread needs more pics! :)
    Awesome work, love the dedication.
  11. genesis
    genesis Member
    458
    NW, Tasmania
    This is ART!!
    This is a piece of art, Well done!!:thumbup:
  12. Liighthead
    Liighthead New Member
    Jul 22, 2010
    212
    nice work :D saw this on losias few days ago.. and on ocn :p :wired:
  13. moosi
    moosi Member
    Dec 3, 2007
    442
    I'd pay for someone to build me a PC like that, but so cramped everything is. Must feel like a heater being next to that. Hmmm.
  14. OnyxElite
    OnyxElite Member
    Jan 15, 2010
    194
    Sydney, NSW
    I'd pay for that too! It looks epic. Much better with the inside painted.
  15. Tommy1990
    Tommy1990 Member
    Aug 7, 2006
    38
    Sydney, NSW
    i gotta ask, does it get very hot having the HDD right under the PSU?
    miahallen
    miahallen Member
    Oct 3, 2010
    65
    Northern Japan
    Thanks guys :thumbup:
    One's an Intel SSD (no heat), the other is a Seagate Momentus XT (SSD/HDD hybrid....very low power)....so to answer your question, no. The storage solution doesn't warm up at all. The PSU stays pretty cool too :)
  17. MorgzMods
    MorgzMods Member
    Mar 27, 2010
    731
    i've done this myself, cut wires, and if you have a look his got single black heatshrink over the ends. even a clean cut with pliers wouldn't cause any issues, unless you had them sitting touching end to end.
    I'd love to see the 'licenses' of every person that's opened up a PSU or cut wires. or even sleeved it.
  18. Intensity
    Intensity Member
    Feb 12, 2010
    2,238
    Launceston TAS 7290
    Nice job there m8, sweet little lanbox :thumbup: ;)
  19. Ashtefere
    Ashtefere Member
    Dec 19, 2006
    64
    Nice work. Its like a shuttle with some more awesome thrown in. Just the sorta thing I like really ;)
    A small bit of advice with that water cooling kit - you have the intake and outtake tubes at the top.
    Because the corsair system is not actually maintenance free like they say, your water level will actually drop, sooner rather than later.
    Problem is, the pump is going to suck dry air because the intake is at the top, like so:
    -O------O-
    RADIATOR
    BOTTOM
    I would recommend having it on its side or upside down to maximise the amount of time you have before needing to rip it out and top it up.
    Always have the intake that goes to the pump as low as possible on the rad. Otherwise you end up with a dead pump and fried CPU.
    Again, nice work. Really like this kind of mod!
    -Ash
    miahallen
    miahallen Member
    Oct 3, 2010
    65
    Northern Japan
    Thanks for the tip Ash....what's your source?
    Also, if you were to perform maintainence...how would you do it? There's no fillport. Would you add one? :confused:
    Also, keep in mind, the rad is aliminum, and the block is copper making this a mixed metal loop, for anybody who does wish to flush the system, ensure you refill it with the proper additives to prevent corrosion ;)
