May have blown up the lens on my mum's DSLR... Now what?
Discussion in 'Photography & Video' started by Esposch, Jun 11, 2018.
  1. Esposch
    Esposch Member
    Jan 14, 2010
    148
    SE Melbourne (Knoxfield)
    Hi OCAU.
    As the title suggests, my mum was kind enough to lend me her DSLR (Olympus OM-D E-M10), with the stock M.Zuiko 14-42mm lens as well as another one for long-distance shoots.
    Unfortunately, I appear to have killed the lens.
    When connected, a black screen will appear and there is no lens information in the lower-centre of the screen, just the text "-.-".
    Have tried all of the factory resets and reconnected the lens multiple times; not much seems to fix things. Pin seems to pop into place correctly; I can hear it click and depressing the lens removal button will get a response in the viewfinder. It's definitely not a problem with the main unit, as the other lens works perfectly.
    Interestingly, if I don't actually install the lens in place and hold it in front of the image sensor on the camera's body, I can see a sorta-in-focus image on the screen/viewfinder. It's not possible to change the zoom or focus, though.
    I know how to disassemble electronic devices in general, and have pulled apart and reassembled camera lenses before, but I'm not exactly sure how to approach this problem.
    Anyone have any ideas?
    I'm suspecting a dead MCU...
  2. stevo4
    stevo4 Member
    10,631
    Tried cleaning the lens contacts?
    otherwise
    a warranty job.
  3. power
    67,115
    if you didn't drop it or something stupid like that it's hardly your fault just a co-incidence that you were using it. Just tell her it's playing up and that you haven't dropped it or anything.
  4. Scootre
    Scootre Member
    Mar 29, 2009
    387
    Syd
    Don't pull apart the lens. Take it to a camera centre, pay to get it fixed properly. Cut your losses.
    Esposch
    Esposch Member
    Jan 14, 2010
    148
    Come on... Where's the fun in that?
    BurningFeetMan likes this.
  6. mtma
    mtma Member
    Aug 12, 2009
    5,906
  7. Mathuisella
    Mathuisella Member
    Dec 3, 2002
    7,540
    in your gearbox...grindin
    how does a lense die ? isn't it just glass lenses ?
  8. Scootre
    Scootre Member
    Mar 29, 2009
    387
    Syd
    Yeah, you're right.
    @OP: it probably just needs a good squirt of WD40.
  9. BurningFeetMan
    BurningFeetMan Member
    Apr 22, 2003
    9,622
    Veg City
    I was thinking 15 minutes in the oven at 200ÂșC should do the trick...
    Esposch
    Esposch Member
    Jan 14, 2010
    148
    Thanks, that's what I ended up doing. It's not mine, after all.
    Glass lens and and some electronics that identifies the lens parameters to the camera. The glass is fine but the electronics are not.
